BASIC4MCU | 질문게시판 | 배열에 있는 값으로 jpg 파일 보는 법
작성자 lshlsh3690 작성일2022-06-03 15:10 조회585회 댓글3건본문
#include <ArduCAM.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//This demo can only work on OV2640_MINI_2MP or OV5642_MINI_5MP or OV5642_MINI_5MP_BIT_ROTATION_FIXED platform.
#if !(defined OV5642_MINI_5MP || defined OV5642_MINI_5MP_BIT_ROTATION_FIXED || defined OV2640_MINI_2MP || defined OV3640_MINI_3MP)
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
//#define SD_CS 4
const int SPI_CS = 7;
#if defined (OV2640_MINI_2MP)
ArduCAM myCAM( OV2640, SPI_CS );
#elif defined (OV3640_MINI_3MP)
ArduCAM myCAM( OV3640, SPI_CS );
#else
ArduCAM myCAM( OV5642, SPI_CS );
#endif
void myCAMSaveToSDFile(){
char str[8];
byte buf[256];
static int i = 0;
static int k = 0;
uint8_t temp = 0,temp_last=0;
uint32_t length = 0;
bool is_header = false;
int len = 0;
File outFile;
//Flush the FIFO
myCAM.flush_fifo();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Start capture
myCAM.start_capture();
Serial.println(F("start Capture"));
while(!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK));
Serial.println(F("Capture Done."));
length = myCAM.read_fifo_length();
len = length;
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //384K
Serial.println(F("Over size."));
return ;
if (length == 0 ) //0 kb
Serial.println(F("Size is 0."));
return ;
//Construct a file name
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
/*outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if(!outFile){
Serial.println(F("File open faild"));
return;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
Serial.println(F("Image save OK."));
is_header = false;
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
buf[i++] = temp_last;
buf[i++] = temp;
i=0;
while(len--)
Serial.print(buf[i++],HEX);
Serial.println();
uint8_t vid, pid;
uint8_t temp;
Wire.begin();
Serial.begin(115200);
Serial.println(F("ArduCAM Start!"));
//set the CS as an output:
pinMode(SPI_CS,OUTPUT);
digitalWrite(SPI_CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
myCAM.write_reg(0x07, 0x00);
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55){
Serial.println(F("SPI interface Error!"));
delay(1000);continue;
}else{
Serial.println(F("SPI interface OK."));break;
//Initialize SD Card
/*while(!SD.begin(SD_CS)){
Serial.println(F("SD Card Error!"));delay(1000);
Serial.println(F("SD Card detected."));
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))){
Serial.println(F("Can't find OV2640 module!"));
Serial.println(F("OV2640 detected."));break;
//Check if the camera module type is OV3640
myCAM.rdSensorReg16_8(OV3640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV3640_CHIPID_LOW, &pid);
if ((vid != 0x36) || (pid != 0x4C)){
Serial.println(F("Can't find OV3640 module!"));
}else{
Serial.println(F("OV3640 detected."));break;
#else
//Check if the camera module type is OV5642
myCAM.wrSensorReg16_8(0xff, 0x01);
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if((vid != 0x56) || (pid != 0x42)){
Serial.println(F("Can't find OV5642 module!"));
Serial.println(F("OV5642 detected."));break;
#endif
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.OV2640_set_JPEG_size(OV2640_1024x768);
myCAM.OV3640_set_JPEG_size(OV3640_320x240);
#else
myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK); //VSYNC is active HIGH
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
#endif
myCAMSaveToSDFile();
delay(8000);
저는 아두캠 mini ov2640을 사용하고 있습니다.
buf배열안에 있는 캡처되있는 바이트를 16진수로 출력해서 웹사이트 hex to image에 들어갔는데 확인이 안되네요
실행할때마다 파일 길이는 달라져서 작동은 되는거 같은데
어떻게 확인할 방법이 없네요
sd카드 없이 확인 할 수 있는 방법은 없나요?
댓글 3
조회수 585master님의 댓글
https://cafe.naver.com/circuitsmanual/110402
아두이노도 아니고, 카메라도 다릅니다만
출력 포멧을 맞춘다면 이 프로그램을 활용 할 수 있을겁니다.
https://cafe.naver.com/circuitsmanual/110403
코드 분석 능력이 되셔야 도움이 될텐데요
lshlsh3690님의 댓글
lshlsh3690
답변 감사합니다. 글을 읽고 이것저것 찾아보고 있는데 파일을 로드하는데 딜레이가 있으면 안되서요
아두이노 우노에 캡처를 하고 mqtt 통신을 해서 토픽이랑 같이 묶어서 보내려는데
딜레이는 없앨 수 없을까요? ov2640이 아니라 다른 모듈을 사용해도 상관 없습니다.
지금이라도 능력좋은 라즈베리파이나 PC에서 화상을 직접 받아서 처리해야 하지 않나요?
어쩌려구 능력 떨어지는 아두이노에서 화상을 처리 할까요
