질문게시판 > 모터
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
모터
작성자 룰루 작성일21-12-24 09:26 조회1,286회 댓글3건
#define kilo 1000UL
#define Mega (kilo*kilo)
#define F_CPU 16*Mega
#define ST0P  0
#define GO    1
#define MODE1 0
#define MODE2 1
#define MODE3 2
#define NULL 0
void current_motor(void);
void current_sw(void);
void mcu_timer2_fPWM(void);
//void mcu_timer0_ctc(void);
void mcu_exinterrupt_switch(void);
void chattering(char);
struct op
  volatile uint8_t state;
  volatile uint8_t mode_sel;
  uint8_t array_ocr2[];
  //struct op *next;
}motor_op =
 ST0P,
 MODE3,  //after reset "MODE3" trans to "MODE1" by INT4
 { 76,156,220 } //TCNT2(256),30%,60%,90%
int main()
  current_motor();
  current_sw();
  mcu_timer2_fPWM();
  mcu_exinterrupt_switch();
  struct op *ptr = &motor_op;
  DDRA = 0xff;
  if(ptr->state)
      switch(ptr->mode_sel)
      case MODE1:  OCR2 = ptr->array_ocr2[0]; PORTA=0x10;  break;
      case MODE2:  OCR2 = ptr->array_ocr2[1]; PORTA=0x20;  break;
      case MODE3:  OCR2 = ptr->array_ocr2[2]; PORTA=0x40;  break;
  }else  {
    PORTA ^= 0x01;
    _delay_ms(100);
  DDRB = (1<<DDB6)|(0<DDB7); //for use OC2 (1<<DDB7)  //enabled by ISR(INT4_vect).
TCCR2 = (1<<WGM21)|(1<<WGM20)|(1<<COM21)|(0<<COM20)|(1<<CS22)|(0<<CS21)|(1<<CS20); //OC2: enable (COM21:0 =2)
        //(fast mode)        ( clear:up, set:down)  (clock : 1024) = small motor didn't respond high frequency
/*--OCF2-------*/
//TIMSK = (1<<OCR2);  //timer2: compare match interrupt enable. //ISR(TIMER2_COMP_VECT) : enable.
/*--ISR OCF2-------*/
ISR(TIMER2_COMP_vect)
  /*none*/
  DDRE = 0xff;
  DDRE ^= (1<<DDE4)|(1<<DDE5);  //default: 0  //use for INT4,5 port pin function enable.
 EIMSK = (1<<INT4)|(1<<INT5);  // INT4,5 enable.
 EICRB = (1<<ISC41)|(0<<ISC40)|(1<<ISC51)|(0<<ISC50); //interrupt source collect, trigger: rising edge.
 sei();
void chattering(char num)
  EIFR= (1<<num);
  _delay_ms(30);
ISR(INT4_vect)
{                            // mode1 mode2 mode3
  static uint8_t trans_mode[3] = {MODE2,MODE3,MODE1};
  motor_op.mode_sel = trans_mode[motor_op.mode_sel];
                                  //stop  go
  static uint8_t trans_array[2] = { GO, GO };
  motor_op.state = trans_array[motor_op.state];
  DDRB |= 1<<DDB7; //motor: start. (DDR: connect OC2 signal)
  chattering(4);
ISR(INT5_vect)
{                                //mode 1 mode2 mode3
  static uint8_t trans_mode[3] = {MODE3,MODE3,MODE3};
                          // stop go
  static uint8_t tran_array[2] = {ST0P,ST0P};
  motor_op.state = tran_array[motor_op.state];
  DDRB &= 0<<DDB7; // motor: stop (DDR: cut OC2 signal)
  OCR2 = 0;
  chattering(5);
프로젝트 설명 :
SW1을 한 번 누르면 미풍, 두번 누르면 약풍, 세번 누르면 강풍, 네번 누르면 다시 미풍이 되며, SW2를 누르면 정지가 되는 모터를 작동하고 싶은데 작동이 안됩니다ㅠ 어디가 문제인가요...
  • 카카오톡으로 보내기
댓글 : 3
조회수 : 1,286
EICRB=(1<<ISC41)|(0<<ISC40)|(1<<ISC51)|(0<<ISC50);
이 설정은 상승엣지가 아니고 하강엣지입니다.
코드가 복잡해서 한번에 파악은 안되지만
각각의 인터럽트 및 PWM등은 하나씩 차근차근 제대로 코딩을 했는지 일일이 확인해야 합니다.
#define  F_CPU 16000000UL
volatile char mode=0;
ISR(INT4_vect){
  if(++mode>3)mode=1;
  if(mode==1){ OCR2= 76; PORTA=0x10; }
  if(mode==2){ OCR2=156; PORTA=0x20; }
  if(mode==3){ OCR2=220; PORTA=0x40; }
  _delay_ms(50); EIFR=0x30;
ISR(INT5_vect){ mode=0; OCR2=0; PORTA=0; }
int main(){
  DDRA=0xff; DDRB=0xC0;
  TCCR2=(1<<WGM21)|(1<<WGM20)|(1<<COM21)|(0<<COM20)|(1<<CS22)|(0<<CS21)|(1<<CS20);
  EICRB=0xAA; EIMSK=0x30; sei();
  while(1){}
룰루님의 댓글
룰루 댓글의 댓글작성일
이부분만 수정해도 되는 건가요??
BASIC4MCU > 질문게시판 목록
제목 날짜
PC버전
