질문게시판 > 아두이노 Rfid 멀티미더제어
TODAY304 TOTAL1,939,462
BASIC4MCU | 질문게시판 | 아두이노 Rfid 멀티미더제어
작성자 지방대 작성일2021-11-22 17:36 조회36회 댓글1건
안녕하세요 ?  아두이노 라이브러리에 MFRC 522   멀티 리더기 예제를 사용해서
1) 태그가 리더0번에 찍히면  >> 7핀이 high , 6핀이 low
2) 태그가 리더1번에 찍히면 >> 6핀이 high, 7번핀이 low 이렇게 구현하고 싶은데 작동이 되지 않습니다.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS 1    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI SS 2    SDA(SS)      ** custom, take a unused pin, only HIGH/LOW required **
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_1_PIN        10         // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
#define SS_2_PIN        8          // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define NR_OF_READERS   2
byte ssPins[] = {SS_1_PIN, SS_2_PIN};
MFRC522 mfrc522[NR_OF_READERS];   // Create MFRC522 instance.
 * Initialize.
  Serial.begin(9600); // Initialize serial communications with the PC
  while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
pinMode(7,OUTPUT);
pinMode(6,OUTPUT);
  SPI.begin();        // Init SPI bus
  for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
    mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
    Serial.print(F("Reader "));
    Serial.print(reader);
    Serial.print(F(": "));
    mfrc522[reader].PCD_DumpVersionToSerial();
 * Main loop.
    // Look for new cards
    if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
      // Show some details of the PICC (that is: the tag/card)
      //Serial.print(F(": Card UID:"));
      dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
      Serial.println();
      //Serial.print(F("PICC type: "));
      MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
      Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
      // Halt PICC
      mfrc522[reader].PICC_HaltA();
      // Stop encryption on PCD
      mfrc522[reader].PCD_StopCrypto1();
    } //if (mfrc522[reader].PICC_IsNewC
  } //for(uint8_t reader
char State = Serial.read();
if (State == '0'){
digitalWrite(7, HIGH);
digitalWrite(6, LOW);
}else if (State=='1'){
digitalWrite(6, HIGH);
digitalWrite(7, LOW);
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
  for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer[i] < 0x10 ? " 0" : " ");
    Serial.print(buffer[i], DEC);
조회수 36
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 4181
공지 사이트 이용 안내댓글[20] master 17-10-29 23884
질문 초음파 센서를 이용한 dc모터 두개 작동입니다. 새글 비버 21-11-27 11
질문 아두이노 월 트레이싱 관련하여 질문드립니다. 새글 hiheel 21-11-27 11
질문 온도센서 4자리 세븐세그먼트 새글 초보코딩자 21-11-27 7
질문 아두이노 진동모터 새글 공머생 21-11-27 10
질문 블루투스 연결 질문입니다.댓글[4] 이미지새글첨부파일 ASAP 21-11-26 24
질문 로드셀을 이용한 모터 제어입니다댓글[1] 새글 정욱스 21-11-26 20
질문 LCD패널 질문댓글[1] 새글 초보코딩자 21-11-26 14
질문 관리자님 저 이전에 쓴글 질문입니다.댓글[1] 새글 호호미 21-11-26 21
질문 스마트 쓰레기통 코딩 문제-3댓글[1] 이미지새글 찬영 21-11-26 17
질문 atmeg 128댓글[1] 새글 초보오 21-11-26 21
질문 스마트 쓰레기통 코딩 문제-2댓글[4] 이미지새글 찬영 21-11-26 21
질문 아두이노 스텝모터 제어 새글 지방대 21-11-26 18
질문 스마트 쓰레기통 코딩 문제댓글[3] 새글 찬영 21-11-26 15
질문 초음파센서 코딩문제댓글[3] 이미지새글첨부파일 민준싸 21-11-26 30
질문 온도센서와 7세그먼트 연결 질문이요..댓글[1] 초보코딩자 21-11-26 16
질문 IRremote, Servo 라이브러리 충돌?문제댓글[3] 댜야자뱌냌 21-11-25 17
질문 전압 충돌댓글[2] 이미지첨부파일 비버 21-11-25 22
질문 아두이노 PIR센서와 온습도센서 DC모터댓글[4] 코딩처음초보 21-11-25 40
질문 아두이노 spi통신 고수님들 도움 부탁드립니다.댓글[2] 이미지첨부파일 hienvd 21-11-25 28
질문 버튼 스위치와 모터 연결 코딩댓글[4] 이미지첨부파일 wpdi123 21-11-25 32
질문 [재업로드]댓글[1] 민예진 21-11-25 21
질문 아두이노 전자시계 만들기 도와주세요댓글[4] yizhide 21-11-25 30
질문 이거 tinker cad로 가능할까요?댓글[1] 비버 21-11-24 30
질문 아두이노 컴파일 에러 도와주세요 ㅠㅠ댓글[1] 분위기파주방장 21-11-24 30
질문 아두이노에서 if문을 이용해 무한 동작 중 키보드 나 블루투스 입력을 통해 탈출할 수 있는 방법좀 알려주세요댓글[4] 아두이노잘하고싶다 21-11-24 34
질문 아두이노 fsr센서 워터펌프 작동관련해서 궁금해서요..댓글[3] TTTp 21-11-24 43
질문 초음파센서 2개를 이용하여 스텝모터2개 제어댓글[4] 동현킴 21-11-24 50
질문 아두이노 와이파이 사용 질문입니다.댓글[2] 이미지첨부파일 호호미 21-11-24 31
