질문게시판 > 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.
TODAY150 TOTAL2,230,949
BASIC4MCU | 질문게시판 | 답변 : 아두이노 millis ->atmega128에서 사용하고 싶습니다.
작성자 master 작성일2022-05-19 17:27 조회566회 댓글2건
#define TdsSensorPin A1
#define VREF         5.0     // analog reference voltage(Volt)of the ADC
#define SCOUNT       30      // sum of sample point
int analogBuffer[SCOUNT];    // store the analog value in the array,read from ADC
int analogBufferTemp[SCOUNT];
int analogBufferIndex=0,copyIndex=0;
float averageVoltage=0,tdsValue=0,temperature=25;
volatile char flag40=0,flag800=0;
ISR(TIMER1_COMPA_vect){ // 40ms
  static char c=0;
  flag40=1;
  if(++c>=20){ c=0; flag800=1; } // 800ms
int main(){
  Serial.begin(115200);
  pinMode(TdsSensorPin,INPUT);
  TCCR1B=0x0B; OCR1A=9999; TIMSK=0x10; SREG=0x80; //40ms
   if(flag40){ flag40=0; // 40ms
     analogBuffer[analogBufferIndex]=analogRead(TdsSensorPin);               // read ADC
     analogBufferIndex++;
     if(analogBufferIndex==SCOUNT)analogBufferIndex=0;
   if(flag800){ flag800=0; // 800ms
      for(copyIndex=0;copyIndex<SCOUNT;copyIndex++)analogBufferTemp[copyIndex]=analogBuffer[copyIndex];
      averageVoltage=getMedianNum(analogBufferTemp,SCOUNT)*(float)VREF/1024.0; // read the analog value more stable by the median filtering algorithm,and convert to voltage value
      float compensationCoefficient=1.0+0.02*(temperature-25.0);               // temperature compensation formula: fFinalResult(25^C)=fFinalResult(current)/(1.0+0.02*(fTP-25.0));
      float compensationVolatge=averageVoltage/compensationCoefficient;        // temperature compensation
      tdsValue=(133.42*compensationVolatge*compensationVolatge*compensationVolatge-255.86*compensationVolatge*compensationVolatge+857.39*compensationVolatge)*0.5; //convert voltage value to tds value
      //Serial.print("voltage:"); Serial.print(averageVoltage,2); Serial.print("V   ");
      Serial.print("TDS Value:"); Serial.print(tdsValue,0); Serial.println("ppm");
int getMedianNum(int bArray[],int iFilterLen){
  int bTab[iFilterLen];
  for(byte i=0;i<iFilterLen;i++)bTab[i]=bArray[i];
  int i,j,bTemp;
  for(j=0;j<iFilterLen-1;j++){
    for(i=0;i<iFilterLen-j-1;i++){
      if(bTab[i]>bTab[i+1]){ bTemp=bTab[i]; bTab[i]=bTab[i+1]; bTab[i+1]=bTemp; }
  if((iFilterLen&1)>0)bTemp=bTab[(iFilterLen-1)/2];
  else bTemp=(bTab[iFilterLen/2]+bTab[iFilterLen/2-1])/2;
  return bTemp;
조회수 566
akmong413님의 댓글
akmong413 작성일
8MHz에서 사용하려면 timer0 쓰면 될까요?
타이머0의 최대는 16MHz에서 16,384ms, 8MHz에서 32,768ms 밖에 안되므로 40ms를 만들기 위해서는 변수를 하나 더 사용해야 하는 번거로움이 있습니다.
번거로워도 상관없고 구지 8비트를 사용하고 싶다면
    TCCR0=0x0E; OCR0=249; TIMSK=2; //16000000/256/(1+249),4ms
이 설정은 16mHz에서 4ms이므로 8MHz에서 8ms가 됩니다.
변수로 카운트 해서 5일 때가 40ms가 되겠죠
16Mhz에서 20ms는 8MHz에서 40ms가 됩니다.
타이머1에서 20ms 설정을 찾으면 몇가지 종류가 나옵니다.
    TCCR1B=0x0A; OCR1A=39999; TIMSK=0x10; //20ms
    TCCR1B=0x0B; OCR1A=4999; TIMSK=0x10; //20ms
    TCCR1B=0x0C; OCR1A=1249; TIMSK=0x10; //20ms
이 중 맘에드는 것으로 아무 것이나 골라서 사용하세요
질문 atmega128 avr usart 질문 snoflak 22-06-21 179
답변 답변글 답변 : atmega128 avr usart 질문댓글[5] master 22-06-21 340
질문 atmega128댓글[1] 이미지 양의노래 22-06-20 204
질문 ATMEGA128 UART,FND 연동 질문 JMOD 22-06-19 223
답변 답변글 답변 : ATMEGA128 UART,FND 연동 질문댓글[1] master 22-06-20 131
질문 atmega128 초음파 센서로 신호등 시간초 늘리기 서동씨 22-06-18 187
답변 답변글 답변 : atmega128 초음파 센서로 신호등 시간초 늘리기댓글[1] master 22-06-18 225
질문 atmega128댓글[2] 망경이 22-06-18 246
질문 안녕하세요 atmega128 질문드리고 싶습니다. (자동 분리수거 기계, 소리 주파수 변환)댓글[3] dlcldl 22-06-17 348
질문 ATMEGA128 HIGH LOW신호 수신 질문 yhj2644 22-06-16 237
답변 답변글 답변 : ATMEGA128 HIGH LOW신호 수신 질문댓글[3] master 22-06-17 252
질문 codevision atmega128 코딩 알려주세요 ㅠㅠ댓글[4] 이미지 goodjob 22-06-16 312
질문 atmega128 인터럽트 이용한 dc모터 제어댓글[2] 이미지첨부파일 박맹 22-06-10 389
질문 atmega128 순차적신호 질문있습니다댓글[1] 이미지첨부파일 졸업예정 22-06-10 284
답변 답변글 답변 : atmega128 순차적신호 질문있습니다 master 22-06-10 333
질문 ATMEGA128 인터럽트 관련질문입니다댓글[2] 짜요쩌요 22-06-09 420
질문 atmega128에서 초음파 센서(HC-SR04)를 통해 부저 소리를 내려합니다. seung 22-06-08 374
답변 답변글 답변 : atmega128에서 초음파 센서(HC-SR04)를 통해 부저 소리를 내려합니다.댓글[1] master 22-06-08 353
질문 Atmega128 코딩 도와주세요,,! 이미지첨부파일 화니뿌뿌 22-06-07 413
답변 답변글 답변 : Atmega128 코딩 도와주세요,,!댓글[3] master 22-06-08 377
질문 atmega128 코드 질문있습니다 콜뚜기 22-06-07 297
답변 답변글 답변 : atmega128 코드 질문있습니다댓글[3] master 22-06-07 420
질문 ATMEGA128질문입니다.댓글[1] suid82 22-06-06 408
질문 atmega128 프로젝트 외주 사례합니다댓글[1] 공돌ㅇ 22-06-05 390
질문 atmega128 프로테우스 부저소리 관련하여..댓글[1] 꿍다라링 22-06-04 287
질문 atmega128 조도센서를 이용하여 서보모터와 dc모터 제어하는거 봐주실수있나요ㅠㅠ 이미지첨부파일 화니뿌뿌 22-06-02 520
답변 답변글 답변 : atmega128 조도센서를 이용하여 서보모터와 dc모터 제어하는거 봐주실수있나요ㅠㅠ댓글[4] master 22-06-02 1036
질문 ATMEGA128 채터링(chattering)관련 질문입니다.댓글[1] 아지개구리 22-06-02 567
