질문게시판 > 아두이노 심박센서 + 체온센서 코드 합치기 질문.
TODAY274 TOTAL1,939,432
BASIC4MCU | 질문게시판 | 아두이노 심박센서 + 체온센서 코드 합치기 질문.
작성자 Asasa 작성일2021-11-22 17:10 조회50회 댓글2건
	1. 심박센서 + 화면 + 알람
#define USE_ARDUINO_INTERRUPTS true    // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h>    // Includes the PulseSensorPlayground Library.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
/* Uncomment the initialize the I2C address , uncomment only one, If you get a totally blank screen try the other*/
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
//#define i2c_Address 0x3d //initialize with the I2C addr 0x3D Typically Adafruit OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1  //  QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000
//  Variables
const int PulseWire = 0;      // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13;          // The on-board Arduino LED, close to PIN 13.
int Threshold = 550;          // Determine which Signal to "count as a beat" and which to ignore.
                              // Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
                              // Otherwise leave the default "550" value.
int buzzerPin = 7;
int a = 0;
int t2 = 0;
int Bflag = 1;
int ledflag = 1;
int count = 0;
unsigned long t1;
PulseSensorPlayground pulseSensor;  // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
  Serial.begin(9600);          // For Serial Monitor
  pinMode(9,INPUT_PULLUP);
  // Configure the PulseSensor object, by assigning our variables to it.
  pulseSensor.analogInput(PulseWire);
  pulseSensor.blinkOnPulse(LED13);      //auto-magically blink Arduino's LED with heartbeat.
  pulseSensor.setThreshold(Threshold);
  display.begin(i2c_Address, true); // Address 0x3C default
 //display.setContrast (0); // dim display
  display.display();
  delay(2000);
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(SH110X_WHITE);
  // Double-check the "pulseSensor" object was created and "began" seeing a signal.
  if (pulseSensor.begin()) {
    Serial.println("We created a pulseSensor Object !");  //This prints one time at Arduino power-up,  or on Arduino reset.
  pinMode(buzzerPin, OUTPUT);
  if(!digitalRead(9)){
    a = 0;
  int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
                                              // "myBPM" hold this BPM value now.
  if (pulseSensor.sawStartOfBeat()) {            // Constantly test to see if "a beat happened".
    Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
    Serial.print("BPM: ");                        // Print phrase "BPM: "
    Serial.println(myBPM);
    display.setCursor(0, 0);
    display.write(3);
    display.print("BPM: ");
    display.println(myBPM); // Print the value inside of myBPM.
    display.display();
  if(myBPM > 79 or myBPM<60){
    a = a + 1;
    if(a>15 and a<30){
      tone(buzzerPin,162,100);
    else if(a>=30){
      tone(buzzerPin,462,100);
    a = 0;
2. 체온 + 화면
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <SPI.h>
#include <Wire.h>
#define i2c_Address2 0x5A
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
#define XPOS 0
#define YPOS 1
#define DELTAY 2
  mlx.begin();
  while (!Serial);
  Serial.println("Adafruit MLX90614 test");
  if (!mlx.begin()) {
    Serial.println("Error connecting to MLX sensor. Check wiring.");
    delay(2000);
  // Clear the buffer.
  // Set text
  float myTEM = mlx.readObjectTempC();
  Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
  Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
  display.setCursor(0, 30);
  display.print("Tem:"); display.print(myTEM); display.println("C");
  display.display();
  Serial.println();
각각의 코드는 잘 작동됩니다.
코드를 합쳐서 OLED 기판에 심박수와 체온을 동시에 표시하고 싶은데
코드 합치는 법을 모르겠습니다! 도와주세요
조회수 50
#include <Wire.h>
#include <SPI.h>
#include <Wire.h>
Adafruit_SH1106G  display=Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define XPOS      0
#define YPOS      1
#define DELTAY    2
Adafruit_MLX90614 mlx=Adafruit_MLX90614();
static const unsigned char PROGMEM logo16_glcd_bmp[] ={
  B00000000, B11000000,B00000001, B11000000,B00000001, B11000000,B00000011, B11100000,
  B11110011, B11100000,B11111110, B11111000,B01111110, B11111111,B00110011, B10011111,
  B00011111, B11111100,B00001101, B01110000,B00011011, B10100000,B00111111, B11100000,
  B00111111, B11110000,B01111100, B11110000,B01110000, B01110000,B00000000, B00110000
//  Variables
const int LED13 = 13,buzzerPin = 7;
int a = 0,t2 = 0,Bflag = 1,ledflag = 1,count = 0;
unsigned long t1;
  display.display();
  delay(2000);
  mlx.begin();
  while (!Serial);
  if (!mlx.begin()) {
  delay(2000);
  // Set text
  if(!digitalRead(9)){ a = 0; }
  if(pulseSensor.sawStartOfBeat()){
    Serial.print("BPM: "); Serial.println(myBPM);
    display.setCursor(0, 0); display.write(3);
    display.print("BPM: ");  display.println(myBPM);
    display.display(); display.clearDisplay();
    a = a + 1;
    if(a>15 and a<30){  tone(buzzerPin,162,100); }
    else if(a>=30){    tone(buzzerPin,462,100); }
  else{    a = 0;  }
  display.display(); Serial.println();
합치는 것은 어렵지 않지만
중복되는 핀을 조정하고
중복되는 코드를 제거하고
원하는대로 동작하도록 코드를 수정하는 것은 직접하셔야 합니다.
