질문게시판 > 답변 : 아두이노코드 합치기 문의드립니다!
TODAY761 TOTAL2,325,631
BASIC4MCU | 질문게시판 | 답변 : 아두이노코드 합치기 문의드립니다!
작성자 master 작성일2022-09-14 17:09 조회83회 댓글0건
#include <TinyGPS.h>
#define GPSBAUD 9600
TinyGPS gps;
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
MPU6050 accelgyro;
unsigned long now,lastTime=0,t2=0;
float dt;
int16_t ax,ay,az,gx,gy,gz;
float aax=0,aay=0,aaz=0,agx=0,agy=0,agz=0;
long axo=0,ayo=0,azo=0;
long gxo=0,gyo=0,gzo=0;
float pi=3.1415926;
float AcceRatio=16384.0;
float GyroRatio=131.0;
uint8_t n_sample=8;
float aaxs[8]={0},aays[8]={0},aazs[8]={0};
long aax_sum,aay_sum,aaz_sum;
float a_x[10]={0},a_y[10]={0},a_z[10]={0},g_x[10]={0},g_y[10]={0},g_z[10]={0};
float Px=1,Rx,Kx,Sx,Vx,Qx;
float Py=1,Ry,Ky,Sy,Vy,Qy;
float Pz=1,Rz,Kz,Sz,Vz,Qz;
uint8_t _hour,_minute,_second,_year,_month,_day; // GPS로부터 시간값 읽기
float latitude,longitude;
    Wire.begin();
    Serial.begin(115200);
    accelgyro.initialize();
    unsigned short times=200;
    for(int i=0;i<times;i++){
        accelgyro.getMotion6(&ax,&ay,&az,&gx,&gy,&gz);
        axo+=ax; ayo+=ay; azo+=az;
        gxo+=gx; gyo+=gy; gzo+=gz;
    axo/=times; ayo/=times; azo/=times;
    gxo/=times; gyo/=times; gzo/=times;
    Serial1.begin(GPSBAUD); Serial1.setTimeout(10); gps=TinyGPS();
    unsigned long now=millis();
    dt=(now-lastTime)/1000.0;
    lastTime=now;
    float accx=ax/AcceRatio;
    float accy=ay/AcceRatio;
    float accz=az/AcceRatio;
    aax=atan(accy/accz)*(-180)/pi;
    aay=atan(accx/accz)*180/pi;
    aaz=atan(accz/accy)*180/pi;
    aax_sum=0;
    aay_sum=0;
    aaz_sum=0;
    for(int i=1;i<n_sample;i++){
        aaxs[i-1]=aaxs[i]; aax_sum+=aaxs[i]*i;
        aays[i-1]=aays[i]; aay_sum+=aays[i]*i;
        aazs[i-1]=aazs[i]; aaz_sum+=aazs[i]*i;
    aaxs[n_sample-1]=aax; aax_sum+=aax*n_sample; aax=(aax_sum/(11*n_sample/2.0))*9/7.0;
    aays[n_sample-1]=aay; aay_sum+=aay*n_sample; aay=(aay_sum/(11*n_sample/2.0))*9/7.0;
    aazs[n_sample-1]=aaz; aaz_sum+=aaz*n_sample; aaz=(aaz_sum/(11*n_sample/2.0))*9/7.0;
    float gyrox=-(gx-gxo)/GyroRatio*dt;
    float gyroy=-(gy-gyo)/GyroRatio*dt;
    float gyroz=-(gz-gzo)/GyroRatio*dt;
    agx+=gyrox;
    agy+=gyroy;
    agz+=gyroz;
    /* kalman start */
    Sx=0; Rx=0;
    Sy=0; Ry=0;
    Sz=0; Rz=0;
    for(int i=1;i<10;i++){
        a_x[i-1]=a_x[i]; Sx+=a_x[i];
        a_y[i-1]=a_y[i]; Sy+=a_y[i];
        a_z[i-1]=a_z[i]; Sz+=a_z[i];
    a_x[9]=aax; Sx+=aax; Sx/=10;
    a_y[9]=aay; Sy+=aay; Sy/=10;
    a_z[9]=aaz; Sz+=aaz; Sz/=10;
    for(int i=0;i<10;i++){ Rx+=sq(a_x[i]-Sx); Ry+=sq(a_y[i]-Sy); Rz+=sq(a_z[i]-Sz); }
    Rx=Rx/9;
    Ry=Ry/9;
    Rz=Rz/9;
    Px=Px+0.0025; Kx=Px/(Px+Rx); agx=agx+Kx*(aax-agx); Px=(1-Kx)*Px;
