질문게시판 > 아두이노 lcd표시문제
TODAY1,227 TOTAL2,922,663
BASIC4MCU | 질문게시판 | 아두이노 lcd표시문제
작성자 아두이노공부해요 작성일2021-12-10 14:38 조회14,036회 댓글4건
오픈웨더맵에서 위도경도를 넣고 그 지역의 pm10값이랑 pm25값을 찾아서 수치를 lcd에 나타내야하는데 수치뿐아니라 문자까지 나타내서 숫자만 나타나게 하던가 중간에 짜르는건 어떻게 하나요?
pm25: (수치) um/m3
pm10: (수치) um/m3
------------------------------------------------------     이렇게 표시하고싶어요
lcd에 표시되는 사진이랑 api로 불러들인 자료사진도 첨부했습니다
코드입니다
#include "WizFi250.h"
#include <SPI.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);  // I2C LCD
char ssid[] = "NEXT-2204N PLUS";    // your network SSID (name)
char pass[] = "39853985";          // your network password
int status = WL_IDLE_STATUS;       // the Wifi radio's status
//Ubidots information
#define lat     "35.19" //위도
#define ion     "128.1" //경도
#define appid   "564900d0968f0885f60f9b7e68482c74"
//Hardware Pin status
char server[] = "api.openweathermap.org";
boolean readingVal;
boolean readingVal1;
boolean viewData;
boolean getIsConnected = false;
String pm25;
String pm10;
String rcvbuf;
// Initialize the Ethernet client object
WiFiClient client;
void httpRequest();
void printWifiStatus();
  // initialize serial for debugging
  Serial.begin(115200);
  Serial.println(F("\r\nSerial Init"));
  pinMode(7, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  pinMode(5, OUTPUT);
  lcd.init();
  lcd.backlight();
  lcd.print(" pm Info System ");
  lcd.setCursor(0, 1);
  lcd.print(" pm10, pm25 ");
  WiFi.init();
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  Serial.println("You're connected to the network");
  printWifiStatus();
  // if there's incoming data from the net connection send it out the serial port
  // this is for debugging purposes only
  while (client.available()) {
    digitalWrite(5,HIGH); //led on
    char c = client.read();
    if ( c != NULL ) {
      if (rcvbuf.length() > 80)
        rcvbuf = "";
      rcvbuf += c;
      Serial.write(c);
       if (rcvbuf.endsWith("\"pm2_5\":")) {
        readingVal = true;
        pm25= "";
      else if (rcvbuf.endsWith("\"pm10\":")) {
        readingVal1 = true;
        pm10= "";
      if (readingVal)
        dataParser(c, pm25, readingVal);
      else if (readingVal1)
        dataParser(c, pm10, readingVal1);
    digitalWrite(5,LOW);  //LED OFF
  //if (millis() - lastConnectionTime > postingInterval) {
  if (!digitalRead(7)) {
    httpRequest();
  if (!digitalRead(6)) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print(" Daejeon ");
    lcd.print(" pm25 pm10 info ");
    delay(5000);
    lcd.clear();
    lcd.print("pm25:");
    lcd.print(pm25);
    lcd.print("ug/m3 ");
    lcd.print("pm10:");
    lcd.print(pm10);
    delay(5000);
  rcvbuf = "";
// this method makes a HTTP connection to the server
void httpRequest() {
  Serial.println();
  // close any connection before send a new request
  // this will free the socket on the WiFi shield
  client.stop();
  // if there's a successful connection
  if (client.connect(server, 80)) {
    Serial.println("Connecting...");
    // send the HTTP PUT request
    client.print(F("GET /data/2.5/air_pollution?lat="));
    client.print(lat);
    client.print(F("&lon="));
    client.print(ion);
    client.print(F("&appid="));
    client.print(appid);
    client.print(F(" HTTP/1.1\r\n"));
    client.print(F("Host: api.openweathermap.org\r\n"));
    client.print(F("Connection: close\r\n"));
    client.print(F("\r\n\r\n"));
  else {
    // if you couldn't make a connection
    Serial.println("Connection failed");
void printWifiStatus() {
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
void dataParser(char c, String &data, boolean &b) {
  if (c != '<') {
    if (c != '>')
      data += c;
  else {
    b = false;
댓글 4
조회수 14,036
void parsing() {
  String announce_time; int tm_start= line0.indexOf(F("<tm>")); // "<tm>"문자가 시작되는 인덱스 값('<'의 인덱스)을 반환한다.
  int tm_end= line0.indexOf(F("</tm>"));
  announce_time = line0.substring(tm_start + 4, tm_end); // +4: "<tm>"스트링의 크기 4바이트, 4칸 이동
https://postpop.tistory.com/86
위 링크를 보면 문자열과 문자열 사이의 문자를 파싱하는 예가 있습니다.
