질문게시판 > 답변 2: 안녕하세요 아두이노 질문 추가입니다
TODAY1,405 TOTAL2,575,960
BASIC4MCU | 질문게시판 | 답변 2: 안녕하세요 아두이노 질문 추가입니다
작성자 master 작성일2018-06-12 17:19 조회7,596회 댓글0건
// DateTime : 2018-06-12 오후 5:21:15
#include <MsTimer2.h>
//#define PWM 180
#define bSW_DN     2 // 4.7k=10k 대체,capacitor x
#define bSW_UP     3
#define wSW_CLOSE  4
#define wSW_OPEN   5
// SW
#define bM_B       6 //  ic2 // 블라인드용
#define bM_A       7 //  7
#define bM_EN      8 //  1
#define wM_D       9 // 10 // 창문용
#define wM_C      10 // 14
#define wM_EN     11 //  9
//MOTER
#define CDS       A0 // 아래쪽이 블라인드
#define Rain      A1 // 윗쪽이 창문
#define STOP       0
#define UP         1
#define DN         2
#define OPEN       1
#define CLOSE      2
int bM_DIR=STOP,bTimer=0,bMode=0;
int wM_DIR=STOP,wTimer=0,wMode=0;
bool old_cds =0;
bool old_Rain=0;
void bM_STOP() { digitalWrite(bM_EN,0); } // blind
void bM_LEFT() { digitalWrite(bM_EN,1); digitalWrite(bM_A,1); digitalWrite(bM_B,0); }
void bM_RIGHT(){ digitalWrite(bM_EN,1); digitalWrite(bM_A,0); digitalWrite(bM_B,1); }
void bM_RUN()  {
  switch(bM_DIR){
    case STOPbMode=0bM_STOP(); break;
    case DN  : if(bMode!=1){ bTimer=10bM_LEFT();  } bMode=1break;
    case UP  : if(bMode!=2){ bTimer=10bM_RIGHT(); } bMode=2break;
void wM_STOP() { digitalWrite(wM_EN,0); } // window
void wM_LEFT() { digitalWrite(wM_EN,1); digitalWrite(wM_C,1); digitalWrite(wM_D,0); }
void wM_RIGHT(){ digitalWrite(wM_EN,1); digitalWrite(wM_C,0); digitalWrite(wM_D,1); }
void wM_RUN()  {
  switch(wM_DIR){
    case STOP : wMode=0wM_STOP(); break;
    case CLOSEif(wMode!=1){ wTimer=25wM_LEFT();  } wMode=1break;
    case OPEN : if(wMode!=2){ wTimer=25wM_RIGHT(); } wMode=2break;
void BTS(){ //  BLUETOOTH
  if(Serial.available()){
    char r=Serial.read();
    if(r=='0'){ bM_DIR=STOP;  } // motor turn off
    if(r=='1'){ bM_DIR=DN;    } // motor turn right
    if(r=='2'){ bM_DIR=UP;    }
    if(r=='3'){ wM_DIR=STOP;  } // motor turn off
    if(r=='4'){ wM_DIR=CLOSE; }
    if(r=='5'){ wM_DIR=OPEN;  }
void cds_run(){
  int cds_val=analogRead(CDS); cds_val/=750// 750 is 0 or 1 value
  if(old_cds!=cds_val){
    if(cds_val)bM_DIR=DN;
    else       bM_DIR=UP;
  old_cds=cds_val;
void Rain_run(){ // Rain window
  int Rain_val=analogRead(Rain); Rain_val/=600// 600 is 0 or 1 value
  if(old_Rain!=Rain_val){
    if(Rain_val)wM_DIR=CLOSE;
    else        wM_DIR=OPEN;
  old_Rain=Rain_val;
void ISR_Timer(){
  if(wTimer){
    if(--wTimer==0){ bM_DIR=STOPbM_STOP(); } //window
  if(bTimer){
    if(--bTimer==0){ wM_DIR=STOPwM_STOP(); } //blind
  pinMode(bM_EN,OUTPUT); pinMode(bM_A,OUTPUT); pinMode(bM_B,OUTPUT);
  pinMode(wM_EN,OUTPUT); pinMode(wM_C,OUTPUT); pinMode(wM_D,OUTPUT);
  MsTimer2::set(100,ISR_Timer); // 100ms,ISR_Timer
  MsTimer2::start();            // Timer start
  if(!digitalRead(bSW_DN   ))bM_DIR=DN;
  if(!digitalRead(bSW_UP   ))bM_DIR=UP;
  if(!digitalRead(wSW_CLOSE))wM_DIR=CLOSE;
  if(!digitalRead(wSW_OPEN ))wM_DIR=OPEN;
  BTS(); bM_RUN(); wM_RUN();
  if((!bMode)&&(!wMode)){ cds_run(); Rain_run(); } // 모터 정지 시 입력체크
변환하면서 버그가 있을 수도 있지만
일단은 코드 크기를 줄였습니다.
조회수 7,596
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 16905
공지 사이트 이용 안내댓글[28] master 17-10-29 33507
질문 아두이노 제어하기댓글[1] 새글 매드닥터 23-03-19 17
질문 atmega128 압력센서 관련 질문입니다댓글[1] 새글 공린이 23-03-19 21
질문 아두이노 스텝모터 각도제어 질문 master 23-03-17 24
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 23
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 20
질문 ATmega328p로 pca9685를 이용하여 서보모터(mg996r, mg90s)를 pwm로 제어 중 떨림댓글[1] 이미지첨부파일 토비 23-03-15 31
질문 hm-10 다중연결 질문있습니다.댓글[1] 첨부파일 뉴비에오 23-03-14 28
질문 while loop 실행 속도댓글[1] 412904 23-03-12 46
질문 AND 연산 질문드립니다.댓글[1] 412904 23-03-11 50
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 124
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 90
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 112
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 66
질문 220V AC를 직류로 바꾸면 건전지 5V 건전지 55개를 대체할 수 있는건가요?댓글[1] hghh 23-02-22 83
질문 HM-10 모듈 사용하는데 질문있습니다.댓글[2] 뉴비에오 23-02-21 107
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 84
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 86
질문 자율주행 로봇을 만드는데 질문있습니다.댓글[2] 뉴비에오 23-02-18 127
질문 블루투스에서 아두이노로 신호전달에 대하여(2)댓글[1] 이미지첨부파일 밍경 23-02-14 167
질문 블루투스에서 아두이노로 신호전달에 대하여 밍경 23-02-13 127
답변 답변글 답변 : 블루투스에서 아두이노로 신호전달에 대하여 master 23-02-14 111
질문 아두이노 코드 에러관련 질문.댓글[1] 영다니 23-02-09 145
질문 가스 센서를 쓰려면댓글[3] 테스터 23-02-08 228
질문 ATmega328p + pca9685 + 서보모터 토비 23-02-08 140
답변 답변글 답변 : ATmega328p + pca9685 + 서보모터댓글[2] master 23-02-08 199
질문 아두이노 LED 시간 제어가 안됩니다.댓글[3] 고양이33 23-02-08 301
질문 Ozone 2 click 센서를 쓰려고하는데댓글[1] 라칸 23-02-07 148
질문 님들 stm32 spi를 사용할떄댓글[1] 이미지 라칸 23-02-06 129