    Py=Py+0.0025; Ky=Py/(Py+Ry); agy=agy+Ky*(aay-agy); Py=(1-Ky)*Py;
    Pz=Pz+0.0025; Kz=Pz/(Pz+Rz); agz=agz+Kz*(aaz-agz); Pz=(1-Kz)*Pz;
    /* kalman end */
    Serial.print("\t FilteredX:"); Serial.print(agx);
    Serial.print("\t FilteredY:"); Serial.print(agy);
    Serial.print("\t FilteredZ:"); Serial.print(agz);Serial.println(); Serial.print("\n"); Serial.print("\n");
    if(millis()-t2>=10000){ t2=millis(); // 10초에 한번씩
    while(Serial1.available()){
        char c=Serial1.read();
        if(gps.encode(c))getgps(gps);
void getgps(TinyGPS &gps){
    gps.f_get_position(&latitude,&longitude);
    Serial.print("Lat/Long: "); Serial.print(latitude,5); Serial.print(","); Serial.println(longitude,5);
    int year;
    byte month,day,hour,minute,second,hundredths;
    gps.crack_datetime(&year,&month,&day,&hour,&minute,&second,&hundredths);
    // Print data and time
    Serial.print("Date: ");   Serial.print(month,DEC);  Serial.print("/"); Serial.print(day,DEC);    Serial.print("/"); Serial.print(year);
    Serial.print("  Time: "); Serial.print(hour+9,DEC); Serial.print(":"); Serial.print(minute,DEC); Serial.print(":"); Serial.print(second,DEC);
    Serial.print("."); Serial.println(hundredths,DEC);
    _year=year-2000; _month=month; _day=day; _hour=hour; _minute=minute; _second=second;
    Serial.print("Altitude(meters): "); Serial.println(gps.f_altitude());
    Serial.print("Course(degrees): ");  Serial.println(gps.f_course());
    Serial.print("Speed(kmph): ");      Serial.println(gps.f_speed_kmph()); Serial.println();
    unsigned long chars;
    unsigned short sentences,failed_checksum;
    gps.stats(&chars,&sentences,&failed_checksum);
    Serial.print("Failed Checksums: ");Serial.print(failed_checksum); Serial.println(); Serial.println();
1. 더 큰 소스를 기준으로, 작은 소스를 큰 소스에 넣으면 됩니다.
헤더파일, 변수, 셋업함수, 루프함수, 서브함수
각각의 위치에 넣고서
2. (회로적으로 또는 코드에서) 충돌하는 부분이 없도록 조정합니다.
3. 동작이 매끄럽도록 디버깅합니다.
조회수 83
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 13346
공지 사이트 이용 안내댓글[26] master 17-10-29 31749
질문 피에조 부저 일시정지 질문입니다. 새글 Tell 21:16 5
질문 아두이노 DC, 서보, 스텝모터 동시 제어가 가능할까요?댓글[1] 새글 jundorio8 12:52 17
질문 아두이노 신호등led 스위치 버튼 누를때마다 빨강-노랑-초록 변환댓글[1] 새글 고고라네 22-09-30 19
질문 이산화탄소 감지 및 창문 자동 개방 아두이노 코드 질문 새글 남폴스전 22-09-30 16
답변 답변글 답변 : 이산화탄소 감지 및 창문 자동 개방 아두이노 코드 질문 새글 master 22-09-30 9
질문 led하나 스위치 하나로 스위치가 눌릴때마다 변화댓글[1] 돌쇠 22-09-29 35
답변 답변글 답변 : 아두이노 led시간 늘리기 master 22-09-29 40
질문 아두이노로 영상출력이 가능할까요??댓글[1] 김보 22-09-27 63
질문 스위치를 이용한 led2개의 밝기 순차적으로 조절입니다.댓글[2] Tell 22-09-24 118
질문 avr로 매트랩 이용하고 싶은데 도와주세요 ㅠㅠ댓글[1] 지수진 22-09-22 90
질문 아두이노 리미트 스위치를 이용한 모터 제어댓글[4] 오모리 22-09-22 114
질문 아두이노 갑자기 기능구현 안됨댓글[1] 면지지 22-09-21 57
