질문게시판 > 답변 : ATMEGA 코드에 오류가 있을까요?
TODAY68 TOTAL2,325,725
BASIC4MCU | 질문게시판 | 답변 : ATMEGA 코드에 오류가 있을까요?
작성자 master 작성일2022-06-15 18:33 조회906회 댓글1건
#include <mega16.h>
#include <delay.h>
#define SW1   PINA.7
#define SW2   PINA.6
#define SW3   PINA.5
#define SW4   PIND.7
#define SD    PINA.4
#define SC    PINA.3
#define SB    PINA.2
#define SA    PINA.1
#define H     PINC.7
#define G     PINC.6
#define F     PINC.5
#define E     PINC.4
#define D     PINC.3
#define C     PINC.2
#define B     PINC.1
#define A     PINC.0
#define FB    PORTB.7
#define FA    PORTB.6
#define IN2   PORTB.5
#define IN1   PORTB.4
#define SCK   PORTB.2
#define RCK   PORTB.1
#define SER   PORTB.0
#define reset PORTA.0
#define SCK2  PORTD.5
#define RCK2  PORTD.4
#define SER2  PORTD.2
void shiftout(unsigned char num){
  unsigned char maski,i;
  maski=0x80; //maski=10000000
  i=8;
  while(i){
    if(num&maski){SER=1;} else{SER=0;}
    SCK=1;SCK=0;
    maski>>=1;
    i--;
void shiftout2(unsigned char num){
  i=8;
  while(i){
    if(num&maski){SER2=1;} else{SER2=0;}
    SCK2=1;SCK2=0;
    maski>>=1;
    i--;
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void){ delay_ms(50); }
void main(void){
  //cf=current floor, tf=target floor, df=delta floor
  unsigned char cf, tf, df, s, k, n, n1, n10, ibcd;
  DDRA=0x01; PORTA=0x00; DDRB=0xff; PORTB=0x80;
  DDRC=0x00; PORTC=0x00; DDRD=0x34; PORTD=0x00;
  TCCR0=(1<<WGM00)|(1<<COM01)|(0<<COM00)|(1<<WGM01)|(0<<CS02)|(1<<CS01)|(1<<CS00);
  TCNT0=0x00;
  OCR0=0x00;
  GICR|=(0<<INT1)|(1<<INT0)|(0<<INT2);
  MCUCR=(0<<ISC11)|(0<<ISC10)|(1<<ISC01)|(0<<ISC00);
  MCUCSR=(0<<ISC2);
  GIFR=(0<<INTF1)|(1<<INTF0)|(0<<INTF2);
  cf=1;            // 프로그램 내부적으로 현재층=1층으로 설정
  tf=1;            // 프로그램 내부적으로 목표층=1층으로 설정
  FB=0;FA=1;       // 세븐세그먼트에 현재층 1층 표시
  IN1=0;IN2=0;     // motor break
  reset=1;reset=0; // 카운터 reset
  shiftout(0x37);  // 두 자리 세븐세그먼트에 카운터값 37로 표시
  RCK=1;RCK=0;
  k=0; //while(k)deactivated
  if(SW4==0){
    ibcd=0x41;
    shiftout2(ibcd);
    RCK2=1; RCK2=0;
      //target floor setting
      if(SW1==0){ tf=1;
        if(SW4==0){ ibcd=0x59; shiftout2(ibcd); RCK2=1; RCK2=0; }
      if(SW2==0){ tf=2;
      if(SW3==0){ tf=3;
      //회전량 및 회전방향 설정
      if(tf>cf){
        df=(tf-cf)*20;   // 한 층=20 slits, 두 층=40 slits
        IN1=1;IN2=0;     // 모터 회전방향 CW
        k=1; //while(k)activated
      if(tf<cf){
        df=(cf-tf)*20;   // 한 층=20 slits
        IN1=0;IN2=1;     // 모터 회전방향 CCW
      while(k){
        //read speed value from BCD switch
        s=0;
        if(SA==0)s=s+1; if(SB==0)s=s+2; if(SC==0)s=s+4; if(SD==0)s=s+8;
        OCR0=50+s*20; //duty를 인가하여 모터회전 시작
        //카운터 일의 자리 BCD값 읽음
        n1=0;
        if(A==1)n1=n1+1; if(B==1)n1=n1+2; if(C==1)n1=n1+4; if(D==1)n1=n1+8;
        //카운터 십의 자리 BCD값 읽음
        n10=0;
        if(E==1)n10=n10+1; if(F==1)n10=n10+2; if(G==1)n10=n10+4; if(H==1)n10=n10+8;
        n=n10*10+n1; //카운터값 구성
        //카운터값 표시
        shiftout((n/10)*16+(n%10));
        RCK=1;RCK=0;
        if(df-n<=0){   // 목표 회전량이 만족되면
          OCR0=0;      // motor stop
          IN1=0;IN2=0; // motor brake
          cf=tf; //현재층=목표층
          //현재층 표시
          if(cf==1){ FB=0; FA=1; } if(cf==2){ FB=1; FA=0; } if(cf==3){ FB=1; FA=1; }
      } //while(k)의 끝
    } //while(1)의 끝
  }//if(SW4==0)의 끝
} //void main의 끝
디버깅도 학습입니다.
