질문게시판 > 아두이노 코드 에러관련 질문.
TODAY447 TOTAL2,592,968
BASIC4MCU | 질문게시판 | 아두이노 코드 에러관련 질문.
작성자 영다니 작성일2023-02-09 13:55 조회191회 댓글1건
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <ESP8266WiFi.h>  //Use this for WiFi instead of Ethernet.h
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server_addr();   //IP of the MySQL server here
char user[] = "";               //MySQL user login username
char password[] = "!";         //MySQL user login password
// WiFi card example
char ssid[] = "";     //your SSID
char pass[] = "";       // your SSID Password
WiFiClient client;             //Use this for WiFi instead of EthernetClient
MySQL_Connection conn((Client *)&client);
//rgb 센서 변수 선언
int s0=3; // S0 는 D3
int s1=4; // S1 는 D4
int s2=5; // S2 는 D5
int s3=6; // S3 는 D6
int out=2; // OUT 은 D2
int flag=0;
byte counter=0;
byte countR=0,countG=0,countB=0;
byte TCCR2A , TCCR2B , TCNT2 , TIMSK2;
  Serial.begin(115200);
  while (!Serial);  //wait for serial port to connect. Needed for Leonardo only
  pinMode(s0,OUTPUT);
  pinMode(s1,OUTPUT);
  pinMode(s2,OUTPUT);
  pinMode(s3,OUTPUT);
 //Begin WiFi section
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
  while( WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
//  print out info about the connection
    Serial.println("Connected to network");
    Serial.print("My IP address is ");
    Serial.println(WiFi.localIP());
//  End WiFi section
  Serial.println("Connecting...");
  if (conn.connect(server_addr, 3307, user, password)) {
    MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
    cur_mem->execute(INSERT_SQL);
    delete cur_mem;
    Serial.println("Connection failed.");
  conn.close();
//RGT TCS 함수
void TCS()
 flag=0;
 digitalWrite(s1,HIGH);
 digitalWrite(s0,HIGH);
 digitalWrite(s2,LOW);
 digitalWrite(s3,LOW);
 attachInterrupt(0, ISR_INTO, CHANGE);
 timer0_init();
//ISR_INTO()함수
void ISR_INTO()
 counter++;
// TIMER INIT() 함수
 void timer0_init(void)
  TCCR2A=0x00;
  TCCR2B=0x07;   //the clock frequency source 1024 points
  TCNT2= 100;    //10 ms overflow again
  TIMSK2 = 0x01; //allow interrupt
// ISR 함수
int i=0;
ISR(TIMER2_OVF_vect) {
    TCNT2=100;
    flag++;
   if(flag==1)
        countR=counter;
        Serial.print("red=");
        Serial.println(countR,DEC);
        digitalWrite(s2,HIGH);
        digitalWrite(s3,HIGH);
    else if(flag==2)
        countG=counter;
        Serial.print("green=");
        Serial.println(countG,DEC);
   else if(flag==3)
          countB=counter;
          Serial.print("blue=");
          Serial.println(countB,DEC);
          Serial.println("\n");
    else if(flag==4)
     flag=0;
       counter=0;
    delay(5000);
    delete cur_mem;
  conn.close();
  TCS();
  while(1);
아두이노 rgb센서를 이용하여 rgb값을 wifi 로 보내주는 코드를 짜는 중입니다.
ISR 이쪽 줄에서
exit status 1 Compilation error: expected constructor, destructor, or type conversion before '(' token
이라는 오류가 뜨는데, 혹시 어떻게 해결해야 할까요.
보드는 nodeMCU 1.0 사용 , WIFI는 ESP8266WIFI 사용하고 있습니다.
조회수 191
ISR 함수가 2개이고 어느 라인에서 에러가 났다는지 알 수 없습니다.
버튼 누르면 디테일한 오류 내용을 볼 수 있습니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17377
공지 사이트 이용 안내댓글[28] master 17-10-29 33600
질문 아두이노 코딩 질문댓글[2] 이미지새글첨부파일 pmh11 23-04-01 20
질문 라즈베리 파이 질문댓글[1] 새글 rasp 23-03-31 21
질문 아두이노 코드관련 질문댓글[1] 새글 왕초봉 23-03-31 22
질문 아두이노 led 부저 스위치 김똘 23-03-30 28
답변 답변글 답변 : 아두이노 led 부저 스위치댓글[4] master 23-03-30 39
질문 아두이노 근접센서 2개 연결 질문댓글[1] 김민종 23-03-29 29
질문 아두이노 코딩 에러 질문댓글[1] 이미지첨부파일 박무농 23-03-25 60
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[2] 박무농 23-03-25 61
질문 sd카드 이미지 전송댓글[2] 던지기마스터 23-03-24 39
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 81
질문 부품 관련 문의댓글[1] 타코 23-03-23 42
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 56
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 37
질문 ESP로 원격 모터제어를 할 수 있나용?댓글[1] 비차 23-03-22 45
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 58
질문 아두이노 제어하기댓글[3] 매드닥터 23-03-19 75
질문 atmega128 압력센서 관련 질문입니다댓글[1] 공린이 23-03-19 96
질문 아두이노 스텝모터 각도제어 질문댓글[3] master 23-03-17 94
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 62
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 70
질문 ATmega328p로 pca9685를 이용하여 서보모터(mg996r, mg90s)를 pwm로 제어 중 떨림댓글[1] 이미지첨부파일 토비 23-03-15 71
질문 hm-10 다중연결 질문있습니다.댓글[1] 첨부파일 뉴비에오 23-03-14 62
질문 while loop 실행 속도댓글[1] 412904 23-03-12 91
질문 AND 연산 질문드립니다.댓글[1] 412904 23-03-11 92
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 189
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 151
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 167
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 96
