질문게시판 > 답변 : 검토좀부탁드립니다
TODAY1,542 TOTAL2,170,492
BASIC4MCU | 질문게시판 | 답변 : 검토좀부탁드립니다
작성자 master 작성일2018-06-23 23:04 조회4,982회 댓글1건
// DateTime : 2018-06-23 오후 11:03:07
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <IRremote.h>
#include <VirtualWire.h>
#include <SoftwareSerial.h>
int bluetoothTx=2,bluetoothRx=3;
SoftwareSerial bluetooth(bluetoothTx,bluetoothRx);
int RECV_PIN=A0//define input pin on Arduino
IRrecv irrecv(RECV_PIN);
int RF433receivePin=A1;
int n,m,k;
long RF433time,RF433startTime;
bool RF433start=false;
long RF433firstSignaltime;
bool firstSignal=false;
bool ledOn,ledOff;
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  lcd.init(); lcd.backlight();
  //lcd.begin(20,4);
  lcd.setCursor(6,1); lcd.print("MY HOME"); lcd.setCursor(2,2); lcd.print("LIGHTING SYSTEMS"); delay(5000);
  lcd.clear();
  lcd.setCursor(0,3); lcd.print("OFF"); lcd.setCursor(8,3); lcd.print("OFF"); lcd.setCursor(16,3); lcd.print("OFF");
  lcd.setBacklight(0x7);
  bluetooth.begin(9600);
  Serial.println("sdadsfjkdfskjlsdf");
  pinMode(10,OUTPUT); pinMode(11,OUTPUT); pinMode(12,OUTPUT); pinMode(A1,INPUT);
  pinMode(RF433receivePin,INPUT);
  if(irrecv.decode(&results)){
    Serial.println(results.value,HEX);
    switch(results.value){
      case 0x20DF4EB1digitalWrite(10,HIGH); break//0버튼이 눌리면 LED ON
      case 0x20DF8E71digitalWrite(10,LOW ); break//0버튼이 눌리면 LED OFF
      case 0x20DFC639digitalWrite(11,HIGH); break//0버튼이 눌리면 LED ON
      case 0x20DF8679digitalWrite(11,LOW ); break//0버튼이 눌리면 LED OFF
    irrecv.resume(); // Receive the next value
  if(Serial.available()){
    switch(Serial.read()){
      case '1'lcd.setCursor(0,3); lcd.print("ON  "); digitalWrite(10,HIGH); Serial.println("LED1 ON  ");                       break;
      case '2'lcd.setCursor(0,3); lcd.print("OFF "); digitalWrite(10,LOW ); Serial.println("LED1 OFF "); digitalWrite(10,LOW); break;
      case '3'digitalWrite(11,HIGH); break;
      case '4'digitalWrite(11,LOW ); break;
      case '5'digitalWrite(12,HIGH); break;
      case '6'digitalWrite(12,LOW ); break;
  lcd.setCursor(0,2); lcd.print("LED1    LED2    LED3");
  if(bluetooth.available()){
    char cmd=(char)bluetooth.read(); Serial.print("Command="); Serial.println(cmd);
    if(cmd=='1'){ lcd.setCursor0,3); lcd.print("ON "); Serial.println("LED1 ON "); digitalWrite(10,HIGH); }
    if(cmd=='2'){ lcd.setCursor0,3); lcd.print("OFF"); Serial.println("LED1 OFF"); digitalWrite(10,LOW ); }
    if(cmd=='3'){ lcd.setCursor8,3); lcd.print("ON "); Serial.println("LED2 ON "); digitalWrite(11,HIGH); }
    if(cmd=='4'){ lcd.setCursor8,3); lcd.print("OFF"); Serial.println("LED2 OFF"); digitalWrite(11,LOW ); }
    if(cmd=='5'){ lcd.setCursor(16,3); lcd.print("ON "); Serial.println("LED3 ON "); digitalWrite(12,HIGH); }
    if(cmd=='6'){ lcd.setCursor(16,3); lcd.print("OFF"); Serial.println("LED3 OFF"); digitalWrite(12,LOW ); }
  if(!RF433start){
