질문게시판 > 답변 : 안녕하세요! 아두이노 로봇팔 질문!
TODAY266 TOTAL2,271,733
BASIC4MCU | 질문게시판 | 답변 : 안녕하세요! 아두이노 로봇팔 질문!
작성자 master 작성일2022-06-16 12:49 조회670회 댓글0건
#include <Servo.h>
Servo sv1;
Servo sv2;
Servo sv3;
Servo sv4;
int button_exe=A1;
int button_save=A0;
int button_up1=13,button_dn1=12;
int button_up2=11,button_dn2=10;
int button_up3=9,button_dn3=8;
int button_up4=7,button_dn4=6;
int number=0,i,max;
int robot[4]={0,};
byte save[300][4]={0,};
bool flag=0;
  pinMode(button_exe,INPUT_PULLUP);
  pinMode(button_save,INPUT_PULLUP);
  pinMode(button_up1,INPUT_PULLUP); pinMode(button_dn1,INPUT_PULLUP);
  pinMode(button_up2,INPUT_PULLUP); pinMode(button_dn2,INPUT_PULLUP);
  pinMode(button_up3,INPUT_PULLUP); pinMode(button_dn3,INPUT_PULLUP);
  pinMode(button_up4,INPUT_PULLUP); pinMode(button_dn4,INPUT_PULLUP);
  sv1.attach(5); sv2.attach(4); sv3.attach(3); sv4.attach(2);
int max_calc0(){
  int x=0,d;
  for(i=0;i<4;i++){
    d=abs(save[0][i]-robot[i]);
    if(d>x)x=d;
  return x;
int max_calc(int n){ // 모터 이동 최대 각도 계산
  int x=0,d;
  for(i=0;i<4;i++){
    d=abs(save[n][i]-save[n-1][i]);
    if(d>x)x=d;
  return x;
  if(digitalRead(button_dn1)==LOW){ if(robot[0]<180)robot[0]++; delay(10); }
  if(digitalRead(button_up1)==LOW){ if(robot[0]>  0)robot[0]--; delay(10); }
  if(digitalRead(button_up2)==LOW){ if(robot[1]< 90)robot[1]++; delay(10); }
  if(digitalRead(button_dn2)==LOW){ if(robot[1]>  0)robot[1]--; delay(10); }
  if(digitalRead(button_up3)==LOW){ if(robot[2]<180)robot[2]++; delay(10); }
  if(digitalRead(button_dn3)==LOW){ if(robot[2]> 90)robot[2]--; delay(10); }
  if(digitalRead(button_up4)==LOW){ if(robot[3]<130)robot[3]++; delay(10); }
  if(digitalRead(button_dn4)==LOW){ if(robot[3]>  0)robot[3]--; delay(10); }
  sv1.write(robot[0]); sv2.write(robot[1]); sv3.write(robot[2]); sv4.write(robot[3]);
  if(digitalRead(button_save)==LOW){ // 스위치 누르면
    if(flag==0){ flag=1;             // 하강엣지 검출
      for(i=0;i<4;i++)save[number][i]=robot[i];
      if(++number>=300){ number=0;
        for(int n=0;n<300;n++){
          for(i=0;i<4;i++)save[n][i]=0;
      delay(50); // 채터링 방지
  else{ // 스위치 누르지 않으면
    if(flag){ flag=0; delay(50); } // 상승엣지 검출 // 채터링 방지
  if(digitalRead(button_exe)==LOW){
    // 첫번째 값으로 이동
    if(save[0][0]){ // 저장된 값이 0이 아니면
      sv1.write(save[0][0]); sv2.write(save[0][1]); sv3.write(save[0][2]); sv4.write(save[0][3]);
      max=max_calc0();
      delay(max*5); // 각도 차이의 5배 딜레이를 줌(모터가 이동 할 수 있는 시간 확보)
      for(i=1;i<300;i++){
        if(save[i][0]==0)break; // 저장된 값이 0이면 루프 종료
        sv1.write(save[i][0]); sv2.write(save[i][1]); sv3.write(save[i][2]); sv4.write(save[i][3]);
        max=max_calc(i);
    number=0;
수정 안된 부분이 있어서 수정했습니다.
