질문게시판 > LED 잔상 텍스터 플레이
TODAY470 TOTAL2,679,177
BASIC4MCU | 질문게시판 | LED 잔상 텍스터 플레이
작성자 박희범 작성일2018-06-11 15:05 조회11,097회 댓글2건
#include <mega128.h>
#include <delay.h>
#include <stdio.h>
#define U16 unsigned int
#define U08 unsigned char
char hannam[72]={
  0x00,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0x00,0xFF,0xFF,0x07,0xF3,0xF4,0xF6,0xF6,0xF6,0xF6,0xF4,0xF3,0x07,0xFF,0xFF,
  0x00,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0x00,0xFF,0xFF,0x00,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0x00,0xFF,0xFF,
  0x07,0xF3,0xF4,0xF6,0xF6,0xF6,0xF6,0xF4,0xF3,0x07,0xFF,0xFF,0x00,0xFE,0xFd,0xFB,0xF7,0xF7,0xFB,0xFD,0xFE,0x00,0xFF,0xFF
char elec[130]={
  0x00,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0xFF,0xFF,0xFF,0x00,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF,0xFF,
  0x00,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0x76,0xFF,0xFF,0xFF,0x81,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0xBD,0xFF,0xFF,0xFF,
  0xFE,0xFE,0xFE,0xFE,0x00,0xFE,0xFE,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0x00,0xF6,0xF6,0xF6,0xF6,0xF6,0xF6,0xF6,0xF6,0x09,0xFF,0xFF,0xFF,
  0x81,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x81,0xFF,0xFF,0xFF,0x00,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0x00,0xFF,0xFF,0xFF,
  0xFF,0xFF,0x7E,0x7E,0x00,0x7E,0x7E,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x81,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0x7E,0xBD,0xFF,0xFF,0xFF
char jwl[48]={
  0xAE,0x56,0x5A,0x5A,0x54,0x54,0x4E,0x5B,0x5B,0xA0,0xFF,0xFF,0xED,0xEA,0xEA,0xEA,0x0A,0xEA,0xEA,0xEa,0xED,0xFF,0xFF,0xFF,
  0x02,0x4A,0x4A,0x4A,0x4A,0x4A,0x48,0x5F,0x00,0xFB,0xFF,0xFF,0xFF,0xF3,0xE1,0xA0,0x81,0x03,0x81,0xA0,0xE1,0xF3,0xFF,0xFF
char ksl[48]={
  0x7E,0x7E,0x7E,0x0E,0x7E,0x7E,0x0E,0x7E,0x7E,0x40,0xFF,0xFF,0xEF,0xE7,0xEB,0xED,0x0E,0xED,0xEB,0xE7,0xEF,0xFF,0xFF,0xFF,
  0x00,0x67,0x67,0x67,0x67,0x67,0x67,0x67,0x6F,0x00,0xFF,0xFF,0xFF,0xF3,0xE1,0xA0,0x81,0x03,0x81,0xA0,0xE1,0xF3,0xFF,0xFF
char font1[][10]={
  {0xFF,0xFF,0x81,0x7E,0x7E,0x7E,0x7E,0x81,0xFF,0xFF}, //0
  {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0xFF,0xFF}, //1
  {0xFF,0xFF,0x06,0x76,0x76,0x76,0x76,0x70,0xFF,0xFF},
  {0xFF,0xFF,0x76,0x76,0x76,0x76,0x76,0x00,0xFF,0xFF},
  {0xFF,0xFF,0xF0,0xF7,0xF7,0xF7,0xF7,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x70,0x76,0x76,0x76,0x76,0x06,0xFF,0xFF},
  {0xFF,0xFF,0x00,0x76,0x76,0x76,0x76,0x06,0xFF,0xFF},
  {0xFF,0xFF,0xFE,0xFE,0xFE,0xFE,0xFE,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x00,0x76,0x76,0x76,0x76,0x00,0xFF,0xFF}, //8
  {0xFF,0xFF,0xF0,0xF6,0xF6,0xF6,0xF6,0x00,0xFF,0xFF}, //9
  {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF}, //x
  {0xFF,0xFF,0x03,0xF5,0xF6,0xF6,0xF5,0x03,0xFF,0xFF}, //A
  {0xFF,0xFF,0X00,0x76,0x76,0x76,0x76,0x89,0xFF,0xFF}, //B
  {0xFF,0xFF,0x81,0x7E,0x7E,0x7E,0x7E,0xBD,0xFF,0xFF},
  {0xFF,0xFF,0x00,0x7E,0x7E,0x7E,0x7E,0x81,0xFF,0xFF},
  {0xFF,0xFF,0x00,0x76,0x76,0x76,0x76,0x76,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xF6,0xF6,0xF6,0xF6,0xF6,0xFF,0xFF},
