질문게시판 > 답변 : 라인트레이서 조도센서 질
TODAY201 TOTAL2,592,722
BASIC4MCU | 질문게시판 | 답변 : 라인트레이서 조도센서 질
작성자 master 작성일2022-11-27 14:37 조회605회 댓글0건
int IN1=8,IN2=9,IN3=10,IN4=11;
int ULTRASENS_T=5,ULTRASENS_E=7;
int leftLineSensor=13,rightLineSensor=12;
int ENA=3,ENB=6;
void forward(){
  analogWrite(3,90); analogWrite(6,90);
  digitalWrite(IN1,1); digitalWrite(IN2,0); digitalWrite(IN3,1); digitalWrite(IN4,0);
void back() { digitalWrite(IN1,0); digitalWrite(IN2,1); digitalWrite(IN3,0); digitalWrite(IN4,1); }
void left() { digitalWrite(IN1,0); digitalWrite(IN2,0); digitalWrite(IN3,1); digitalWrite(IN4,0); }
void right(){ digitalWrite(IN1,1); digitalWrite(IN2,0); digitalWrite(IN3,0); digitalWrite(IN4,0); }
void stop() { digitalWrite(IN1,0); digitalWrite(IN2,0); digitalWrite(IN3,0); digitalWrite(IN4,0); }
void avd1(){ analogWrite(3,190); analogWrite(6,90); } // 회피 1차 동작
void avd2(){ analogWrite(3,90); analogWrite(6,190); } // 회피 2차 동작
void avd3(){ analogWrite(3,190); analogWrite(6,40); } // 회피 3차 동작
long howclose(){
  long duration=0,distance=0;
  digitalWrite(ULTRASENS_T,1); delayMicroseconds(10); digitalWrite(ULTRASENS_T,0);
  duration=pulseIn(ULTRASENS_E,1);
  distance=duration/29/2;
  Serial.print(distance); Serial.println("cm");
  return distance;
  pinMode(A4, INPUT);            pinMode(2, OUTPUT);
  pinMode(IN1,OUTPUT);           pinMode(IN2,OUTPUT); // A 모터
  pinMode(IN3,OUTPUT);           pinMode(IN4,OUTPUT); // B 모터
  pinMode(leftLineSensor,INPUT); pinMode(rightLineSensor,INPUT);
  pinMode(ULTRASENS_T,OUTPUT);   pinMode(ULTRASENS_E,INPUT);
  Serial.println(analogRead(A4)); // if 값은 주변 환경 조도값에 따라 변경
  if(analogRead(A4)<80)digitalWrite(2, HIGH); else digitalWrite(2, LOW);
  long distance=howclose();
  if(distance>20){
    if     (!digitalRead(leftLineSensor)&& !digitalRead(rightLineSensor)){ forward(); } // 양쪽 센서가    '미감지(반사신호OK) 경우 : 전진
    else if(!digitalRead(leftLineSensor)&&  digitalRead(rightLineSensor)){ left();    } // 왼쪽 센서만    '선감지(반사신호X)' 경우 : 좌회전
    else if( digitalRead(leftLineSensor)&& !digitalRead(rightLineSensor)){ right();   } // 오른쪽 센서만  '선감지(반사신호X)' 경우 : 우회전
    else if( digitalRead(leftLineSensor)&&  digitalRead(rightLineSensor)){ stop();    } // 양쪽 센서 모두 '선감지(반사신호X)' 경우 : 정지
  else if(distance<10){ stop(); delay(0); }
  else{ avd1(); delay(1300); avd2(); delay(2700); avd3(); delay(2000); } // 10 < distance < 20
조회수 605
질문 아두이노 근접센서 2개 연결 질문댓글[1] 김민종 23-03-29 27
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 79
질문 atmega128 압력센서 관련 질문입니다댓글[1] 공린이 23-03-19 95
질문 가스 센서를 쓰려면댓글[3] 테스터 23-02-08 298
질문 Ozone 2 click 센서를 쓰려고하는데댓글[1] 라칸 23-02-07 208
질문 ULPSM 센서의 bias 용도댓글[3] 이미지 라칸 23-02-02 322
질문 미세먼지 센서를 해보는데댓글[3] 라칸 23-01-30 318
질문 가스 센서 공식댓글[2] 이미지첨부파일 풀이싫은초식동물 23-01-27 295
질문 adc값 가지고 센서 측정값을 찾고 싶은데댓글[2] 라칸 23-01-25 316
질문 님들 센서 측정값 계산식 찾는법좀댓글[2] 라칸 23-01-13 311
질문 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F) 이미지 JCHJ 22-12-15 370
답변 답변글 답변 : 아두이노 a4988 스텝모터 + LCD 모니터 + 미세먼지 센서 (GP2Y1014AU0F)댓글[2] master 22-12-15 660
질문 atmega128 온도센서, 광센서, led2개, 스위치, 스피커 사용댓글[1] 졸업만도아주세윰 22-12-14 605
질문 아두이노 심박센서 및 LCD로 BPM나타내기 질문있습니다.댓글[2] 이미지첨부파일 공백 22-12-12 694
질문 Atmeg128a, 초음파센서, 서보모터 코드댓글[2] 전가스 22-12-12 725
질문 atmega128 초음파 센서 신장 측정 가나다라 22-12-12 378
답변 답변글 답변 : atmega128 초음파 센서 신장 측정 master 22-12-12 359
질문 도움이 필요합니다.. 충격감지 센서 연결댓글[1] 알쓰리 22-12-11 340
질문 atmega128 온도센서 질문입니다. 으아어려워 22-12-10 329
답변 답변글 답변 : atmega128 온도센서 질문입니다.댓글[1] master 22-12-10 424
질문 아두이노와 초음파 센서로 모터 제어 코드 질문있습니다. blackbunn 22-12-07 390
답변 답변글 답변 : 아두이노와 초음파 센서로 모터 제어 코드 질문있습니다.댓글[1] master 22-12-07 498
질문 온습도 센서와 L9110 FAN Module 모터구동 질문있습니다!!댓글[2] 진현 22-12-04 494
질문 2개의 초음파센서로 서보모터 하나 작동댓글[2] 이미지첨부파일 승천 22-12-03 570
답변 답변글 답변 : 2개의 초음파센서로 서보모터 하나 작동댓글[1] master 22-12-03 368
질문 초음파센서코드와 조도센서코드 합성하는 중입니다.댓글[4] 잉뚜 22-12-02 939
질문 아두이노 코딩을 바탕으로 atmega 128수위센서를 만들고 싶습니다.댓글[1] atmegaga123 22-12-01 605
질문 아두이노 특정 상황에서 초음파 센서가 작동을 안하는거 같습니다. KMMS 22-12-01 480
답변 답변글 답변 : 아두이노 특정 상황에서 초음파 센서가 작동을 안하는거 같습니다. master 22-12-01 538
질문 아두이노 화재센서 블루투스 연동 질문드립니다.댓글[1] 원할머니보고쌈 22-11-29 711