    if(RF433signal(7,A1)){ RF433startTime=millis()+10RF433start=truefirstSignal=false; }
  if(RF433start){
    long milli=millis();
    if(!firstSignal){
      if(milli>RF433startTime){
        if(RF433signal(7,A1)){ firstSignal=trueRF433firstSignaltime=milli; }
        if(milli>RF433startTime+30)RF433start=false;
      if(milli>RF433firstSignaltime+80)RF433start=false;
          long timeGap=milli-RF433firstSignaltime;
          Serial.println(timeGap);
          if(timeGap>50&&timeGap<71){ ledOff=trueRF433start=false; }
          if(timeGap>29&&timeGap<51){ ledOn =trueRF433start=false; }
  if(ledOn ){ ledOn =falselcd.setCursor(0,3); lcd.print("ON  "); Serial.println("on "); }
  if(ledOff){ ledOff=falselcd.setCursor(0,3); lcd.print("OFF "); Serial.println("off"); }
bool RF433signal(int8_t numCriteria,int8_t pinNum){
  int8_t count=0;
  for(int8_t i=0; i<10; i++){
    if(analogRead(pinNum)>RFsSignalLevel;)count++;
    delay(1);
  if(count>=numCriteria)return true; else return false;
// DateTime : 2018-06-23 오후 11:06:36
#define BT_TXD      2
#define BT_RXD      3
SoftwareSerial btSerial(BT_RXD,BT_TXD);
int RECV_PIN=A0;
int RFsendPin=4;
bool ledLight=false;
bool previousLedlight=false;
  pinMode(4,OUTPUT);
  pinMode(10,OUTPUT); digitalWrite(10,HIGH); //RELAY핀
  pinMode(11,OUTPUT); digitalWrite(11,HIGH);
  pinMode(12,OUTPUT); digitalWrite(12,HIGH);
  btSerial.begin(9600);
      case 0x20DF8E71digitalWrite(10,LOW); break//0버튼이 눌리면 LED OFF
      case 0x20DF8679digitalWrite(11,LOW); break//0버튼이 눌리면 LED OFF
      case '1'digitalWrite(10,HIGH); ledLight=true;  break;
      case '2'digitalWrite(10,LOW ); ledLight=falsebreak;
      case '3'digitalWrite(11,HIGH); ledLight=true;  break;
      case '4'digitalWrite(11,LOW ); ledLight=falsebreak;
      case '5'digitalWrite(12,HIGH); ledLight=true;  break;
      case '6'digitalWrite(12,LOW ); ledLight=falsebreak;
  if(btSerial.available()){
    char ch=btSerial.read();
    Serial.write(ch);
    switch(ch){
      case '1'digitalWrite(10,HIGH); ledLight=true;  break//ch가 1이면 C와 NC가 붙는다.// LED는 꺼진다.
      case '2'digitalWrite(10,LOW ); ledLight=falsebreak//ch가 2이면 C와 NO가 붙는다.// LED는 켜진다.
      case '3'digitalWrite(11,HIGH); ledLight=true;  break//ch가 1이면 C와 NC가 붙는다.// LED는 꺼진다.
      case '4'digitalWrite(11,LOW ); ledLight=falsebreak//ch가 2이면 C와 NO가 붙는다.// LED는 켜진다.
      case '5'digitalWrite(12,HIGH); ledLight=true;  break//ch가 2이면 C와 NO가 붙는다.// LED는 켜진다.
      case '6'digitalWrite(12,LOW ); ledLight=falsebreak//ch가 2이면 C와 NO가 붙는다.// LED는 켜진다.
  if(ledLight&&!previousLedlight){ //새로이 ledLight 가 참이되면 0.25초간 송신기에 high 신호를 보냅니다.
    digitalWrite(RFsendPin,HIGH); delay(20); digitalWrite(RFsendPin,LOW); delay(10);
    digitalWrite(RFsendPin,HIGH); delay(20); digitalWrite(RFsendPin,LOW); delay(50);
    previousLedlight=ledLight;
  if(!ledLight&&previousLedlight){ //새로이 ledLight가 부가 되면 0.4초간 송신기에 high 신호를 보냅니다.
    previousLedlight=ledLight//현재의 ledLight 신호 값을 과거의 ledLight 값으로 바꿉니다.