  {0xFF,0xFF,0x81,0x7E,0x7E,0x7E,0xAE,0x0D,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xF7,0xF7,0xF7,0xF7,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x7E,0x7E,0x00,0x7E,0x7E,0xFF,0xFF,0xFF},
  {0xFF,0xFF,0xBE,0x7E,0x80,0xFE,0xFE,0xFF,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xE7,0xDB,0xBD,0x7E,0xFF,0xFF,0xFF},
  {0xFF,0xFF,0x00,0x7F,0x7F,0x7F,0x7F,0x7F,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xFD,0xFB,0xFB,0xFD,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xFD,0xF3,0xCF,0xBF,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xF6,0xF6,0xF6,0xF6,0xF9,0xFF,0xFF},
  {0xFF,0xFF,0xC1,0xBE,0xBE,0xAE,0x9E,0x41,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xF6,0xF6,0xF6,0xF6,0x09,0xFF,0xFF},
  {0xFF,0xFF,0xB9,0x76,0x76,0x76,0x76,0x8D,0xFF,0xFF},
  {0xFF,0xFF,0xFE,0xFE,0x00,0xFE,0xFE,0xFF,0xFF,0xFF},
  {0xFF,0xFF,0x80,0x7F,0x7F,0x7F,0x7F,0x80,0xFF,0xFF},
  {0xFF,0xFF,0xF8,0xC7,0x3F,0x3F,0xC7,0xF8,0xFF,0xFF},
  {0xFF,0xFF,0x00,0xBF,0xCF,0xCF,0xBF,0x00,0xFF,0xFF},
  {0xFF,0xFF,0x3E,0xCD,0xF3,0xF3,0xCD,0x3E,0xFF,0xFF},
  {0xFF,0xFF,0xFC,0xF3,0x0F,0xF3,0xFC,0xFF,0xFF,0xFF}, //Y
  {0xFF,0xFF,0x3E,0x5E,0x6E,0x76,0x7A,0x7C,0xFF,0xFF}  //Z
U08 uniPhase[]={0x81,0x85,0x84,0x86,0x82,0x8A,0x88,0x89};
U08 num=10;
void LDelay(U16 Dly,float f){ U16 i; float dd; for(i=0; i<Dly; i++)for(dd=0.;dd<f;dd+=0.2); }
void led_hannam(){ static int i=0,c=0; if(PIND==0xFF)c=1; else PORTA=PORTB=0xFF; if(c){ PORTA=PORTB=hannam[i]; if(++i== 71)i=c=0; } LDelay(1,10.8); } // HANNAM문자 함수
void led_elec()  { static int i=0,c=0; if(PIND==0xFF)c=1; else PORTA=PORTB=0xFF; if(c){ PORTA=PORTB=elec[i];   if(++i==129)i=c=0; } LDelay(1, 7.8); } // ELECTRONIC문자 함수
void led_jwl()   { static int i=0,c=0; if(PIND==0xFF)c=1; else PORTA=PORTB=0xFF; if(c){ PORTA=PORTB=jwl[i];    if(++i== 47)i=c=0; } LDelay(1,20.6); } // jwl문자 함수
void led_ksl()   { static int i=0,c=0; if(PIND==0xFF)c=1; else PORTA=PORTB=0xFF; if(c){ PORTA=PORTB=ksl[i];    if(++i== 47)i=c=0; } LDelay(1,20.6); } // ksl문자 함수
void led(U08 n)  { static int i=0,c=0; if(PIND==0xFF)c=1; else PORTA=PORTB=0xFF; if(c){ PORTA=PORTB=font1[n][i]; if(++i==9)i=c=0; } LDelay(1,20.6); }
void LED_USART(){
  U08 c;
  if((UCSR0A&0x80)==0x80){
    c=UDR0;
    if     ((c>='0')&&(c<='9'))num=c&0x0F;
    else if((c>='A')&&(c<='Z'))num=c-'A'+11;
    else if(c=='-')num=10;
    else if(c=='=')num=37;
    else if(c==';')num=38;
    else if(c==',')num=39;
void count(){
  if     (num<= 9)led(num);
  else if(num==10)led_hannam();
  else if(num<=36)led(num);
  else if(num==37)led_elec();
  else if(num==38)led_jwl();
  else if(num==39)led_ksl();
void SDelay(U16 Dly){ while(Dly--); }
void uni_HA_MtrMove(U08 Direction){
  static int Phase=0; U08 TroquePhase;
  TroquePhase=uniPhase[Phase];
  if(Direction){ PORTB=TroquePhase; if(++Phase>8)Phase=0; }
  TroquePhase&=0xFF;
  SDelay(800);
void main(){
  PORTA=0xFF; DDRA=0xFF;
  PORTB=0xFF; DDRB=0xFF;
  PORTD=0xFE; DDRD=0xFE;
  UBRR0L=8; UCSR0B=0x18;
    LED_USART(); count();
    uni_HA_MtrMove(1);
저희가 hannam 이아닌
KANGWON 이나 숫자 1 , 2, 3,4,5,6,7,8,9 모양을 남기고싶은데 어떻게 해야할까요..?
