질문게시판 > Tutorial on Using Arduino TFT LCD Touch Screen Module
TODAY813 TOTAL2,934,270
BASIC4MCU | 질문게시판 | Tutorial on Using Arduino TFT LCD Touch Screen Module
작성자 grey 작성일2022-03-27 12:31 조회9,672회 댓글0건
Step 1: Project Plan
In this tutorial, we use only simple Arduino TFT LCD hardware without a breadboard and any other components. No wiring is required. As follows.
1. 3.5-inch Arduino UNO TFT LCD touch screen module
2. USB cable type A male to B male
Our test code uses the Arduino IDE for Arduino 1.6.12 windows. if you are using an older version, please install Arduino UNO on your PC.
The IDE for the Arduino IDE may have compilation errors, so please use a newer version.
Download the library and paste it into the Arduino libraries folder (usually located in C: Users User Documents Arduino libraries).
Step 2: Pin Connections
Connect your Arduino 3.5-inch UNO TFT LCD touchscreen module in the following way. Make sure all pins fit into their ports.
Step 3: Insert The Code
Insert-the-code-1
Insert-the-code-2
Download the test code and open it up using the Arduino software or IDE.
Make sure the correct board and corresponding ports have been selected. (In this tutorial, the Arduino UNO is used)
Then, upload the test code to the Arduino UNO.
Step 4: Results
Once fully uploaded, you can start drawing on the Arduino TFT LCD screen in the color of your choice.
To clear the screen content, select the ” Ers” box to clear the screen.
조회수 9,672
질문 atmega128a 와 캐릭터 LCD연결 방법댓글[4] 까미 23-09-30 106
질문 타이머 인터럽트를 이용한 LCD제어 질문입니다. Tell 23-09-27 58
답변 답변글 답변 : 타이머 인터럽트를 이용한 LCD제어 질문입니다.댓글[3] master 23-09-28 82
질문 lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ댓글[1] 아두이노개발자 23-09-26 88
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 171
질문 아두이노 lcd 디지털시계 (도와주시면 감사하겠습니다!)댓글[1] 이미지첨부파일 김리 23-06-11 591
질문 아두이노 LCD 글자 출력질문입니다. Tell 23-06-10 510
답변 답변글 답변 : 아두이노 LCD 글자 출력질문입니다. master 23-06-10 495
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 495
답변 답변글 답변 : 아두이노 lcd 문자 스크롤디스플레이댓글[1] master 23-05-31 565
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 954
질문 토양습도센서 이용시LCD 오류댓글[5] 윤던 23-05-23 1078
질문 LCD 부저연결질문입니다.댓글[1] Tell 23-05-19 490
질문 세그먼트 lcd출력질문입니다.댓글[1] Tell 23-05-19 477
질문 lcd 화면에 글자가 안보이네요댓글[7] 이미지 황룡수색 23-05-19 1637
질문 lcd 모니터를 내려서 표기하댓글[5] 수포자 23-04-06 1656
질문 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F) 이미지 JCHJ 22-12-15 1490
답변 답변글 답변 : 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F)댓글[2] master 22-12-15 3248
질문 아두이노 심박센서 및 LCD로 BPM나타내기 질문있습니다.댓글[2] 이미지첨부파일 공백 22-12-12 2709
질문 (MCU) LCD와 인터럭트궁금한 부분이있어 질문드립니다댓글[1] 권철숙 22-12-03 1104
질문 ATMEGA128 가변저항을 이용해 값을 LCD로 받고싶습니다.댓글[1] 납땜마스터 22-12-01 2010
질문 Atmega128 가변저항을 이용해 lcd에 설정값 띄우기 납땜마스터 22-12-01 1660
답변 답변글 답변 : Atmega128 가변저항을 이용해 lcd에 설정값 띄우기 master 22-12-01 2035
질문 USART를 이용한 LCD출력댓글[2] 이름두글자 22-11-29 2046
질문 stm32 tft(LCD) ILI9341 문제점 조언댓글[3] 첨부파일 지산동괴물쥐 22-11-26 3597
질문 LED, LCD, 버튼, 부저 0922tjdus 22-11-24 2540
답변 답변글 답변 : LED, LCD, 버튼, 부저 master 22-11-24 1760
질문 아두이노 우노 압력센서 LCD 코딩 문제댓글[16] 이미지첨부파일 또혀이 22-11-18 30471
답변 답변글 답변 : 아두이노 우노 압력센서 LCD 코딩 문제 이미지 master 22-11-19 2073
질문 인터럽트 활성화시 LCD 오류 발생 마프하나 22-11-16 1887
