질문게시판 > 아두이노 코드를 보던 중, define부분이 이해가 안되서 해석 부탁드립니다
TODAY496 TOTAL2,277,885
BASIC4MCU | 질문게시판 | 아두이노 코드를 보던 중, define부분이 이해가 안되서 해석 부탁드립니다
작성자 선학 작성일2022-06-09 14:30 조회1,264회 댓글2건
#ifndef direct_pin_read_h_
#define direct_pin_read_h_
#if defined(__AVR__) || (defined(__arm__) && defined(CORE_TEENSY))
#define IO_REG_TYPE uint8_t
#define PIN_TO_BASEREG(pin)             (portInputRegister(digitalPinToPort(pin)))
#define PIN_TO_BITMASK(pin)             (digitalPinToBitMask(pin))
#define DIRECT_PIN_READ(base, mask)     (((*(base)) & (mask)) ? 1 : 0)
#elif defined(__SAM3X8E__)  // || defined(ESP8266)
#define IO_REG_TYPE uint32_t
#elif defined(__PIC32MX__)
#define PIN_TO_BASEREG(pin)             (portModeRegister(digitalPinToPort(pin)))
#define DIRECT_PIN_READ(base, mask) (((*(base+4)) & (mask)) ? 1 : 0)
/* ESP8266 v2.0.0 Arduino workaround for bug https://github.com/esp8266/Arduino/issues/1110 */
#elif defined(ESP8266)
#define PIN_TO_BASEREG(pin)             ((volatile uint32_t *)(0x60000000+(0x318)))
#elif defined(__SAMD21G18A__)
#define PIN_TO_BASEREG(pin)             portModeRegister(digitalPinToPort(pin))
#define DIRECT_PIN_READ(base, mask)     (((*((base)+8)) & (mask)) ? 1 : 0)
#elif defined(RBL_NRF51822)
#define PIN_TO_BASEREG(pin)             (0)
#define PIN_TO_BITMASK(pin)             (pin)
#define DIRECT_PIN_READ(base, pin)      nrf_gpio_pin_read(pin)
#elif defined(__arc__) /* Arduino101/Genuino101 specifics */
#include "scss_registers.h"
#include "portable.h"
#include "avr/pgmspace.h"
#define GPIO_ID(pin)                    (g_APinDescription[pin].ulGPIOId)
#define GPIO_TYPE(pin)                  (g_APinDescription[pin].ulGPIOType)
#define GPIO_BASE(pin)                  (g_APinDescription[pin].ulGPIOBase)
#define EXT_PORT_OFFSET_SS              0x0A
#define EXT_PORT_OFFSET_SOC             0x50
#define PIN_TO_BASEREG(pin)             ((volatile uint32_t *)g_APinDescription[pin].ulGPIOBase)
#define PIN_TO_BITMASK(pin)             pin
static inline __attribute__((always_inline))
IO_REG_TYPE directRead(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
    IO_REG_TYPE ret;
    if (SS_GPIO == GPIO_TYPE(pin)) {
        ret = READ_ARC_REG(((IO_REG_TYPE)base + EXT_PORT_OFFSET_SS));
    } else {
        ret = MMIO_REG_VAL_FROM_BASE((IO_REG_TYPE)base, EXT_PORT_OFFSET_SOC);
    return ((ret >> GPIO_ID(pin)) & 0x01);
#define DIRECT_PIN_READ(base, pin)      directRead(base, pin)
#endif
#endif
아두이노용 코드를 atmega128에 사용하려 변경하던 중, 해당 부분이 이해가 안되서 질문 올립니다
조회수 1,264
컴파일러의 소스코드는 복잡합니다.
아두이노의 라이브러리 코드도 복잡합니다.
일일이 쫒아다니다간 머리털 빠질겁니다.
뭘 변환하려는지 모르겠지만 웹검색으로 AVR 예제소스를 찾는 것이 시간적으로 더 유리합니다.
헤더파일부터 공부하세요
선학님의 댓글
선학 댓글의 댓글 작성일
네넵 감사합니당
질문 안녕하세요 atmega128 질문드리고 싶습니다. (자동 분리수거 기계, 소리 주파수 변환)댓글[3] dlcldl 22-06-17 829
질문 아두이노 delay를 millis로 바꾸고 싶습니다. 슨슨슨모 22-06-16 1022
답변 답변글 답변 : 아두이노 delay를 millis로 바꾸고 싶습니다. master 22-06-17 532
질문 아두이노 LCD 시계 이미지첨부파일 dentist22 22-06-16 758
답변 답변글 답변 : 아두이노 LCD 시계 master 22-06-17 716
질문 ATMEGA128 HIGH LOW신호 수신 질문 yhj2644 22-06-16 648
답변 답변글 답변 : ATMEGA128 HIGH LOW신호 수신 질문댓글[3] master 22-06-17 773
질문 보드레이트 관련 재질문댓글[9] 죠르디 22-06-16 905
질문 서보모터, 사운드센서 질문댓글[3] 죠르디 22-06-16 900
질문 안녕하세요! 아두이노 로봇팔 질문! 이미지첨부파일 구찌만두 22-06-16 834
답변 답변글 답변 : 안녕하세요! 아두이노 로봇팔 질문! master 22-06-16 780
질문 codevision atmega128 코딩 알려주세요 ㅠㅠ댓글[4] 이미지 goodjob 22-06-16 1186
질문 앱인벤터 센서값 숫자 비교 관련입니다.댓글[2] 이미지첨부파일 도와주십 22-06-16 865
질문 이유를 모르겠습니다.댓글[7] 나난나 22-06-15 919
질문 아두이노 이용해서 호흡측정을 하고싶은데 혹시 알맞은 센서가 있을까요??댓글[1] intvert 22-06-15 728
질문 ATMEGA 코드에 오류가 있을까요? skanl 22-06-15 332
답변 답변글 답변 : ATMEGA 코드에 오류가 있을까요?댓글[1] master 22-06-15 452
질문 심박수 측정값 블루투스 전송 코드댓글[1] 이미지 카키 22-06-15 853
질문 LCD 2줄 출력 오류 데라라 22-06-15 1008
답변 답변글 답변 : LCD 2줄 출력 오류댓글[2] master 22-06-15 798
질문 아두이노 질문있습니다. Alpaka 22-06-15 994
답변 답변글 답변 : 아두이노 질문있습니다.댓글[1] master 22-06-15 786
질문 센서 두 종류를 동시에 사용하는 코드를 만드려고 합니다댓글[1] intvert 22-06-14 1105
질문 아래 질문에 연장해서 질문이 있습니다.댓글[1] 페이즐리 22-06-14 939
질문 아두이노 LCD와 7세그먼트 동시 사용댓글[4] 페이즐리 22-06-14 1734
질문 아두이노 코딩 질문입니다.댓글[4] NICE 22-06-14 1361
질문 댓글 : millis()? 질문드립니다.댓글[2] 첨부파일 브링미히어 22-06-14 1272
답변 답변글 답변 : 댓글 : millis()? 질문드립니다.댓글[1] master 22-06-14 840
질문 모션센서 민감도 조절..댓글[3] 이미지첨부파일 남산 22-06-14 1241
질문 아두이노 코딩질문 Alpaka 22-06-14 1398
