질문게시판 > stm32 uart serial 통신
TODAY534 TOTAL2,277,923
BASIC4MCU | 질문게시판 | stm32 uart serial 통신
작성자 하리 작성일2022-05-09 14:44 조회2,744회 댓글2건
/* USER CODE END Header */
/* Includes --------
#include "main.h"
#include <string.h>
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
  uint8_t str[15] = "Hello World!\n\r";
  uint8_t received[5] = {0};
  //uint8_t received=5;
  HAL_StatusTypeDef rcvStat;
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
  void UART1_IRQHandler(void)
    HAL_UART_IRQHandler(&huart1);
  void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart){
  if (huart->Instance == USART1)
      if(rcvStat == HAL_OK)
        if(sizeof(received) == sizeof(5))
           HAL_UART_Transmit(&huart1, received, 1, 10);
   rcvStat = HAL_UART_Receive_IT(&huart1, received, 1);
/* USER CODE ENdD 0 */
  * @brief  The application entry point.
  * @retval int
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_USART1_UART_Init();
  /* Initialize interrupts */
  MX_NVIC_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
   HAL_UART_Transmit(&huart1, received, 1, 10) 처럼 하나씩 받으면 제대로 받아지지 않고 잘려서 받아져요 예를 들면 hello를 보냈을 때 돌아오는건 hel만 받아지고
   5개씩 받을려고 할 때 5개보다 적거나 많을 때는 ERROR란 글자를 보내고 싶어서 if문을 작성해봤는데 여러방법을 사용해봐도 ERROR란 글자는 안써지고 예를들어 eeeeee를 보내면 eeeee가 받아진 후 다음에 ffff를 보내면 effff이런식으로 받아져요
   어디서부터 잘못되었을까요 ㅠㅠ
반대로 5개가 충족되면 OK를 받게 했더니 그건 제대로 받아지더라고요 HAL_UART_Transmit(&huart1, "OK", sizeof("OK"), 10);
조회수 2,744
여기서 sizeof(5) 이 건 뭔가요? 상수 5의 (메모리)크기를 왜 넣었죠?
if(sizeof(received) == 5)
이렇게 해야 하는 것 아닌가요?
문자열의 크기를 측정하는 경우 널문자를 못 만나면 오동작합니다. 문자열에 대해서 공부하세요
인터럽트 안에서 시간이 많이 걸리는 처리를 하면 안됩니다.
2바이트 이상의 데이터를 주고 받으려면 패킷(프로토콜)을 만들어서 주고 받으세요
하리님의 댓글
하리 댓글의 댓글 작성일
답변해주셔서 감사합니다 인사가 늦었습니다 ㅠㅠ
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[4] 이미지첨부파일 스트렌져 22-05-24 1245
질문 진동센서와 서보모터 연결 코드 질문입니다!댓글[1] 제리 22-05-24 1378
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 코딩초보1 22-05-24 1245
질문 서보모터 제어에 관하여 궁금합니다댓글[3] 이미지첨부파일 오소로롯 22-05-24 815
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지 마프하나 22-05-23 1996
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 졸작부수다 22-05-23 1532
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … master 22-05-24 971
질문 보드레이트 질문댓글[1] 죠르디 22-05-23 1109
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 1321
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 1532
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 1609
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 1383
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 1485
질문 초음파+스텝모터 도꺼비 22-05-22 1233
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 1148
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 1302
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 1395
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 1689
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 1747
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 1132
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 1209
답변 답변글 답변 : Atmega128 UART통신에서 ECHO 관련 질문드립니다.댓글[1] master 22-05-22 1144
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 1494
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[5] noster 22-05-21 1673
질문 아두이노 에러질문댓글[2] 이미지첨부파일 리니어 22-05-21 2114
질문 아두이노 블루투스 통신 관련 질문 있습니다!! 블루툿 22-05-21 623
답변 답변글 답변 : 아두이노 블루투스 통신 관련 질문 있습니다!! master 22-05-21 1317
질문 아두이노 DRV2605 헵틱 모터 드라이버댓글[4] gano 22-05-21 1554
질문 아두이노 d1r2 W238 방수 초음파 센서댓글[1] 밤새아두이노 22-05-21 1556
질문 아두이노 블루투스(hc-06)사용중 질문있습니다. 첨부파일 띵꽁 22-05-20 1631
