질문게시판 > 답변 : 아두이노 l298n frequency sweep 관련 질문
TODAY561 TOTAL2,925,424
BASIC4MCU | 질문게시판 | 답변 : 아두이노 l298n frequency sweep 관련 질문
작성자 master 작성일2022-12-07 19:46 조회1,614회 댓글2건
  attachInterrupt(0,doEncoderA,CHANGE);
  attachInterrupt(1,doEncoderB,CHANGE);
인터럽트 함수가 누락되어 있습니다.
#include // For the ATOMIC_BLOCK macro
#define encoder0PinA 2 //encoder pin 2 and 3
#define encoder0PinB 3
int encoder0Pos=0;
const int elements=40; // number of frequencies
int Fs=500;            // sampling frequency of sin wave
int n=500;             // 500; // number of samples
byte samples[500];
float t,freq_arra[elements]={ // frequncy look up table
  0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1.0,
  1.1,1.2,1.3,1.4,1.5,1.6,1.7,1.8,1.9,2.0,
  2.5,3.0,3.5,4.0,4.5,5.0,5.5,6.0,6.5,7.0,
  7.5,8.0,8.5,9.0,9.5,10.0,11.0,12.0,13.0,14.0
int samling_interval,no_samples;
  pinMode(encoder0PinA,INPUT_PULLUP);
  pinMode(encoder0PinB,INPUT_PULLUP);
  pinMode(10,OUTPUT); pinMode(11,OUTPUT); // declaration of PWM pins
  Serial.begin(230400);
  for(int k=0;k<n;k++){ t=(float)k/Fs; samples[k]=(byte)(127.0/1 * sin(2*3.142*t*1)+127.0/1); } //calculating Sin wave values
  char value;
  if(Serial.available()>0){
    value=Serial.read();
    if(value=='a'){
      for(int m=0;m<elements;m++){  // loop for changing the frequencies
        samling_interval=(float)1000000/(freq_arra[m]*n);
        no_samples=(float)(freq_arra[m]*n/50);
        analogWrite(10,255); analogWrite(11,255); delay(1000);
        encoder0Pos=0;                     // to reset the position of encoder
        for(int p=0;p<5*freq_arra[m];p++){ // to have 5sec signal starting from 0 degree
          for(int j=0;j<n;j++){
            if(j>=n/4 && j<3*n/4){ analogWrite(10,samples[j]); analogWrite(11,0); } //signal between 90-270 degree
            else                 { analogWrite(11,samples[j]); analogWrite(10,0); } //signal between 270->90 degree
            Serial.print(encoder0Pos); Serial.write(13); Serial.write(10);
            if(freq_arra[m]<=1){ delay(samling_interval/1000);        } // delay for sampling 2/frequency ms
            else               { delayMicroseconds(samling_interval); } // delay for sampling 2000/frequency ms
      Serial.print('b'); Serial.write(13); Serial.write(10);
      analogWrite(10,0); analogWrite(11,0);
코드 분석을 하려면 들여쓰기부터 하고, 자신의 스타일에 맞게 정리를 해야겠죠
결국 PWM핀에 출력을 하고
엔코더 입력값을 출력하는 것 아닌가요?
조회수 1,614
sdwdjangwon님의 댓글
sdwdjangwon 작성일
네 맞습니다. 복붙하는 과정에서 날아간 모양입니다.
해당 코드는 엔코더 출력까지는 제가 짰고, frequency sweep 부분은 따와서 사용했습니다. 실제로 돌아가는 것까지 확인했구요. 그런데 frequency sweep이 이해가 잘 안되더라구요.
sample[k]는 0~499/500 까지 1/500 sampling으로 sin함수가 형성된 것은 안 바뀌고, for(int p=0; p<5*freq_arra[m];p++) 부분에서 반복되는 횟수만 바뀔 뿐인데 (freq_arra=0.1일 때는 p=0;p<0.;p++5라서 1번, 0.3일 때는 p=0;p<1.5;p++라서 2번) 어째서 진폭이 감소하는 sin함수 꼴이 출력값으로 나오는지 궁금해서, matlab systemIdentification으로 확인해보고 싶었는데 input함수를 못 구하겠어서 질문을 올렸습니다.