조회수 11,097
char hannam[72]={
폰트를 2진수로 배열하면 무슨 글자인지 알아볼 수 있습니다.
알파벳이나 숫자는 char font1[][10] 에 있으니 사용법만 공부하면 되겠죠?
박희범님의 댓글
박희범 댓글의 댓글 작성일
폰트를 2진수르 배열한다는 말이 잘 이해가안가요 ㅜㅜ..
답변 답변글 답변 : 아두이노 보드 Arduino/Geunie UNO 컴파일 에러 master 18-06-19 8318
질문 아두이노 수동부저와 led제어 비공개 18-06-19 11415
답변 답변글 답변 : 아두이노 수동부저와 led제어 master 18-06-19 8643
질문 블루투스 연결이 안됩니다. 비공개 18-06-18 6915
답변 답변글 답변 : 블루투스 연결이 안됩니다.댓글[1] master 18-06-18 10927
답변 답변글 답변 2: 답변 : 블루투스 연결이 안됩니다.댓글[4] master 18-06-19 13423
질문 버튼으로 서브모터 각도 조절 첨부파일 비공개 18-06-18 6957
답변 답변글 답변 : 버튼으로 서브모터 각도 조절댓글[7] master 18-06-18 25287
답변 답변글 답변 2: 버튼으로 서브모터 각도 조절댓글[1] master 18-06-19 11146
질문 아두이노 질문드립니다 ㅠ댓글[3] qlsdl 18-06-18 11698
답변 답변글 답변 : 아두이노 SimpleDHT LiquidCrystal_I2C master 18-06-18 8434
질문 가변저항으로 세그먼트댓글[4] 이미지첨부파일 비공개 18-06-18 14304
답변 답변글 답변 : 가변저항으로 세그먼트댓글[4] 이미지 master 18-06-18 12770
답변 답변글 답변 2: 가변저항으로 세그먼트댓글[2] 이미지 master 18-06-18 10436
질문 아두이노 전원관련 질문 드립니다.댓글[4] 이미지 홍성훈 18-06-18 16275
질문 Switch 문으로 변경댓글[3] 이미지첨부파일 비공개 18-06-18 9636
질문 질문합니다~!!!댓글[1] 푸린 18-06-18 7728
질문 부탁드립니다댓글[2] 푸린 18-06-18 8505
답변 답변글 답변 : 부탁드립니다댓글[1] 푸린 18-06-18 7495
질문 질문드립니다...!!!댓글[1] 푸린 18-06-18 8330
질문 질문드립니다.댓글[1] 푸린 18-06-18 9921
답변 답변글 답변 : 아두이노 DHT-11 먼지센서 LCD master 18-06-18 7465
질문 아두이노 질문입니다.댓글[2] 이미지첨부파일 clown 18-06-18 9570
답변 답변글 답변 : 아두이노 사운드센서 NeoPixel master 18-06-18 7497
질문 아트메가 128 코딩 질문드립니다.. 전기의달인감전맨 18-06-18 7515
답변 답변글 답변 : 아트메가 128 코딩 질문드립니다.. master 18-06-18 7507
질문 질문드립니다.!!댓글[1] 푸린 18-06-17 8332
질문 프로세싱 동영상 재생 비공개 18-06-17 10234
답변 답변글 답변 : 프로세싱 동영상 재생 master 18-06-17 7644
질문 압력센서를 사용한 아두이노 프로세싱 연동에 대해 질문드립니다.댓글[1] 이미지 듀런 18-06-17 10459