Asasa님의 댓글
Asasa 댓글의 댓글 작성일
OLED기판에 계속 표시가 안되더라구요 ㅜ
혹시 합치는 기본적인 틀만 잡아주실 수 있나요!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 4181
공지 사이트 이용 안내댓글[20] master 17-10-29 23883
질문 초음파 센서를 이용한 dc모터 두개 작동입니다. 새글 비버 21-11-27 10
질문 아두이노 월 트레이싱 관련하여 질문드립니다. 새글 hiheel 21-11-27 11
질문 온도센서 4자리 세븐세그먼트 새글 초보코딩자 21-11-27 7
질문 아두이노 진동모터 새글 공머생 21-11-27 9
질문 블루투스 연결 질문입니다.댓글[4] 이미지새글첨부파일 ASAP 21-11-26 24
질문 로드셀을 이용한 모터 제어입니다댓글[1] 새글 정욱스 21-11-26 20
질문 LCD패널 질문댓글[1] 새글 초보코딩자 21-11-26 14
질문 관리자님 저 이전에 쓴글 질문입니다.댓글[1] 새글 호호미 21-11-26 21
질문 스마트 쓰레기통 코딩 문제-3댓글[1] 이미지새글 찬영 21-11-26 17
질문 atmeg 128댓글[1] 새글 초보오 21-11-26 20
질문 스마트 쓰레기통 코딩 문제-2댓글[4] 이미지새글 찬영 21-11-26 20
질문 아두이노 스텝모터 제어 새글 지방대 21-11-26 18
질문 스마트 쓰레기통 코딩 문제댓글[3] 새글 찬영 21-11-26 15
질문 초음파센서 코딩문제댓글[3] 이미지새글첨부파일 민준싸 21-11-26 29
질문 온도센서와 7세그먼트 연결 질문이요..댓글[1] 초보코딩자 21-11-26 16
질문 IRremote, Servo 라이브러리 충돌?문제댓글[3] 댜야자뱌냌 21-11-25 17
질문 전압 충돌댓글[2] 이미지첨부파일 비버 21-11-25 22
질문 아두이노 PIR센서와 온습도센서 DC모터댓글[4] 코딩처음초보 21-11-25 40
질문 아두이노 spi통신 고수님들 도움 부탁드립니다.댓글[2] 이미지첨부파일 hienvd 21-11-25 28
질문 버튼 스위치와 모터 연결 코딩댓글[4] 이미지첨부파일 wpdi123 21-11-25 32
질문 [재업로드]댓글[1] 민예진 21-11-25 19
질문 아두이노 전자시계 만들기 도와주세요댓글[4] yizhide 21-11-25 30
질문 이거 tinker cad로 가능할까요?댓글[1] 비버 21-11-24 29
질문 아두이노 컴파일 에러 도와주세요 ㅠㅠ댓글[1] 분위기파주방장 21-11-24 28
질문 아두이노에서 if문을 이용해 무한 동작 중 키보드 나 블루투스 입력을 통해 탈출할 수 있는 방법좀 알려주세요댓글[4] 아두이노잘하고싶다 21-11-24 34
질문 아두이노 fsr센서 워터펌프 작동관련해서 궁금해서요..댓글[3] TTTp 21-11-24 43
질문 초음파센서 2개를 이용하여 스텝모터2개 제어댓글[4] 동현킴 21-11-24 50
질문 아두이노 와이파이 사용 질문입니다.댓글[2] 이미지첨부파일 호호미 21-11-24 30