          Serial.print("for P="); Serial.println(P); // <----
            Serial.print("for n="); Serial.println(n); // <----
            if(j>=n/4 && j<3*n/4){ Serial.print("10="); Serial.println(samples[j]); } // <----
            else                { Serial.print("11="); Serial.println(samples[j]); } // <----
            if(freq_arra[m]<=1){ Serial.print("delay ms="); Serial.println(samling_interval/1000); } // <----
            else              { Serial.print("delay us="); Serial.println(samling_interval); } // <----
엔코더값 삭제하고
코드에서 읽어오는 값을 출력하면 코드의 이해를 높일 것으로 보입니다.
데이터가 많을테니 필요하면 시리얼모니터가 아닌 다른 종류의 시리얼모니터링 프로그램을 사용해서 받든지
복사할 시간을 벌으려면 10초 정도의 딜레이를 넣고, 복사하라는 메시지도 출력하면 될 것으로 생각합니다,
질문 atmega128 분초시계에서 초부분이 잘안돼고있어요댓글[2] 이미지 rpdla 23-05-08 728
질문 가변 저항 입력을 0∼4095로 7-세그먼트에 표시한걸 0∼33 으로 7-세그먼트에 표시하는법댓글[2] 수포자 23-05-08 609
질문 아두이노 서보모터 제어 질문이있습니다댓글[1] apzk3 23-05-06 644
질문 atmega128로 분초 전자시계를 어떻게 만들어야하나요?댓글[5] 이미지첨부파일 rpdla 23-05-05 1631
질문 mpu 6050 과 gps 센서 질문댓글[1] Mick 23-05-05 501
질문 아두이노 GPS 확장 SPI통신 쉴드댓글[3] 이미지첨부파일 Mick 23-05-04 871
질문 gps 확장 spi통신 쉴드댓글[1] 이미지첨부파일 Mick 23-05-04 458
질문 아두이노 우노 보드 구입하려고 하는데 두 부품의 차이점이 뭔지 알려주시면 감사하겠습니다댓글[1] 나도할수있어아두 23-05-03 1130
질문 온도 센서 오류댓글[1] 핸찌니 23-05-03 534
질문 hm10으로 pwm모델을 제어하려고 합니다.댓글[6] 용용이 23-05-01 1445
질문 비콘댓글[1] 앋우이노 23-05-01 470
질문 atmega128 dc모터 코딩 질문입니다. 김자라 23-04-30 620
답변 답변글 답변 : atmega128 dc모터 코딩 질문입니다.댓글[4] master 23-04-30 1437
질문 여러센서 아두이노 연결관련 코드 핸찌니 23-04-29 785
질문 Ph 블루투스로 앱인벤터 출력 안녕하세요13 23-04-28 443
답변 답변글 답변 : Ph 블루투스로 앱인벤터 출력댓글[15] master 23-04-29 5642
질문 아두이노 프로젝트 - 여러센서연결문의댓글[6] 이미지 핸찌니 23-04-27 2254
질문 atmega128 fnd 24시간 시계댓글[1] 마이크로어려워 23-04-27 998
질문 아두이노 초음파센서와 HC06(블루투스)를 이용, 릴레이동작댓글[3] 나도할수있어아두 23-04-27 1371
질문 학부수업에서 마이크로프로세서를 배우고 있는데 혹시 작은 프로젝트 해볼거 없을까요??댓글[2] E10n 23-04-26 931
질문 아두이노 블루투스 서보 제어서 튐댓글[2] 첨부파일 타이지 23-04-24 1045
질문 AVR 질문입니다.댓글[1] 모지리학부생 23-04-22 581
질문 아트메가128 전류증폭 질문드립니다 ..!!댓글[5] 순길 23-04-21 1154
질문 아두이노 질문댓글[2] 이미지 1233 23-04-20 896
질문 스텝모터 감속 코딩 질문입니다. 무야더싱 23-04-19 472
답변 답변글 답변 : 스텝모터 감속 코딩 질문입니다.댓글[2] master 23-04-19 702
질문 atmega128 스위치로 스피커 제어하기댓글[6] 호구마 23-04-19 2280
질문 아트멜7.0 서보모터 스위치 제어 질문 드립니다.댓글[1] 순길 23-04-18 669
질문 모터드라이버와 모터 연결 문의댓글[1] 오후 23-04-14 625
질문 아두이노에 이산화탄소 센서 여러개 연결방법댓글[1] 생물공학도 23-04-14 849
