질문게시판 > 답변 : 서보모터, 온습도센서 코드 질문
TODAY96 TOTAL2,325,753
BASIC4MCU | 질문게시판 | 답변 : 서보모터, 온습도센서 코드 질문
작성자 master 작성일2022-06-22 14:15 조회4,125회 댓글15건
#include <MsTimer2.h>
#include <Servo.h>
#include <Wire.h>
#include "DHT.h"
#define DHTPIN 4        // SDA 핀의 설정
#define DHTTYPE DHT22   // DHT22(AM2302)센서종류 설정
DHT dht(DHTPIN,DHTTYPE);
SoftwareSerial BTserial(8,9); //블루투스 연결
Servo myservo1;// create servo object to control a servo
Servo myservo2;// twelve servo objects can be created on most boards
int Sensor=A1;
int speakerPin=12;
char notes[]="ccggaag ffeeddc ggffeed ggffeed ccggaag ffeeddc ";
int beats[]={ 1,1,1,1,1,1,2,1,1,1,1,1,1,2,4 };
int tempo=300;
volatile int pos=0,length=15,len=0,run=0;
void playTone(int tone,int duration){ //자장가 출력1
  for(long len=0;len<duration*1000L; len+=tone*2){
    digitalWrite(speakerPin,1); delayMicroseconds(tone);
    digitalWrite(speakerPin,0); delayMicroseconds(tone);
void playNote(char note,int duration){ //자장가 출력2
  char names[]={ 'c','d','e','f','g','a','b','C' };
  int tones[]={ 2015,1800,1619,1532,1375,1236,1114,1056 };
  for(int len=0; len < 8; len++){
    if(names[len]==note)playTone(tones[len],duration);
void flash(){ //서보모터 작동
  if(run){
    if     (len< 5){ if(pos<100)pos++; }
    else if(len< 9){ if(pos>  0)pos--; }
    else if(len<14){ if(pos<100)pos++; }
    else           { if(pos>  0)pos--; }
    myservo1.write(pos);
    myservo2.write(pos);
    pos=0; myservo1.write(0); myservo2.write(0);
  pinMode(Sensor,INPUT);
  pinMode(speakerPin,OUTPUT);
  myservo1.attach(6);
  myservo2.attach(5);
  dht.begin();
  BTserial.begin(9600);
  MsTimer2::set(20,flash); // flash함수를 20ms마다 호출한다
  MsTimer2::start();
  int Sound=analogRead(Sensor);
  Serial.println(Sound);
  if(Sound>130){ //소리가 130이상이면
    run=1;
    for(len=0;len<length;len++){
      if(notes[len]==' '){ delay(beats[len]*tempo); }
      else { playNote(notes[len],beats[len]*tempo); }
      delay(tempo/2);
    run=0;
  float t=dht.readTemperature(); //온도 읽어옴
  float h=dht.readHumidity();    //습도 읽어옴
  if(isnan(t)|| isnan(h)){ Serial.println("Failed to read from DHT"); } //값 읽기 실패시 시리얼 모니터 출력
  else{ //온도,습도 표시 시리얼 모니터 출력
    //Serial.print("Temperature: "); Serial.print(t); Serial.print(" ºC\t");
    //Serial.print("Humidity: ");    Serial.print(h); Serial.println(" % rH");
  BTserial.print(t); BTserial.println(" ºC");
  BTserial.print(h); BTserial.println(" %");
  if(t>=29 && h>=80)BTserial.println("O"); else BTserial.println("X");
동영상이 안보이니 증상을 정확히는 모르겠고..(무슨 유료 코덱을 설치 하라고 해서 패스)
코드에서 특별히 눈에 띄는 부분은 없습니다.
댓글 15
조회수 4,125
kshdlfaldfh님의 댓글
kshdlfaldfh 작성일
이거 카카오 팟플레이어 깔고 거기서 열면 볼 수 있습니다!