일단 컴파일 오류는 처리 되었으니
잘 디버깅해서 원하는 대로 완성시켜보세요
조회수 670
질문 ad9850 sin파 2댓글[6] 이미지첨부파일 opqr 22-07-21 216
질문 ad9850 sin파 합성댓글[7] 첨부파일 opqr 22-07-20 282
질문 특정값이 n초이상,n번 이상 연속될경우를 감지하는 함수가 있나요댓글[4] 우수 22-07-17 298
질문 delay를 millis함수로 바꾸는데 질문있습니다.댓글[12] 첨부파일 뉴비에오 22-07-16 657
질문 피에조 부저로 맬로디 만들기인대 코딩 까지 했는데 아두이노 가 동작을 안해요.댓글[2] 이미지첨부파일 mingu123 22-07-15 1650
질문 블루투스와 안드로이드 연동관련 질문입니다! ㅎㅇㅎㅇ 22-07-14 418
질문 아두이노간 블루투스 통신에 대해서 질문있습니다 첨부파일 뉴비에오 22-07-13 182
답변 답변글 답변 : 아두이노간 블루투스 통신에 대해서 질문있습니다댓글[3] master 22-07-14 304
질문 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다. keem 22-07-11 233
답변 답변글 답변 : 아두이노 스탭모터, 모터드라이버, SMPS 관련하여 질문드립니다.댓글[4] master 22-07-11 307
질문 아두이노 키패드 질문 면지지 22-07-10 217
답변 답변글 답변 : 아두이노 키패드 질문 master 22-07-11 253
질문 초음파 센서와 dc모터 질문있습니다. 첨부파일 뉴비에오 22-07-09 212
답변 답변글 답변 : 초음파 센서와 dc모터 질문있습니다.댓글[1] master 22-07-10 207
질문 PID 제어에 대해 질문 드립니다댓글[1] 이미지 miniPCR 22-07-09 175
질문 아두이노 질문 드립니다댓글[4] 김형근 22-07-08 358
질문 앱인벤터 list index too large 오류 질문입니다. 도와주세요ㅜㅜ댓글[11] 이미지첨부파일 PT규 22-07-07 676
질문 Atmega IO핀 출력 상태 질문이요..댓글[3] chelsea 22-07-06 401
답변 답변글 답변 : Atmega IO핀 출력 상태 질문이요..댓글[6] master 22-07-06 556
질문 아두이노 센서 쉴드 v5.0 과 음성인식 모듈(V2)통신댓글[6] 이미지첨부파일 AutoSun 22-07-05 631
질문 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다. 첨부파일 뉴비에오 22-07-04 352
답변 답변글 답변 : 초음파 센서를 사용한 dc모터 제어에 관해 질문 있습니다.댓글[2] master 22-07-05 423
질문 아두이노 Sensor Shield 5.0 시리얼 통신 질문댓글[2] AutoSun 22-07-04 349
질문 Atmega 코드 좀 봐주세요.댓글[1] 첨부파일 chelsea 22-07-04 403
질문 아두이노 while문 탈출 질문 yhj2644 22-07-01 542
답변 답변글 답변 : 아두이노 while문 탈출 질문댓글[8] master 22-07-01 746
질문 ESP32-C3 리튬폴리머 ADC 전압 체크 관련 문의 (2)댓글[3] 이미지 cansad 22-06-30 312
질문 ESP32-C3 리튬폴리머 ADC 전압 체크 관련 문의댓글[3] cansad 22-06-30 442
질문 빵판없이 디스플레이 넣을 수 있을까요?댓글[2] 이미지첨부파일 오소로롯 22-06-29 341
질문 라즈베리파이4 신형 선택문제댓글[1] maximum 22-06-26 336
