BASIC4MCU | 질문게시판 | Atmega128 기억력테스트 구성중....
작성자 GENE 작성일2018-06-27 00:12 조회5,038회 댓글0건본문
#include <stdlib.h>
#include <avr/pgmspace.h>
//bit제어를위해 설정
#define sbit(x,y) (x |= (1<<y))
#define cbit(x,y) (x &= ~(1<<y))
#define tbit(x,y) (x & (1<<y))
volatile uint8_t msec,m00;
volatile int16_t seed;
volatile uint8_t key1,key1_temp,key_flag,start_flag;
volatile uint8_t key1_on,key1_up,key1_down;
volatile uint8_t data[128],data_count,data_count_end,key_data,timer;
void port_init(void)
DDRD = 0xF0; // PD7-PD4 = LED output
PORTD = 0x00;
DDRF = 0x00; // PORTF = KEY input
PORTF = 0xFF;
void timer_init(void)
TCCR0 = 0x0C; // 1/64
ASSR = 0x00;
OCR0 = 249; // 16MHz/64/(1+249) = 1ms
TCNT0 = 0x00;
TIMSK = 0b00000010; // enable OC0 interrupt
TIFR = 0x00;
prog_int8_t data_table[4] = {0x10,0x20,0x40,0x80};
void keyread(void)
unsigned char i,j;
key1=~PINF&0xf0; //값을 읽어와 필요부분만 유효화한다.
if(key1_temp==key1) //2회 동일값이면
//---------------------------------------------키를 누를때 1회 on
i=key1_on; //이전값
j=key1_temp; //현재값
j=(i^j)&j; //새로운값만 유효
key1_down=j;
//---------------------------------------------키를 눌렀다 뗄때 1회ON
j=key1_temp; //현재값
j=(i^j)&i; //off된 이전값만 유효
key1_up=j;
//---------------------------------------------키가눌려져 있는 동안 on
key1_on=key1_temp; //현재값
//---------------------------------------------이전 값과 일치하지 않으면
else key1_temp=key1;
//10ms 마다 이함수로 진입
void plc(void)
uint8_t i;
if(data_count_end>100) start_flag=0;//최대 100회 반복
//start
if(start_flag==0)
srand(seed);
data_count=0;
data_count_end=0;
start_flag=1;
key1_down=0;
for(i=0;i<100;i++)//난수 100개를 저장
data[i] = rand()%4;
//data 표시
if(start_flag==1)//
timer++;
if(timer<50)
m00=pgm_read_byte(&data_table[data[data_count_end]]);
timer=0;
m00=0;
start_flag=2;
//key 변환
if(start_flag==2)//
if(key1_down>0)
if(tbit(key1_down,4)) key_data=0;
else if(tbit(key1_down,5)) key_data=1;
else if(tbit(key1_down,6)) key_data=2;
else key_data=3;
start_flag=3;
//check
if(start_flag==3)//
if(key_data==data[data_count])
data_count++;
start_flag=2;
if(data_count>data_count_end)
start_flag=1;
data_count=0;
data_count_end++;
start_flag=4;
//error
if(start_flag==4)//
timer++;
if(timer<100)
m00=0xff;
else if(timer<150)
timer=0;
m00=0x00;
start_flag=0;
//out
PORTD=(PORTD&0x0f)|m00;
key1_down=0;key1_up=0;
ISR(TIMER0_COMP_vect) // OC0 interrupt function
sei(); //인터럽트 허용
msec++;
if(msec==10)//10ms
msec=0;
seed++; //난수의 씨앗
keyread();
plc(); // 10ms를 초과하지말것.(가능하면 5ms이내로할것.)
int
main (void)
port_init();
timer_init();
sei();
저희가 기억력테스트랑 LCD 기능을 합쳐서 소스를 만들려고 하는데
위 소스가 기억력 소스입니다. 혹시 Reset 후에 LCD애 START가 약 몇 초간 켜졌다가 꺼지게 만들고 싶은데 혹시 어떻게 해야 할까요?
그리고 잘못 눌렀을 때 Game Over를 몇초간 뜨게 하고 싶습니다~
초심자라 하나 하나씩 배워가고 있습니다 부탁 드릴게요~~
다음은 LCD 소스 입니다~
#include <stdio.h>
void LCD_wCmd(char c){ PORTD=0x08; PORTC=c; _delay_us(1); PORTD&=~8; _delay_ms( 3); }
void LCD_Char(char d){ PORTD=0x0A; PORTC=d; _delay_us(1); PORTD&=~8; _delay_us(50); }
void LCD_Str(char *s){ while(*s)LCD_Char(*s++); }
int main(void){
DDRD=0x0E; // PD1,PD2,PD3 // RS RW E
DDRC=0xFF;
_delay_ms(100);
LCD_wCmd(0x38); LCD_wCmd(0x38); LCD_wCmd(0x38); LCD_wCmd(0x38);
LCD_wCmd(0x0c); LCD_wCmd(0x01);
LCD_Str("if");
_delay_ms(100);
return 0;
조회수 5,038등록된 댓글이 없습니다.