둘 중의 하나만 움직이는 것이 맞나요? myservo1? myservo2? 어느쪽 모터죠?
움직이는 각도는 0도~100도인가요? 그보다 적나요?
kshdlfaldfh님의 댓글
kshdlfaldfh 댓글의 댓글 작성일
둘 다 움직이고 100도까지는 아니고 엄청 조금만 왔다갔다 합니다! 마지막에 있는 delay가 문제가 될 가능성은 없나요??
run=0;
이 변수를 설정하기 때문에 마지막 딜레이와 상관이 없습니다.
  static char flag=0;
  if(run){ flag=0;
    if(flag==0){ flag=1;
인터럽트 함수를 변경해서 돌려보세요
kshdlfaldfh님의 댓글
처음이랑 똑같습니다ㅜㅜ
선이 길어서 케이블에 노이즈가 탈까요?
왜 혼자서 움직일까요?
kshdlfaldfh님의 댓글
#include <Servo.h>
int Sensor = A1;
int speakerPin = 12;
char notes[] = "ccggaag ffeeddc ggffeed ggffeed ccggaag ffeeddc ";
int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };
int tempo = 300;
void playTone(int tone, int duration) { //자장가 출력1
  for (long len = 0; len < duration * 1000L; len += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) { //자장가 출력2
  char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
  int tones[] = { 2015, 1800, 1619, 1532, 1375, 1236, 1114, 1056 };
  for (int len = 0; len < 8; len++) {
    if (names[len] == note) {
      playTone(tones[len], duration);
void flash() { //서보모터 작동
  if(run){
  myservo1.attach(6);
  myservo2.attach(5);// attaches the servo on pin 5,6 to the servo object
  pinMode(speakerPin, OUTPUT);
  MsTimer2::set(20,flash);// flash함수를 20ms마다 호출한다
  MsTimer2::start();
 int Sound = analogRead(Sensor);
 if (Sound > 130) { //소리가 130이상이면
    run=1;
    for (len=0;len<length;len++){
      if (notes[len]==' ') { delay(beats[len] * tempo); }
      else { playNote(notes[len], beats[len] * tempo); }
      delay(tempo / 2);
    run=0;
단순히 서보모터만 실행했을 때는 잘 실행됩니다.
#include <Wire.h>
#include "DHT.h"
#define DHTTYPE DHT22  // DHT22 (AM2302) 센서종류 설정
DHT dht(DHTPIN, DHTTYPE);
  dht.begin();
  float t = dht.readTemperature(); //온도 읽어옴
  float h = dht.readHumidity();    //습도 읽어옴
  if (isnan(t) || isnan(h)) { //값 읽기 실패시 시리얼 모니터 출력
  } else { //온도, 습도 표시 시리얼 모니터 출력
    Serial.print(t);
    Serial.print(h);
  BTserial.print(t);
  BTserial.print(h);
  if(t >=29 and h >= 80) { //온도가 29도가 넘고 습도가 80%가 넘을시
    BTserial.println("기저귀를 확인하세요."); //출력
  } else{
    BTserial.println("기저귀가 뽀송합니다.");
이 코드와 합치면서 문제가 생긴 듯해요..ㅜ^ㅜ
myservo1.attach(6);
  myservo2.attach(5);
서보모터를 9번 10번으로 옮겨서 돌려보세요 ( 3번 11번도 있습니다.)
다른핀이 이미 사용하고 있다면 그 핀도 옮기세요
kshdlfaldfh님의 댓글
3,11과 9,10번으로 옮겨도 똑같네요 대체 뭐가 문제인지 ㅜㅜ
PWM핀이 아닌 곳으로 옮겨보세요
타이머 충돌 때문에 생기는 것 같습니다.
DHT도 타이머2를 사용합니다.
kshdlfaldfh님의 댓글
9,10이 PWM핀이 아닌 곳 아닌가요?