자기가 작성한 코드조차 디버깅 하지 못하면 코딩을 못하는 사람이라고 봐야겠죠
들여쓰기만 잘해도 디버깅 하기 편합니다.
조회수 906
skanl님의 댓글
skanl 작성일
정말로 감사합니다!
질문 레오나르도 인체감지센서 알림 안옴 면지지 22-07-24 750
답변 답변글 답변 : 레오나르도 인체감지센서 알림 안옴 master 22-07-25 703
질문 Uno에서 엔코더값 놓치는 이유가 뭘까요...댓글[3] MAKTUB 22-07-24 867
질문 아두이노 압력센서 연동 질문댓글[4] dbice 22-07-23 1384
질문 아두이노 버튼 누르기 문의댓글[1] 김형근 22-07-23 884
질문 HM10 다중페어링댓글[1] ㅎㅋㅎㅋㅎ 22-07-22 751
질문 모터드라이브 선정댓글[6] 이미지 조숩인 22-07-22 1088
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 1225
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 1026
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 1275
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 2894
질문 피에조 부저로 맬로디 만들기인대 코딩 까지 했는데 아두이노 가 동작을 안해요.댓글[2] 이미지첨부파일 mingu123 22-07-15 2508
질문 블루투스와 안드로이드 연동관련 질문입니다! ㅎㅇㅎㅇ 22-07-14 730
질문 아두이노간 블루투스 통신에 대해서 질문있습니다 첨부파일 뉴비에오 22-07-13 508
답변 답변글 답변 : 아두이노간 블루투스 통신에 대해서 질문있습니다댓글[3] master 22-07-14 1188
질문 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다. keem 22-07-11 1339
답변 답변글 답변 : 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다.댓글[4] master 22-07-11 1662
질문 아두이노 키패드 질문 면지지 22-07-10 1029
답변 답변글 답변 : 아두이노 키패드 질문 master 22-07-11 1147
질문 초음파 센서와 dc모터 질문있습니다. 첨부파일 뉴비에오 22-07-09 714
답변 답변글 답변 : 초음파 센서와 dc모터 질문있습니다.댓글[1] master 22-07-10 656
질문 PID 제어에 대해 질문 드립니다댓글[1] 이미지 miniPCR 22-07-09 656
질문 아두이노 질문 드립니다댓글[4] 김형근 22-07-08 1496
질문 앱인벤터 list index too large 오류 질문입니다. 도와주세요ㅜㅜ댓글[11] 이미지첨부파일 PT규 22-07-07 2151
질문 Atmega IO핀 출력 상태 질문이요..댓글[3] chelsea 22-07-06 1562
답변 답변글 답변 : Atmega IO핀 출력 상태 질문이요..댓글[6] master 22-07-06 2705
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통신댓글[6] 이미지첨부파일 AutoSun 22-07-05 3172
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다. 첨부파일 뉴비에오 22-07-04 1815
답변 답변글 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다.댓글[2] master 22-07-05 2086
질문 아두이노 Sensor Shield 5.0 시리얼 통신 질문댓글[2] AutoSun 22-07-04 1718
