질문게시판 > 답변 : ATMEGA 코드에 오류가 있을까요?
TODAY285 TOTAL2,271,752
BASIC4MCU | 질문게시판 | 답변 : ATMEGA 코드에 오류가 있을까요?
작성자 master 작성일2022-06-15 18:33 조회396회 댓글1건
#include <mega16.h>
#include <delay.h>
#define SW1   PINA.7
#define SW2   PINA.6
#define SW3   PINA.5
#define SW4   PIND.7
#define SD    PINA.4
#define SC    PINA.3
#define SB    PINA.2
#define SA    PINA.1
#define H     PINC.7
#define G     PINC.6
#define F     PINC.5
#define E     PINC.4
#define D     PINC.3
#define C     PINC.2
#define B     PINC.1
#define A     PINC.0
#define FB    PORTB.7
#define FA    PORTB.6
#define IN2   PORTB.5
#define IN1   PORTB.4
#define SCK   PORTB.2
#define RCK   PORTB.1
#define SER   PORTB.0
#define reset PORTA.0
#define SCK2  PORTD.5
#define RCK2  PORTD.4
#define SER2  PORTD.2
void shiftout(unsigned char num){
  unsigned char maski,i;
  maski=0x80; //maski=10000000
  i=8;
  while(i){
    if(num&maski){SER=1;} else{SER=0;}
    SCK=1;SCK=0;
    maski>>=1;
    i--;
void shiftout2(unsigned char num){
  i=8;
  while(i){
    if(num&maski){SER2=1;} else{SER2=0;}
    SCK2=1;SCK2=0;
    maski>>=1;
    i--;
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void){ delay_ms(50); }
void main(void){
  //cf=current floor, tf=target floor, df=delta floor
  unsigned char cf, tf, df, s, k, n, n1, n10, ibcd;
  DDRA=0x01; PORTA=0x00; DDRB=0xff; PORTB=0x80;
  DDRC=0x00; PORTC=0x00; DDRD=0x34; PORTD=0x00;
  TCCR0=(1<<WGM00)|(1<<COM01)|(0<<COM00)|(1<<WGM01)|(0<<CS02)|(1<<CS01)|(1<<CS00);
  TCNT0=0x00;
  OCR0=0x00;
  GICR|=(0<<INT1)|(1<<INT0)|(0<<INT2);
  MCUCR=(0<<ISC11)|(0<<ISC10)|(1<<ISC01)|(0<<ISC00);
  MCUCSR=(0<<ISC2);
  GIFR=(0<<INTF1)|(1<<INTF0)|(0<<INTF2);
  cf=1;            // 프로그램 내부적으로 현재층=1층으로 설정
  tf=1;            // 프로그램 내부적으로 목표층=1층으로 설정
  FB=0;FA=1;       // 세븐세그먼트에 현재층 1층 표시
  IN1=0;IN2=0;     // motor break
  reset=1;reset=0; // 카운터 reset
  shiftout(0x37);  // 두 자리 세븐세그먼트에 카운터값 37로 표시
  RCK=1;RCK=0;
  k=0; //while(k)deactivated
  if(SW4==0){
    ibcd=0x41;
    shiftout2(ibcd);
    RCK2=1; RCK2=0;
      //target floor setting
      if(SW1==0){ tf=1;
        if(SW4==0){ ibcd=0x59; shiftout2(ibcd); RCK2=1; RCK2=0; }
      if(SW2==0){ tf=2;
      if(SW3==0){ tf=3;
      //회전량 및 회전방향 설정
      if(tf>cf){
        df=(tf-cf)*20;   // 한 층=20 slits, 두 층=40 slits
        IN1=1;IN2=0;     // 모터 회전방향 CW
        k=1; //while(k)activated
      if(tf<cf){
        df=(cf-tf)*20;   // 한 층=20 slits
        IN1=0;IN2=1;     // 모터 회전방향 CCW
      while(k){
        //read speed value from BCD switch
        s=0;
        if(SA==0)s=s+1; if(SB==0)s=s+2; if(SC==0)s=s+4; if(SD==0)s=s+8;
        OCR0=50+s*20; //duty를 인가하여 모터회전 시작
        //카운터 일의 자리 BCD값 읽음
        n1=0;
        if(A==1)n1=n1+1; if(B==1)n1=n1+2; if(C==1)n1=n1+4; if(D==1)n1=n1+8;
        //카운터 십의 자리 BCD값 읽음
        n10=0;
        if(E==1)n10=n10+1; if(F==1)n10=n10+2; if(G==1)n10=n10+4; if(H==1)n10=n10+8;
        n=n10*10+n1; //카운터값 구성
        //카운터값 표시
        shiftout((n/10)*16+(n%10));
        RCK=1;RCK=0;
        if(df-n<=0){   // 목표 회전량이 만족되면
          OCR0=0;      // motor stop
          IN1=0;IN2=0; // motor brake
          cf=tf; //현재층=목표층
          //현재층 표시
          if(cf==1){ FB=0; FA=1; } if(cf==2){ FB=1; FA=0; } if(cf==3){ FB=1; FA=1; }
      } //while(k)의 끝
    } //while(1)의 끝
  }//if(SW4==0)의 끝
} //void main의 끝
디버깅도 학습입니다.
