질문게시판 > 초음파센서 2개를 이용하여 스텝모터2개 제어
TODAY253 TOTAL1,939,411
BASIC4MCU | 질문게시판 | 초음파센서 2개를 이용하여 스텝모터2개 제어
작성자 동현킴 작성일2021-11-24 16:23 조회49회 댓글4건
초음파센서 2개를 이용해서 특정거리이하가 측정되면 스텝모터를 순서대로 제어하는 코딩을 하여 해봤는데 초음파센서도 측정이 안되고 모터도 안돌아갑니다..
아래는 코딩입니다
#include <AccelStepper.h>
#define FULLSTEP 4
#define HALFSTEP 8
#define echo_Pin1 12
#define trig_Pin1 13
#define echo_Pin2 6
#define trig_Pin2 7
long duration, sensor1val, sensor2val;
int distance;
int steps = 2048;
AccelStepper stepper1(FULLSTEP, 11,9,10,8);
AccelStepper stepper2(FULLSTEP, 5,3,4,2);
  // put your setup code here, to run once
 pinMode(trig_Pin1, OUTPUT);
 pinMode(echo_Pin1, INPUT);
 pinMode(trig_Pin2, OUTPUT);
 pinMode(echo_Pin2, INPUT);
 stepper1.setMaxSpeed(1000);
 stepper2.setMaxSpeed(1000);
 stepper1.setAcceleration(50);
 stepper2.setAcceleration(50);
 stepper1.setSpeed(200);
 stepper2.setSpeed(200);
 stepper2.moveTo(2048);
  driveSensor(trig_Pin1, echo_Pin2);
  sensor1val = distance;
  driveSensor(trig_Pin2, echo_Pin2);
  sensor2val = distance;
  Serial.print("sensor1 = ");
  Serial.print(sensor1val);
  Serial.println(" cm");
  Serial.print("sensor2 =  ");
  Serial.print(sensor2val);
  Serial.println("");
void driveSensor(int trig_Pin,int echo_Pin) {
 digitalWrite(trig_Pin, LOW);
 digitalWrite(echo_Pin, LOW);
 delayMicroseconds(2);
 digitalWrite(trig_Pin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echo_Pin,HIGH);
 distance = (duration/2)/29.4;
 if(distance<20){
  if(stepper1.distanceToGo() == 0)
   stepper1.moveTo(-stepper1.currentPosition());
   if(stepper2.distanceToGo() == 0)
    stepper2.moveTo(-stepper2.currentPosition());
  stepper1.run();
  delay(5000);
  stepper2.run();
 }else{
댓글 4
조회수 49
초음파센서 2개를 이용해서
#define FULLSTEP  4
#define HALFSTEP  8
#define echo_Pin2 6
#define trig_Pin2 7
long duration,sensor1val,sensor2val;
int distance;
int steps=2048;
AccelStepper stepper1(FULLSTEP,11,9,10,8);
AccelStepper stepper2(FULLSTEP,5,3,4,2);
  pinMode(trig_Pin1,OUTPUT); pinMode(echo_Pin1,INPUT);
  pinMode(trig_Pin2,OUTPUT); pinMode(echo_Pin2,INPUT);
  stepper1.setMaxSpeed(1000); stepper1.setAcceleration(50); stepper1.setSpeed(200); stepper1.moveTo(2048);
  stepper2.setMaxSpeed(1000); stepper2.setAcceleration(50); stepper2.setSpeed(200); stepper2.moveTo(2048);
  driveSensor(trig_Pin1,echo_Pin2); sensor1val=distance;
  driveSensor(trig_Pin2,echo_Pin2); sensor2val=distance;
  Serial.print("sensor1="); Serial.print(sensor1val); Serial.println(" cm");
  Serial.print("sensor2="); Serial.print(sensor2val); Serial.println(" cm");
  Serial.println("");
  digitalWrite(trig_Pin,1); delayMicroseconds(10); digitalWrite(trig_Pin,0);
  duration=pulseIn(echo_Pin,HIGH);
  distance=(duration/2)/29.4;
  if(distance<20){
    if(stepper1.distanceToGo()==0)stepper1.moveTo(-stepper1.currentPosition());
    if(stepper2.distanceToGo()==0)stepper2.moveTo(-stepper2.currentPosition());
    stepper1.run(); delay(5000); stepper2.run();
동작이 안되면
초음파센서 예제만으로 구동하고, 초음파센서 2개로 변경해서 구동
모터 예제만으로 구동하고
이상없으면 합쳐서 만드세요
스텝모터는 전류 소모가 커서 전류용량이 충분한 전원을 사용해야 합니다.
