질문게시판 > 아두이노 와이파이
인기검색어 > 아두이노 센서 ATMEGA128
최신글 질문게시판 동영상강좌 가입하기
▼ BASIC4MCU 후원업체 신제품 정보 ▼
▲ BASIC4MCU 후원업체 신제품 정보 ▲
BASIC4MCU > 질문게시판
아두이노 와이파이
작성자 비공개 작성일18-06-14 10:59 조회5,673회 댓글1건
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <TinyGPS.h>
Adafruit_MLX90614 mlx=Adafruit_MLX90614();
TinyGPS gps;
SoftwareSerial nss(3, 4);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
double Amb,Obj,AmbSum,ObjSum;
  Serial.begin(115200);
  nss.begin(9600);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println();
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println();
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  mlx.begin();
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  //gpsdump(gps);
  AmbSum=0; ObjSum=0;
    for(int i=0; i<10; i++){
    AmbSum+=mlx.readAmbientTempC();
    ObjSum+=mlx.readObjectTempC();
    Serial.print(i+1); Serial.print("\tAmbient="); Serial.print(Amb);
    Serial.print("*C\tObject="); Serial.print(Obj); Serial.println("*C");
  Amb=AmbSum/10;
  Obj=ObjSum/10;
  Serial.print("Ambient Avr.="); Serial.print(Amb);
  Serial.print("*C\tObject Avr.="); Serial.print(Obj); Serial.println("*C");
  Serial.println();
  delay(2000);
  if(Obj<28){
    gpsdump(gps);  // GPS 호출
    delay(2000);
    return;
//GPS 호출
static void print_str(const char *str, int len);
static void print_date(TinyGPS &gps);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
      float flat, flon;
      unsigned long age, date, time, chars = 0;
      unsigned short sentences = 0, failed = 0;
      static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
      print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
      print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
      gps.f_get_position(&flat, &flon, &age);
      print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
      print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
      print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
      print_date(gps);
      print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
      print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
      print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
      print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
      print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
      print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
      print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
      gps.stats(&chars, &sentences, &failed);
      print_int(chars, 0xFFFFFFFF, 6);
      print_int(sentences, 0xFFFFFFFF, 10);
      print_int(failed, 0xFFFFFFFF, 9);
      Serial.println();
      char sz[32];
      if (val == invalid)
       strcpy(sz, "*******");
       sprintf(sz, "%ld", val);
        sz[len] = 0;
      for (int i=strlen(sz); i<len; ++i)
        sz[i] = ' ';
      if (len > 0)
        sz[len-1] = ' ';
      Serial.print(sz);
      feedgps();
      char sz[32];
      if (val == invalid)
        sz[len] = 0;
        if (len > 0)
        sz[len-1] = ' ';
        for (int i=7; i<len; ++i)
        sz[i] = ' ';
        Serial.print(sz);
        Serial.print(val, prec);
        int vi = abs((int)val);
        int flen = prec + (val < 0.0 ? 2 : 1);
        flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
        for (int i=flen; i<len; ++i)
        Serial.print(" ");
      feedgps();
      int year;
      byte month, day, hour, minute, second, hundredths;
      unsigned long age;
      gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
      if (age == TinyGPS::GPS_INVALID_AGE)
        Serial.print("*******    *******    ");
      char sz[32];
      sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
          month, day, year, hour, minute, second);
      Serial.print(sz);
      feedgps();
      int slen = strlen(str);
      for (int i=0; i<len; ++i)
        Serial.print(i<slen ? str[i] : ' ');
      feedgps();
     while (nss.available())
       if (gps.encode(nss.read()))
       return true;
       return false;
GPS소스 대신에 WiFi소스를 넣고 싶은데 어디다가 삽입해야될지 알려주세요
  • 카카오톡으로 보내기
댓글 : 1
조회수 : 5,673
와이파이 예제를 공부하고
Adafruit_MLX90614 예제를 공부한 후에
합쳐서 만드세요
BASIC4MCU > 질문게시판 목록
제목 날짜
질문 앱인벤터 list index too large 오류 질… 첨부파일PT규 새글 22-07-07
질문 Atmega IO핀 출력 상태 질문이요.. 댓글[3] chelsea 새글 22-07-06
답변 답변 : Atmega IO핀 출력 상태 질문이요.. 댓글[6] master 새글 22-07-06
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통… 댓글[6] 첨부파일AutoSun  22-07-05
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니… 첨부파일뉴비에오  22-07-04
답변 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질… 댓글[2] master  22-07-05
질문 아두이노 Sensor Shield 5.0 시리얼 통신 … 댓글[2] AutoSun  22-07-04
질문 Atmega 코드 좀 봐주세요. 댓글[1] 첨부파일chelsea  22-07-04
PC버전