자기가 작성한 코드조차 디버깅 하지 못하면 코딩을 못하는 사람이라고 봐야겠죠
들여쓰기만 잘해도 디버깅 하기 편합니다.
조회수 396
skanl님의 댓글
skanl 작성일
정말로 감사합니다!
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 216
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 282
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 298
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 658
질문 피에조 부저로 맬로디 만들기인대 코딩 까지 했는데 아두이노 가 동작을 안해요.댓글[2] 이미지첨부파일 mingu123 22-07-15 1650
질문 블루투스와 안드로이드 연동관련 질문입니다! ㅎㅇㅎㅇ 22-07-14 418
질문 아두이노간 블루투스 통신에 대해서 질문있습니다 첨부파일 뉴비에오 22-07-13 182
답변 답변글 답변 : 아두이노간 블루투스 통신에 대해서 질문있습니다댓글[3] master 22-07-14 304
질문 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다. keem 22-07-11 234
답변 답변글 답변 : 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다.댓글[4] master 22-07-11 307
질문 아두이노 키패드 질문 면지지 22-07-10 218
답변 답변글 답변 : 아두이노 키패드 질문 master 22-07-11 253
질문 초음파 센서와 dc모터 질문있습니다. 첨부파일 뉴비에오 22-07-09 212
답변 답변글 답변 : 초음파 센서와 dc모터 질문있습니다.댓글[1] master 22-07-10 207
질문 PID 제어에 대해 질문 드립니다댓글[1] 이미지 miniPCR 22-07-09 175
질문 아두이노 질문 드립니다댓글[4] 김형근 22-07-08 358
질문 앱인벤터 list index too large 오류 질문입니다. 도와주세요ㅜㅜ댓글[11] 이미지첨부파일 PT규 22-07-07 676
질문 Atmega IO핀 출력 상태 질문이요..댓글[3] chelsea 22-07-06 401
답변 답변글 답변 : Atmega IO핀 출력 상태 질문이요..댓글[6] master 22-07-06 556
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통신댓글[6] 이미지첨부파일 AutoSun 22-07-05 631
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다. 첨부파일 뉴비에오 22-07-04 352
답변 답변글 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다.댓글[2] master 22-07-05 425
질문 아두이노 Sensor Shield 5.0 시리얼 통신 질문댓글[2] AutoSun 22-07-04 349
질문 Atmega 코드 좀 봐주세요.댓글[1] 첨부파일 chelsea 22-07-04 404
질문 아두이노 while문 탈출 질문 yhj2644 22-07-01 542
답변 답변글 답변 : 아두이노 while문 탈출 질문댓글[8] master 22-07-01 746
질문 ESP32-C3 리튬폴리머 ADC 전압 체크 관련 문의 (2)댓글[3] 이미지 cansad 22-06-30 312
질문 ESP32-C3 리튬폴리머 ADC 전압 체크 관련 문의댓글[3] cansad 22-06-30 442
질문 빵판없이 디스플레이 넣을 수 있을까요?댓글[2] 이미지첨부파일 오소로롯 22-06-29 341
질문 라즈베리파이4 신형 선택문제댓글[1] maximum 22-06-26 336