길거나 복잡한 기능의 소스는 남이 봐줄 수가 없습니다.
스스로 디버깅하는 능력을 키우세요
잘 안되는 기능을 하나씩 차례대로 체크해서 문제를 해결하세요
조회수 4,982
슬픈남부님의 댓글
비공개 작성일
검토해주셔서 감사합니다~
역시나 업로드 했더니 안되네요!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 9675
공지 사이트 이용 안내댓글[24] master 17-10-29 29759
질문 로드셀 무게 센서 질문드립니다.댓글[2] 새글 제비고기 15:52 11
질문 adc, uart dma댓글[2] 새글첨부파일 hiㅡO3O 13:10 16
질문 ADC,uart DMA댓글[1] 이미지새글첨부파일 hiㅡO3O 12:23 18
질문 아두이노 스텝모터 리미트 문의드립니다.댓글[1] 이미지새글첨부파일 스트렌져 22-05-24 21
질문 진동센서와 서보모터 연결 코드 질문입니다!댓글[1] 새글 제리 22-05-24 19
질문 atmega128 GPS,블루투스 질문드립니다.댓글[1] 새글 코딩초보1 22-05-24 28
질문 서보모터 제어에 관하여 궁금합니다댓글[2] 이미지새글첨부파일 오소로롯 22-05-24 33
질문 atmega 128 타이머 작성 중 질문 드립니다.댓글[8] 이미지새글 마프하나 22-05-23 46
질문 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 어떻게 해…댓글[1] 새글 졸작부수다 22-05-23 145
답변 답변글 답변 : 아두이노와 휴대폰을 HC-06으로 연결시켜서 블루투스연결이 끊기면 부저에서 소리가 나게 할려하는데 … 새글 master 22-05-24 19
질문 보드레이트 질문댓글[1] 새글 죠르디 22-05-23 20
질문 atmega 128 블루투스 질문 입니다댓글[1] yhj2644 22-05-23 37
질문 아트메가 공부중에 질문있습니다..댓글[1] suid82 22-05-23 25
질문 Atmega128 UART통신 echo 반복 질문댓글[2] ming2ming 22-05-23 34
질문 아두이노의 지속 시간에 대해 질문합니다. merry 22-05-23 36
답변 답변글 답변 : 아두이노의 지속 시간에 대해 질문합니다. master 22-05-23 30
질문 초음파+스텝모터 도꺼비 22-05-22 28
답변 답변글 답변 : 초음파+스텝모터 master 22-05-23 32
질문 아두이노 인터럽트 질문있습니다.댓글[1] 띵꽁 22-05-22 36
답변 답변글 답변 : 아두이노 인터럽트 질문있습니다.댓글[3] master 22-05-22 36
질문 atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[4] 이미지 마프하나 22-05-22 55
답변 답변글 답변 : atmega128 스톱워치 작성 중 외부 인터럽트 관련 질문 드립니다.댓글[1] 이미지 master 22-05-23 33
질문 서보모터제어 해당코드에서 어떤걸 추가해야할까요댓글[3] 이미지첨부파일 오소로롯 22-05-22 39
질문 Atmega128 UART통신에서 ECHO 관련 질문드립니다. dsfdfsa 22-05-22 39
답변 답변글 답변 : Atmega128 UART통신에서 ECHO 관련 질문드립니다.댓글[1] master 22-05-22 31
질문 아두이노 서보모터제어 하나도 모르겠습니다 ㅠ댓글[2] 이미지첨부파일 오소로롯 22-05-21 57
질문 아트메가 128 을 이용해서적외선 센서 코딩 중 물어볼게있습니다!!댓글[5] noster 22-05-21 61
질문 아두이노 에러질문댓글[2] 이미지첨부파일 리니어 22-05-21 59