만약 컴마 전까지 파싱하고 싶다면
  int tm_end= line0.indexOf(F(","));
이렇게 변경하면 되겠죠
아두이노공부해요님의 댓글
아두이노공부해요 댓글의 댓글 작성일
글을 늦게봐서 답변을 늦게 달았습니다.
블로그도 보고 저 line0 부분을 pm25로 바꾸고 해도 잘되지않아 어떻게 고쳐야 하는지 자세히 알려주실수 있을까요?
void parsing() {
  String pm25; int tm_start= pm25.indexOf(F("\"pm2_5\":"));
  int tm_end= pm25.indexOf(F(","));
  String pm10; int hour_start= pm10.indexOf(F("\"pm10\":"));
  int hour_end= pm10.indexOf(F(",")); }
고치기는 이렇게 고쳐봤습니다만...
동일한 경험이 없어서 조언을 드리지 못합니다.
보통 코드를 완전히 이해하면 수정이나 디버깅을 할 수 있게 됩니다.
아두이노공부해요님의 댓글
아두이노공부해요 댓글의 댓글 작성일
알겠습니다 제가 아직 초보라 조금더 천천히 보면서 공부해보겠습니다. 알려주셔서 감사합니다
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 121
질문 아두이노 lcd 디지털시계 (도와주시면 감사하겠습니다!)댓글[1] 이미지첨부파일 김리 23-06-11 550
질문 아두이노 LCD 글자 출력질문입니다. Tell 23-06-10 475
답변 답변글 답변 : 아두이노 LCD 글자 출력질문입니다. master 23-06-10 436
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 451
답변 답변글 답변 : 아두이노 lcd 문자 스크롤디스플레이댓글[1] master 23-05-31 507
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 867
질문 토양습도센서 이용시LCD 오류댓글[5] 윤던 23-05-23 990
질문 LCD 부저연결질문입니다.댓글[1] Tell 23-05-19 440
질문 세그먼트 lcd출력질문입니다.댓글[1] Tell 23-05-19 439
질문 lcd 화면에 글자가 안보이네요댓글[7] 이미지 황룡수색 23-05-19 1521
질문 lcd 모니터를 내려서 표기하댓글[5] 수포자 23-04-06 1546
질문 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F) 이미지 JCHJ 22-12-15 1431
답변 답변글 답변 : 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F)댓글[2] master 22-12-15 3061
질문 아두이노 심박센서 및 LCD로 BPM나타내기 질문있습니다.댓글[2] 이미지첨부파일 공백 22-12-12 2589
질문 (MCU) LCD와 인터럭트궁금한 부분이있어 질문드립니다댓글[1] 권철숙 22-12-03 1048
질문 ATMEGA128 가변저항을 이용해 값을 LCD로 받고싶습니다.댓글[1] 납땜마스터 22-12-01 1918
질문 Atmega128 가변저항을 이용해 lcd에 설정값 띄우기 납땜마스터 22-12-01 1612
답변 답변글 답변 : Atmega128 가변저항을 이용해 lcd에 설정값 띄우기 master 22-12-01 1959
질문 USART를 이용한 LCD출력댓글[2] 이름두글자 22-11-29 1956
질문 stm32 tft(LCD) ILI9341 문제점 조언댓글[3] 첨부파일 지산동괴물쥐 22-11-26 3478
질문 LED, LCD, 버튼, 부저 0922tjdus 22-11-24 2442
답변 답변글 답변 : LED, LCD, 버튼, 부저 master 22-11-24 1698
질문 아두이노 우노 압력센서 LCD 코딩 문제댓글[16] 이미지첨부파일 또혀이 22-11-18 29175
답변 답변글 답변 : 아두이노 우노 압력센서 LCD 코딩 문제 이미지 master 22-11-19 1987
질문 인터럽트 활성화시 LCD 오류 발생 마프하나 22-11-16 1846
답변 답변글 답변 : 인터럽트 활성화시 LCD 오류 발생 master 22-11-17 1438
질문 3x4 키패드를 이용한 LCD 계산기 코딩 질문입니다.댓글[1] 첨부파일 LCDnoob 22-11-16 2904
질문 Lcd실드 모듈 연결해서 lcd만 사용할 수 있나요?댓글[2] 이미지첨부파일 떼잉 22-11-13 2651
질문 아두이노 lcd 오류 질문댓글[2] 이미지첨부파일 아두이노진구 22-11-11 3173
