BASIC4MCU | 질문게시판 | 아두이노 초급자 과제 중인데 코드해석이 어렵습니다..
작성자 zhem 작성일2022-12-06 16:09 조회1,463회 댓글0건본문
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
#include <Servo.h>
Servo myservo;
int cont=0;
int LED=12;
int LED2=13;
int rele=A4;
#include <Adafruit_Fingerprint.h>
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
lcd.begin(16, 2);
lcd.setCursor(0,0); //LCD 커서 위치 ì„¤ì •
lcd.clear(); // LCD 초기화
myservo.attach(A5); // 서보모터 attachì—서 A5ë²ˆì— ì—°ê²°
pinMode(LED,OUTPUT); //
pinMode(LED2,OUTPUT);
pinMode(rele,OUTPUT);
digitalWrite(rele,0);
while (!Serial); // For Yun/Leo/Micro/Zero/...
//2
Serial.println("\n\nfinger detecter");
lcd.print("finger detecter");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
else {
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Sensor contains ");
Serial.print(finger.templateCount);
Serial.println(" templates");
Serial.println("Waiting for valid finger...");
lcd.clear();
//3
void loop() // run over and over again
delay(50);
getFingerprintIDez();
digitalWrite(LED,cont);
digitalWrite(LED2,!cont);
digitalWrite(rele,cont);
delay(50);
lcd.setCursor(0, 0);
lcd.print("Found ID #");
lcd.print(finger.fingerID);
if(cont == 1){
lcd.setCursor(0, 1);
lcd.print("POWER = ON ");
myservo.write(0);
lcd.print("POWER = OFF ");
myservo.write(90);
//don't ned to run this at full speed.
//4
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
//Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
//Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
//Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
//Serial.println("Imaging error");
return p;
default:
//Serial.println("Unknown error");
return p;
// 5
// OK success!
p = finger.image2Tz();
switch (p) {
//Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
//Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
//Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
//6
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
//Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
//Serial.println("Did not find a match");
return p;
} else {
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
// 7
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
if(finger.confidence >= 100){
Serial.println("Identical" );
cont=!cont;
Serial.println("retouch");
Serial.println(cont);
조회수 1,463등록된 댓글이 없습니다.
