질문게시판 > esp32를 이용한 피에조부저
TODAY258 TOTAL2,271,725
BASIC4MCU | 질문게시판 | esp32를 이용한 피에조부저
작성자 ejdog 작성일2022-05-27 23:00 조회1,633회 댓글1건
오류 원인 좀 찾아주세여ㅠㅠ
 * This ESP32 code is created by esp32io.com
 * This ESP32 code is released in the public domain
 * For more detail (instruction and wiring diagram), visit https://esp32io.com/tutorials/esp32-button-piezo-buzzer
#include "pitches.h"
#define BUTTON_PIN 16 // ESP32 GIOP16 pin connected to button's pin
#define BUZZER_PIN 21 // ESP32 GIOP21 pin connected to Buzzer's pin
// notes in the melody:
int melody[] = {
  NOTE_E5, NOTE_E5, NOTE_E5,
  NOTE_E5, NOTE_G5, NOTE_C5, NOTE_D5,
  NOTE_E5,
  NOTE_F5, NOTE_F5, NOTE_F5, NOTE_F5,
  NOTE_F5, NOTE_E5, NOTE_E5, NOTE_E5, NOTE_E5,
  NOTE_E5, NOTE_D5, NOTE_D5, NOTE_E5,
  NOTE_D5, NOTE_G5
// note durations: 4 = quarter note, 8 = eighth note, etc, also called tempo:
int noteDurations[] = {
  8, 8, 4,
  8, 8, 4,
  8, 8, 8, 8,
  2,
  8, 8, 8, 8,
  8, 8, 8, 16, 16,
  8, 8, 8, 8,
  4, 4
  Serial.begin(9600);                // initialize serial
  pinMode(BUTTON_PIN, INPUT_PULLUP); // set ESP32 pin to input pull-up mode
  int buttonState = digitalRead(BUTTON_PIN); // read new state
  if (buttonState == LOW) { // button is pressed
    Serial.println("The button is being pressed");
    buzzer();
void buzzer() {
  // iterate over the notes of the melody:
  int size = sizeof(noteDurations) / sizeof(int);
  for (int thisNote = 0; thisNote < size; thisNote++) {
    // to calculate the note duration, take one second divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1000 / noteDurations[thisNote];
    tone(BUZZER_PIN, melody[thisNote], noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(BUZZER_PIN);
조회수 1,633
int playing = 0;
void tone(byte pin, int freq) {
  ledcSetup(0, 2000, 8); // setup beeper
  ledcAttachPin(pin, 0); // attach beeper
  ledcWriteTone(0, freq); // play tone
  playing = pin; // store pin
void noTone() {
  tone(playing, 0);
https://github.com/espressif/arduino-esp32/issues/1720
질문 아두이노 자율주행 rc카 초음파 장애물에 닿으면 정지하고 장애물 없어지면 다시 전진하는 코딩을 잘모르겠습니다…댓글[5] 종느 22-06-06 2175
질문 아두이노 우노 listen() 사용댓글[3] 첨부파일 면지지 22-06-05 1103
질문 아두이노 메가 2560 관련 질문입니다!댓글[3] 이미지 아뒤노 22-06-05 1391
질문 아두이노 모터 제어 코드 질문 히동 22-06-05 1428
답변 답변글 답변 : 아두이노 모터 제어 코드 질문댓글[1] master 22-06-05 911
질문 atmega128 프로젝트 외주 사례합니다댓글[1] 공돌ㅇ 22-06-05 1080
질문 atmega128 프로테우스 부저소리 관련하여..댓글[1] 꿍다라링 22-06-04 957
질문 assembly coding 한 번만 도와주세요 ㅜ댓글[3] 마프마푸 22-06-04 1343
질문 [ATmega 기초질문] DC모터속도제어 코딩 및 연결 질문드립니다.댓글[2] 이미지 zen123 22-06-04 1689
질문 uart 송수신 관련 질문입니다.댓글[1] 황자르 22-06-04 1155
질문 수위센서, 압력센서를 이용한 서모모터 제어 악두이노 22-06-03 1307
답변 답변글 답변 : 수위센서, 압력센서를 이용한 서모모터 제어 master 22-06-04 890
질문 Esp32 sd card댓글[1] 김아무개 22-06-03 1188
질문 아두이노 라인트레이서 센서를 이용한 rc카로 사다리타기 게임댓글[1] 이미지첨부파일 hunhun 22-06-03 1314
질문 배열에 있는 값으로 jpg 파일 보는 법댓글[3] lshlsh3690 22-06-03 513
질문 아래 ATMEGA LCD 출력 코드 및 에러 확인 질문 이미지 첨부합니다.댓글[1] 이미지첨부파일 chelsea 22-06-03 1260
답변 답변글 답변 : 아래 ATMEGA LCD 출력 코드 및 에러 확인 질문 이미지 첨부합니다. master 22-06-03 1200
질문 온도 센서관련 코드 질문드립니다..댓글[3] MzKLN 22-06-03 1747
질문 ATMEGA LCD 출력 코드 및 에러 확인 부탁드립니다.댓글[2] chelsea 22-06-03 1131
질문 atmega128 조도센서를 이용하여 서보모터와 dc모터 제어하는거 봐주실수있나요ㅠㅠ 이미지첨부파일 화니뿌뿌 22-06-02 1480
답변 답변글 답변 : atmega128 조도센서를 이용하여 서보모터와 dc모터 제어하는거 봐주실수있나요ㅠㅠ댓글[4] master 22-06-02 2614
질문 키패드 led 인체감지 질문 면지지 22-06-02 1450
답변 답변글 답변 : 키패드 led 인체감지 질문댓글[3] master 22-06-02 1021
질문 ATMEGA128 채터링(chattering)관련 질문입니다.댓글[1] 아지개구리 22-06-02 2155
질문 32x8 도트매트릭스 사용질문댓글[3] 엑스칼리버excel 22-06-02 1450
질문 아두이노 릴레이모듈로 전구밝기 조절 가능할까요?댓글[4] 초심자의행운 22-06-02 2203
질문 모터 드라이브 질문드립니다.댓글[2] 이미지첨부파일 kyho3855 22-06-02 1560
질문 안녕하세요 atmega128 chattering에 대해서 궁금한게있습니다.댓글[4] tony 22-06-01 1606
질문 master님 저번 압력센서 릴레이 회로질문입니다! 이미지첨부파일 브레이크 22-06-01 1178
답변 답변글 답변 : master님 저번 압력센서 릴레이 회로질문입니다! 이미지 master 22-06-01 961
