답변 : 아두이노 SimpleDHT LiquidCrystal_I2C
작성자 master 작성일18-06-18 17:19 조회5,520회 댓글0건본문
// DateTime : 2018-06-18 오후 5:22:41
#include <SimpleDHT.h>
SimpleDHT11 dht11;
LiquidCrystal_I2C lcd(0x3F,16,2);
int flame=A0;
int Beep =8; // 피에조부저
int pinDHT11=2;
int ledPin1=11; // 1번 LED
int ledPin2=10; // 2번 LED
int PIRsensor=9; // 센서 신호핀
int val=0,pirState=0;
pinMode(ledPin1,OUTPUT); pinMode(ledPin2,OUTPUT); // LED
pinMode(Beep,OUTPUT);
lcd.init(); lcd.backlight();
val=digitalRead(PIRsensor); Serial.print("PIR="); Serial.println(val); // PIR
if(val){ // 센서 신호값이 HIGH면(인체 감지가 되면)
if(pirState==LOW){
digitalWrite(ledPin1,HIGH); digitalWrite(ledPin2,LOW);
pirState=HIGH; Serial.println("Welcome!");
else{ // 인체감지가 없으면
if(pirState==HIGH){
digitalWrite(ledPin1,LOW); digitalWrite(ledPin2,HIGH);
pirState=LOW; Serial.println("Good Bye~");
val=analogRead(flame); Serial.print("Flame="); Serial.println(val); // 화재센서
if(val>=300)digitalWrite(Beep,HIGH);
else digitalWrite(Beep,LOW);
byte temperature=0;
byte humidity=0;
dht11.read(pinDHT11,&temperature,&humidity,NULL);
Serial.print((int)temperature); Serial.print("*C,");
Serial.print((int)humidity); Serial.println("%");
lcd.clear();
lcd.print((int)temperature); lcd.print("*C,");
lcd.print((int)humidity); lcd.print("%");
delay(1000); // DHT11 sampling rate is 1HZ.
댓글 : 0
조회수 : 5,520
