질문게시판 > 답변 : atmega while문 도와주세요 ㅠㅠ
TODAY205 TOTAL2,582,284
BASIC4MCU | 질문게시판 | 답변 : atmega while문 도와주세요 ㅠㅠ
작성자 master 작성일2022-12-03 10:27 조회243회 댓글0건
1. 실시간 온도 fnd로 나타내기
2. 조도센서 이용해서 LED on,off
3. 초음파 거리센서 이용해서 버저 울리기
#define  F_CPU 16000000UL
#define  F_SCK 40000UL
#define LM75A_ADDR     0x90
#define LM75A_TEMP_REG 0
//모터
#define MOTOR_ON       0x40 //PB6=1
#define MOTOR_STOP     0x00 //PB6=0
#define TEM1           0x1400 //20도
//조도
#define CDS_10         341
int read_twi_2byte_nopreset(char reg){
  char high_byte,low_byte;
  TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x08);
  TWDR=LM75A_ADDR|0;
  TWCR=(1<<TWINT)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x18);
  TWDR=reg;
  TWCR=(1<<TWINT)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x28);
  TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x10);
  TWDR=LM75A_ADDR|1;
  TWCR=(1<<TWINT)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x40);
  TWCR=(1<<TWINT)|(1<<TWEN|1<<TWEA); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x50);
  high_byte=TWDR;
  TWCR=(1<<TWINT)|(1<<TWEN); while(((TWCR&(1<<TWINT))==0x00)||(TWSR&0xf8)!=0x58);
  low_byte=TWDR;
  TWCR=(1<<TWINT)|(1<<TWSTO)|(1<<TWEN); while((TWCR&(1<<TWSTO)));
  return((high_byte<<8)|low_byte);
void display_FND(int value){
  char digit[12]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7c,0x07,0x7f,0x67,0x00,0x40};
  char fnd_sel[4]={0x01,0x02,0x04,0x08};
  int value_int,value_deci,num[4],i;
  if((value&0x8000)!=0x8000)num[3]=10; else{ num[3]=11; value=(~value)+1; }
  value_int=value>>8; value_deci=value&0x80;
  num[2]=(value_int/10)%10; num[1]=value_int%10; num[0]=(value_deci==0x80)?5:0;
  for(i=0;i<4;i++){ PORTC=digit[num[i]]; PORTG=fnd_sel[i]; _delay_us(2500); }
int main(){
  unsigned int distance,i,value_zodo; int temperature=0;
  DDRB=0x50;                   // PB4 버저, MOTOR_ON(PB6)
  DDRE=0x40;                   // Trigger(PE6),Echo(PE7)
  DDRA=0x07;                   // PA0~2까지 LED
  DDRC=0xff;      DDRG=0xff;   // fnd
  TWSR=TWSR&0xfc; TWBR=(F_CPU/F_SCK-16)/2;
  ADMUX=0x40;     ADCSRA=0xE7; // 조도
    temperature=read_twi_2byte_nopreset(LM75A_TEMP_REG);
    display_FND(temperature);
    if(temperature>TEM1)PORTB=MOTOR_ON; else PORTB=MOTOR_STOP;
    value_zodo=ADC;                   // value_zodo=ADW; 낮은 버전에서는 ADCW를 사용 함
    if(value_zodo<=CDS_10)PORTA=0xff; else PORTA=0;
    _delay_ms(100);
    PORTE|=0x40; _delay_us(10); PORTE&=~0x40; // TRIG
    while(!(PINE&0x80)); TCNT1=0;  TCCR1B=3;  // 4us
    while(PINE&0x80);    TCCR1B=0;
    distance=(float)TCNT1*0.6896551724137931; // mm
    if(distance<300){ // 300mm 이내 접근?
      for(i=0;i<10;i++){ PORTB^=0x10; _delay_ms(1); }
조회수 243
질문 아두이노 제어하기댓글[3] 매드닥터 23-03-19 45
질문 아두이노 스텝모터 각도제어 질문댓글[3] master 23-03-17 59
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 42
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 43
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 73
질문 HM-10 모듈 사용하는데 질문있습니다.댓글[2] 뉴비에오 23-02-21 129
