질문게시판 > 답변 : 도와주세요
TODAY212 TOTAL2,271,679
BASIC4MCU | 질문게시판 | 답변 : 도와주세요
작성자 master 작성일2022-05-03 12:48 조회2,890회 댓글2건
//맨위 1번
#define F_CPU 16000000UL
#define cbi(sfr,bit) {(_SFR_BYTE(sfr)&=~_BV(bit));}
#define sbi(sfr,bit) {(_SFR_BYTE(sfr)|=_BV(bit));}
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "lcd.h"
#include "16key.h"
volatile int cnt=0;
volatile char BUFF[30],key,current_State='A';
volatile char number[5],password[5];
volatile int keynum=0;
volatile char rx_ch[5];
volatile int i=0;
volatile char close;
void init_password(){ memset(password,'\0',sizeof(password)); }
void init_number(){ memset(number,'\0',sizeof(number)); }
void set_password(){
    key=keyScan();
    if((key>='0')&(key<='9')||(key=='*')||(key=='#')){
        if(keynum==0){ password[0]=key; password[1]='\0'; }
        if(keynum==1){ password[1]=key; password[2]='\0'; }
        if(keynum==2){ password[2]=key; password[3]='\0'; }
        if(keynum==3){ password[3]=key; password[4]='\0'; }
        keynum++;
void insert_password(){
    key=keyScan();
    if(key=='A'){
        current_State='A'; // A모드로 돌아가라!
        init_password();   // 패스워드 초기화
        init_number();     // 현재 입력한거 초기화
        if(keynum==0){ number[0]=key; number[1]='\0'; }
        if(keynum==1){ number[1]=key; number[2]='\0'; }
        if(keynum==2){ number[2]=key; number[3]='\0'; }
        if(keynum==3){ number[3]=key; number[4]='\0'; }
        keynum++;
void sensor_init(){
    DDRF=0xfc; // PF0 ADC ,PF1 SWITCH
    PORTF |=0x02;
    ADCSRA=0xe7;
    ADMUX=0x40;
void timer_init(){
    DDRB=0xff;
    TCCR0=0x6f;
    TCCR2=0x05;
    TIMSK=0x40;
void usart_init(){
    UCSR0B=0x90; //송신부 & 수신부 활성화
    UBRR0L=103; //9600@16MHz 고정
    SREG=0x80;
ISR(SIG_OVERFLOW2){
    TCNT2=0x40; //0.01ms
    if(cnt>=1000){ cnt=0;
        DDRE=0x00; PORTE=0x00; OCR0=0x0f; close='C'; //닫혀있다
        if(close=='O'){ DDRE=0xf0; PORTE=0xf0; cnt++; } //열려있다.
ISR(USART0_RX_vect){
    rx_ch[i]=UDR0;
    if(++i==4){ i=0;
        if((!strcmp(rx_ch,password))){ OCR0=0x20; close='O'; } //같다면 모터 돌아가기
        memset(rx_ch,'\0',sizeof(rx_ch));
int main(){
  DDRF=0xfe;
  lcd_init();
  sensor_init();
  timer_init();
  usart_init();
  DDRE=0x00;
  OCR0=0x0f; //디폴트(닫혀있다)
    if(!(PINF&0x02)){
        if(ADC<500)PORTF|=4; else PORTF&=~4;
        if(current_State=='A'){ //비밀번호 설정
            set_password();
            sprintf(BUFF,"key : %s ",password);
            writeString_LCD(0,0,"set password");
            writeString_LCD(0,1,BUFF);
            if(keynum==4){ keynum=0; current_State='B'; Command_set(0x01); } // 화면지우기
        if(current_State=='B'){ //비밀번호 입력
            insert_password();
            sprintf(BUFF,"key : %s ",number);
            writeString_LCD(0,0,"insert key");
            if(keynum==4){ keynum=0; current_State='C'; } //비밀번호 확인 모드
        if(current_State=='C'){ //비밀번호 검사
            if((!strcmp(number,password))){ OCR0=0x20; close='O'; } //같다면 모터 돌아가기 // 열려있다
            Command_set(0x01); // 화면지우기
            current_State='B';
    else Command_set(0x01);// 화면지우기
소스코드 정리만 한 것입니다.