동현킴님의 댓글
동현킴 댓글의 댓글 작성일
9V전지로는 스텝모터2개, 초음파센서 작동이 안될까요?
스텝모터 1개도 9V 배터리 여러개를 병렬로 연결해야 할텐데요?
수A 이상의 전류용량을 가진 SMPS를 사용하도록 하세요
동현킴님의 댓글
동현킴 작성일
감사합니다~
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 4181
공지 사이트 이용 안내댓글[20] master 17-10-29 23881
질문 초음파 센서를 이용한 dc모터 두개 작동입니다. 새글 비버 21-11-27 10
질문 아두이노 월 트레이싱 관련하여 질문드립니다. 새글 hiheel 21-11-27 11
질문 온도센서 4자리 세븐세그먼트 새글 초보코딩자 21-11-27 7
질문 아두이노 진동모터 새글 공머생 21-11-27 9
질문 블루투스 연결 질문입니다.댓글[4] 이미지새글첨부파일 ASAP 21-11-26 24
질문 로드셀을 이용한 모터 제어입니다댓글[1] 새글 정욱스 21-11-26 20
질문 LCD패널 질문댓글[1] 새글 초보코딩자 21-11-26 14
질문 관리자님 저 이전에 쓴글 질문입니다.댓글[1] 새글 호호미 21-11-26 21
질문 스마트 쓰레기통 코딩 문제-3댓글[1] 이미지새글 찬영 21-11-26 17
질문 atmeg 128댓글[1] 새글 초보오 21-11-26 20
질문 스마트 쓰레기통 코딩 문제-2댓글[4] 이미지새글 찬영 21-11-26 20
질문 아두이노 스텝모터 제어 새글 지방대 21-11-26 18
질문 스마트 쓰레기통 코딩 문제댓글[3] 새글 찬영 21-11-26 15
질문 초음파센서 코딩문제댓글[3] 이미지새글첨부파일 민준싸 21-11-26 29
질문 온도센서와 7세그먼트 연결 질문이요..댓글[1] 초보코딩자 21-11-26 15
질문 IRremote, Servo 라이브러리 충돌?문제댓글[3] 댜야자뱌냌 21-11-25 16
질문 전압 충돌댓글[2] 이미지첨부파일 비버 21-11-25 21
질문 아두이노 PIR센서와 온습도센서 DC모터댓글[4] 코딩처음초보 21-11-25 38
질문 아두이노 spi통신 고수님들 도움 부탁드립니다.댓글[2] 이미지첨부파일 hienvd 21-11-25 28
질문 버튼 스위치와 모터 연결 코딩댓글[4] 이미지첨부파일 wpdi123 21-11-25 32
질문 [재업로드]댓글[1] 민예진 21-11-25 19
질문 아두이노 전자시계 만들기 도와주세요댓글[4] yizhide 21-11-25 30
질문 이거 tinker cad로 가능할까요?댓글[1] 비버 21-11-24 29
질문 아두이노 컴파일 에러 도와주세요 ㅠㅠ댓글[1] 분위기파주방장 21-11-24 28
질문 아두이노에서 if문을 이용해 무한 동작 중 키보드 나 블루투스 입력을 통해 탈출할 수 있는 방법좀 알려주세요댓글[4] 아두이노잘하고싶다 21-11-24 34
질문 아두이노 fsr센서 워터펌프 작동관련해서 궁금해서요..댓글[3] TTTp 21-11-24 43
현재글 초음파센서 2개를 이용하여 스텝모터2개 제어댓글[4] 동현킴 21-11-24 50
질문 아두이노 와이파이 사용 질문입니다.댓글[2] 이미지첨부파일 호호미 21-11-24 30
