BASIC4MCU | 질문게시판 | 아두이노 코드를 보던 중, define부분이 이해가 안되서 해석 부탁드립니다
작성자 선학 작성일2022-06-09 14:30 조회8,689회 댓글2건본문
#ifndef direct_pin_read_h_
#define direct_pin_read_h_
#if defined(__AVR__) || (defined(__arm__) && defined(CORE_TEENSY))
#define IO_REG_TYPE uint8_t
#define PIN_TO_BASEREG(pin) (portInputRegister(digitalPinToPort(pin)))
#define PIN_TO_BITMASK(pin) (digitalPinToBitMask(pin))
#define DIRECT_PIN_READ(base, mask) (((*(base)) & (mask)) ? 1 : 0)
#elif defined(__SAM3X8E__) // || defined(ESP8266)
#define IO_REG_TYPE uint32_t
#elif defined(__PIC32MX__)
#define PIN_TO_BASEREG(pin) (portModeRegister(digitalPinToPort(pin)))
#define DIRECT_PIN_READ(base, mask) (((*(base+4)) & (mask)) ? 1 : 0)
/* ESP8266 v2.0.0 Arduino workaround for bug https://github.com/esp8266/Arduino/issues/1110 */
#elif defined(ESP8266)
#define PIN_TO_BASEREG(pin) ((volatile uint32_t *)(0x60000000+(0x318)))
#elif defined(__SAMD21G18A__)
#define PIN_TO_BASEREG(pin) portModeRegister(digitalPinToPort(pin))
#define DIRECT_PIN_READ(base, mask) (((*((base)+8)) & (mask)) ? 1 : 0)
#elif defined(RBL_NRF51822)
#define PIN_TO_BASEREG(pin) (0)
#define PIN_TO_BITMASK(pin) (pin)
#define DIRECT_PIN_READ(base, pin) nrf_gpio_pin_read(pin)
#elif defined(__arc__) /* Arduino101/Genuino101 specifics */
#include "scss_registers.h"
#include "portable.h"
#include "avr/pgmspace.h"
#define GPIO_ID(pin) (g_APinDescription[pin].ulGPIOId)
#define GPIO_TYPE(pin) (g_APinDescription[pin].ulGPIOType)
#define GPIO_BASE(pin) (g_APinDescription[pin].ulGPIOBase)
#define EXT_PORT_OFFSET_SS 0x0A
#define EXT_PORT_OFFSET_SOC 0x50
#define PIN_TO_BASEREG(pin) ((volatile uint32_t *)g_APinDescription[pin].ulGPIOBase)
#define PIN_TO_BITMASK(pin) pin
static inline __attribute__((always_inline))
IO_REG_TYPE directRead(volatile IO_REG_TYPE *base, IO_REG_TYPE pin)
IO_REG_TYPE ret;
if (SS_GPIO == GPIO_TYPE(pin)) {
ret = READ_ARC_REG(((IO_REG_TYPE)base + EXT_PORT_OFFSET_SS));
} else {
ret = MMIO_REG_VAL_FROM_BASE((IO_REG_TYPE)base, EXT_PORT_OFFSET_SOC);
return ((ret >> GPIO_ID(pin)) & 0x01);
#define DIRECT_PIN_READ(base, pin) directRead(base, pin)
#endif
#endif
아두이노용 코드를 atmega128에 사용하려 변경하던 중, 해당 부분이 이해가 안되서 질문 올립니다
댓글 2
조회수 8,689master님의 댓글
컴파일러의 소스코드는 복잡합니다.
아두이노의 라이브러리 코드도 복잡합니다.
일일이 쫒아다니다간 머리털 빠질겁니다.
뭘 변환하려는지 모르겠지만 웹검색으로 AVR 예제소스를 찾는 것이 시간적으로 더 유리합니다.
헤더파일부터 공부하세요
선학님의 댓글
선학
네넵 감사합니당