조회수 2,890
뉴봉맨님의 댓글
뉴봉맨 작성일
ISR(SIG_OVERFLOW2)가 오류라고 합니다.. 잘모르겠어요ㅠㅠ
mcu가 뭔가요?
질문 아두이노 스케치 후 pc usb 연결없이 사용한가요?댓글[1] 까치 22-05-20 1027
질문 atmega128 서보모터와 초음파센서댓글[5] tmiae 22-05-20 2451
질문 avr compiler 종류 질문입니다!댓글[3] 민준싸 22-05-20 1506
질문 컴퓨터 usb연결시 정상 작동하나 9V건전지 외부전원 연결 시 작동하지 않는 문제댓글[4] 이미지첨부파일 보겐을운용 22-05-19 1914
질문 아두이노 dac 연결댓글[7] 이미지첨부파일 kodory 22-05-19 2060
질문 아두이노 millis ->atmega128에서 사용하고 싶습니다. akmong413 22-05-19 1189
답변 답변글 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.댓글[2] master 22-05-19 1738
질문 아트메가 모터드라이브와 초음파 센서 연동 질문입니다댓글[1] 123424135123q 22-05-19 1238
질문 스텝모터 드라이버 선정 질문드립니다. 아흐흑 22-05-18 1337
답변 답변글 답변 : 스텝모터 드라이버 선정 질문드립니다.댓글[1] 이미지 master 22-05-19 1203
질문 아두이노로 모터+드라이버 제어댓글[6] 모토 22-05-18 2583
질문 온도센서로 서보모터 제어 코딩댓글[1] 진수네1조 22-05-18 1596
질문 라즈베리파이 웹캠 데이터 아두이노 전송 (초보)댓글[3] 전자과 22-05-17 1388
질문 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) 이현주 22-05-17 2058
답변 답변글 답변 : 아두이노 코딩 도와주세요 (초음파센서와 금속감지센서로 서보모터 제어하기) master 22-05-18 1543
질문 아두이노 우노 2개와 앱인벤터끼리의 블루투스 통신 방법댓글[3] 이미지첨부파일 pyoleo 22-05-17 2256
질문 졸업작품 첨부파일 ejdog 22-05-16 1567
질문 PCB의 커넥터 연결관련 이슈같은데.. 원인을 정확히 모르겠습니다.댓글[2] 이미지 설계못해서개털림 22-05-16 1687
질문 STM32F767 사용중인데 발열이 발생합니다.댓글[5] 존클라프 22-05-16 3012
질문 리니어 레일 거리 조절댓글[1] 면수 22-05-16 1445
질문 아두이노 심전도 센서 BPM 계산댓글[3] 쥬쥬 22-05-16 1663
질문 아두이노 서로 다른 전압을 가진 부품 제어 이미지 chovo 22-05-16 1218
질문 앱인벤터 질문입니다.댓글[2] 이미지 귀끠우유 22-05-16 2260
질문 아두이노 우노끼리 블루투스 통신댓글[1] 첨부파일 pyoleo 22-05-16 1782
질문 마이크로 받은 입력을 주파수로 변경댓글[3] 생늧판출 22-05-16 1410
질문 while문 안 if문 빠져나오는 방법 kyho3855 22-05-15 1436
답변 답변글 답변 : while문 안 if문 빠져나오는 방법댓글[1] master 22-05-16 1262
질문 초음파센서로 속도구하기(코드 합치는법) 쥰니 22-05-15 1607
답변 답변글 답변 : 초음파센서로 속도구하기(코드 합치는법)댓글[1] master 22-05-16 1340
질문 360서보모터 질문입니다댓글[1] 한잔해2 22-05-14 1363
