질문게시판 > 도와주세요
TODAY566 TOTAL2,274,467
BASIC4MCU | 질문게시판 | 도와주세요
작성자 뉴봉맨 작성일2022-05-03 12:15 조회1,301회 댓글1건
오류가 왜 뜨는지 모르겠습니다..
아래는 소스파일이에요
//맨위 1번
#define F_CPU 16000000UL
#define cbi(sfr, bit) {(_SFR_BYTE(sfr) &= ~_BV(bit));}
#define sbi(sfr, bit) {(_SFR_BYTE(sfr) |= _BV(bit));}
#include <stdio.h>
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#include <string.h>
#include "lcd.h"
#include "16key.h"
volatile int cnt=0;
volatile char BUFF[30],key,current_State='A';
volatile char number[5],password[5];
volatile int keynum=0;
volatile char rx_ch[5];
volatile int i=0;
volatile char close;
void init_password()
    memset(password,'\0',sizeof(password));
void init_number()
    memset(number,'\0',sizeof(number));
void set_password()
        key=keyScan();
        if( (key>='0')  & (key<='9'|| (key=='*'|| (key =='#'))
            if(keynum==0)
                password[0]=key;
                password[1]='\0';
            if(keynum==1)
                password[1]=key;
                password[2]='\0';
            if(keynum==2)
                password[2]=key;
                password[3]='\0';
            if(keynum==3)
                password[3]=key;
                password[4]='\0';
            keynum++;
void insert_password()
        key=keyScan();
        if(key=='A')
                current_State='A'//A모드로 돌아가라!
                init_password(); //패스워드 초기화
                init_number(); //현재 입력한거 초기화
            if(keynum==0)
                number[0]=key;
                number[1]='\0';
            if(keynum==1)
                number[1]=key;
                number[2]='\0';
            if(keynum==2)
                number[2]=key;
                number[3]='\0';
            if(keynum==3)
                number[3]=key;
                number[4]='\0';
            keynum++;
void sensor_init()
    DDRF=0xfc// PF0 ADC , PF1 SWITCH
    PORTF |= 0x02;
    ADCSRA=0xe7;
    ADMUX=0x40;
 void timer_init()
     DDRB=0xff;
     TCCR0=0x6f;
    TCCR2=0x05;
    TIMSK = 0x40;
void usart_init()
        UCSR0A=0x00;
          UCSR0B=0x90//송신부 & 수신부 활성화
          UCSR0C=0x06;
          UBRR0H=0;
          UBRR0L=103//9600@16MHz 고정
        SREG=0x80;
ISR(SIG_OVERFLOW2){
    TCNT2=0x40//0.01ms
    if(cnt>=1000)
        DDRE=0x00;
        PORTE=0x00;
        close='C'//닫혀있다
        OCR0=0x0f;
        cnt=0;
        if(close=='O'//열려있다.
            DDRE=0xf0
            PORTE=0xf0;
            cnt++;
ISR(USART0_RX_vect)
    rx_ch[i]=UDR0;
    i++;
    if(i==4)
        if((!strcmp(rx_ch,password)))//같다면 모터 돌아가기
            OCR0=0x20;
            close='O';
        i=0;
        memset(rx_ch,'\0',sizeof(rx_ch));
int main()
    DDRF=0xfe;
    lcd_init();
    sensor_init();
    timer_init();
    usart_init();
    DDRE=0x00
    OCR0=0x0f//디폴트 (닫혀있다)
         if(!(PINF&0x02))
            if(ADC<500)
                PORTF|=0x04;
                PORTF &= 0b1111011;
            if(current_State=='A'//비밀번호 설정
                set_password();
                sprintf(BUFF,"key : %s ",password);
                writeString_LCD(0,0,"set password");
                writeString_LCD(0,1,BUFF);
                if(keynum==4)
                    keynum=0;
                    current_State='B';
                    Command_set(0x01);// 화면지우기
            if(current_State=='B'//비밀번호 입력
                insert_password();
                sprintf(BUFF,"key : %s ",number);
                writeString_LCD(0,0,"insert key");
                if(keynum==4)
                    keynum=0;
                    current_State='C'//비밀번호 확인 모드
            if(current_State=='C'//비밀번호 검사
                if((!strcmp(number,password)))//같다면 모터 돌아가기
                    OCR0=0x20//열어라
                    close='O'// 열려있다
                current_State='B';
조회수 1,301
오류가 뭐죠?
오류를 클릭하면 문제가 있는 소스로 커서가 이동합니다.
질문 아두이노 초음파센서 코딩 질문댓글[3] 이미지첨부파일 아두이노아린이 22-05-20 1844
질문 아두이노 스케치 후 pc usb 연결없이 사용한가요?댓글[1] 까치 22-05-20 1091
질문 atmega128 서보모터와 초음파센서댓글[5] tmiae 22-05-20 2589
질문 avr compiler 종류 질문입니다!댓글[3] 민준싸 22-05-20 1621
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[4] 이미지첨부파일 보겐을운용 22-05-19 2034
질문 아두이노 dac 연결댓글[7] 이미지첨부파일 kodory 22-05-19 2235
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 1273
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.댓글[2] master 22-05-19 1856
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 123424135123q 22-05-19 1314
질문 스텝모터 드라이버 선정 질문드립니다. 아흐흑 22-05-18 1436
답변 답변글 답변 : 스텝모터 드라이버 선정 질문드립니다.댓글[1] 이미지 master 22-05-19 1291
질문 아두이노로 모터+드라이버 제어댓글[6] 모토 22-05-18 2777
질문 온도센서로 서보모터 제어 코딩댓글[1] 진수네1조 22-05-18 1699
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[3] 전자과 22-05-17 1482
질문 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 이현주 22-05-17 2184
답변 답변글 답변 : 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) master 22-05-18 1626
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 2390
질문 졸업작품 첨부파일 ejdog 22-05-16 1641
질문 PCB의 커넥터 연결관련 이슈같은데.. 원인을 정확히 모르겠습니다.댓글[2] 이미지 설계못해서개털림 22-05-16 1790
질문 STM32F767 사용중인데 발열이 발생합니다.댓글[5] 존클라프 22-05-16 3238
질문 리니어 레일 거리 조절댓글[1] 면수 22-05-16 1520
질문 아두이노 심전도 센서 BPM 계산댓글[3] 쥬쥬 22-05-16 1757
질문 아두이노 서로 다른 전압을 가진 부품 제어 이미지 chovo 22-05-16 1293
질문 앱인벤터 질문입니다.댓글[2] 이미지 귀끠우유 22-05-16 2380
질문 아두이노 우노끼리 블루투스 통신댓글[1] 첨부파일 pyoleo 22-05-16 1881
질문 마이크로 받은 입력을 주파수로 변경댓글[3] 생늧판출 22-05-16 1487
질문 while문 안 if문 빠져나오는 방법 kyho3855 22-05-15 1516
답변 답변글 답변 : while문 안 if문 빠져나오는 방법댓글[1] master 22-05-16 1343
질문 초음파센서로 속도구하기(코드 합치는법) 쥰니 22-05-15 1703
답변 답변글 답변 : 초음파센서로 속도구하기(코드 합치는법)댓글[1] master 22-05-16 1403