PWM핀은 보드에 적혀있자나요?
이런 내용까지 질문하시면 곤란합니다.
kshdlfaldfh님의 댓글
PWM 아닌 4,7번에 서보모터 옮겼는데 똑같아요ㅜ
#include "DHT.h"
둘 중 하나에서 서보모터와 타이머 충돌이 있는 것으로 생각됩니다.
해결 방법은 간단하지 않을 것 같습니다.
아두이노 메가를 사용하고 타이머와 라이브러리를 공부하면 될 것 같기는 한데
초보자에겐 쉽지 않을테니...
kshdlfaldfh님의 댓글
그래도 도움 주셔서 감사합니다...!!!
질문 아두이노와 로드셀을 이용한 속도제어댓글[2] wns130314 22-08-24 177
질문 아두이노 센서 3개 연결해서 PLX-DAQ-v2.10로 결과값을 받고싶어요..댓글[8] 생물공학도 22-08-24 348
질문 버튼 하나로 기능 유지 질문드립니다.댓글[5] 에그젤리 22-08-24 231
질문 아두이노 우노 IRremote 송신 코드 질문댓글[3] 남세이 22-08-22 315
질문 LED 스위치댓글[3] 픽공부 22-08-22 259
질문 아두이노 코딩 결합댓글[1] hohoje 22-08-18 197
질문 UART통신 스위치 사용댓글[4] 픽공부 22-08-18 284
질문 아두이노코딩 질문사항댓글[1] kai5439 22-08-16 203
질문 해석좀 해주세요댓글[2] bubu 22-08-14 277
질문 lcd 1602에 특수문자를 출력하는 방법을 알고싶습니다.댓글[3] dndktn 22-08-12 301
질문 stm32 wifi 파일전송댓글[4] 하리 22-08-11 358
질문 회로 구성 수정댓글[2] 첨부파일 픽공부 22-08-11 235
질문 아두이노 와이파이통신 질문 있습니다댓글[1] 학생 22-08-11 201
질문 포토다이오드와의 연결 질문합니다.댓글[7] 이미지첨부파일 박윤모 22-08-10 511
질문 회로 구성댓글[4] 픽공부 22-08-10 316
질문 아두이노 센서, 와이파이, 블루투스 연결댓글[1] pattern 22-08-10 310
질문 PIC 블루투스 연결댓글[19] 픽공부 22-08-09 1868
질문 PIC18F452 블루투스 연결댓글[4] 마이컴 22-08-08 462
질문 아두이노 코드 해석을 못하겠습니다...댓글[2] 김가헌 22-08-08 304
질문 아두이노 코드를 avr로 변환해 주세요 ...ㅠ댓글[3] 옹냥냥 22-08-08 313
질문 아두이노 녹음-스피커모듈 관련 질문있습니다 ㅠㅠ댓글[2] 방귀뿡뿡 22-08-08 230
질문 Serial EEPROM 실수값 저장..댓글[2] 이미지첨부파일 광이 22-08-07 187
질문 STM32 Live Expression 값들이 깜빡이는 현상댓글[3] 둠둠 22-08-05 490
질문 아두이노 ESP32 wifi module댓글[1] Yoon 22-08-03 728
질문 atmega128과 dht11, lcd를 연결했는데 0도라고 뜹니다.댓글[1] 고양이33 22-08-02 1763
질문 ATMEGA 128 코드를 합치려고 하는데 어렵네요댓글[2] 고양이33 22-08-02 1201
질문 서보모터 제어에 대해 질문있습니다.댓글[2] 첨부파일 뉴비에오 22-07-30 627
질문 적외선 통신 알려주실분있나요 ㅠㅠ댓글[1] hkjsj10 22-07-30 718
질문 아두이노 관련 궁금합니다.댓글[1] 뱝뱝 22-07-28 702
질문 아두이노 우노 MCP4725댓글[3] 이미지 opqr 22-07-27 1283
