질문게시판 > 블루투스에서 아두이노로 신호전달에 대하여
TODAY445 TOTAL2,592,966
BASIC4MCU | 질문게시판 | 블루투스에서 아두이노로 신호전달에 대하여
작성자 밍경 작성일2023-02-13 17:39 조회166회 댓글0건
#include <NewPing.h>  //for the Ultrasonic sensor function library.
//L298N motor control pins
#define RightEnable 5
#define Right1 A1
#define Right2 A0
#define LeftEnable 6
#define Left1 A2
#define Left2 A3
//Ultrasonic sensor control pins
#define trig_pin 8
#define echo_pin 9
//IR sensor control pins
#define LLeft 4
#define CLeft 2
#define CRight 3
#define RRight 10
int max_distance = 1000;
int cm = 0;
boolean skiptime = false;
NewPing sonar(trig_pin, echo_pin, max_distance);
SoftwareSerial Bluetooth(11, 12);
  Bluetooth.begin(9600);
  pinMode(RightEnable, OUTPUT);
  pinMode(Right1, OUTPUT);
  pinMode(Right2, OUTPUT);
  pinMode(LeftEnable, OUTPUT);
  pinMode(Left1, OUTPUT);
  pinMode(Left2, OUTPUT);
  pinMode(LLeft, INPUT);
  pinMode(CLeft, INPUT);
  pinMode(CRight, INPUT);
  pinMode(RRight, INPUT);
  digitalWrite(RightEnable, HIGH);
  digitalWrite(LeftEnable, HIGH);
  if (Bluetooth.available()) {
    int c = Bluetooth.read();
    Serial.write(Bluetooth.read());
    Serial.println(Bluetooth.read());
    Serial.println(c);
      if (c = 1) {
        int LC = digitalRead(CLeft);
        int RC = digitalRead(CRight);
        int RR = digitalRead(RRight);
        int LL = digitalRead(LLeft);
        Serial.println(readPing());
        if (readPing() < 0) {
          MotorStop();
        } else if (RR == 1) {
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.print("Straight_1");
          } else if (LL == 1) {
            MotorStop();
            Turn();
            MotorStop_Start_Point();
          } else {
            MotorStop();
            Turn();
        } else if (LC == 0 && RC == 1) {
          Left();
          Serial.println("Left1");
        } else if (LC == 1 && RC == 0) {
          Right();
          Serial.println("Right1");
        } else if (LC == 0 && RC == 0) {
          Straight();
          Serial.println("Straight1");
      else if (c = 2) {
          MotorStop();
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.println("Straight_2");
            MotorStop();
            Turn();
          } else {
            MotorStop();
            Turn();
          Left();
          Serial.println("Left2");
          Right();
          Serial.println("Right2");
          Straight();
          Serial.println("Straight2");
// if 처음
// loop
void MotorStop_Start_Point() {
  analogWrite(Right1, 0);
  analogWrite(Right2, 0);
  analogWrite(Left1, 0);
  analogWrite(Left2, 0);
  delay(10000);
void MotorStop() {
void Straight() {
  analogWrite(RightEnable, 90);
  analogWrite(LeftEnable, 95);
  analogWrite(Right1, 200);
  analogWrite(Left1, 200);
void Straight_() {
  analogWrite(LeftEnable, 90);
  delay(300);
void Right() {
  analogWrite(LeftEnable, 0);
void Left() {
  analogWrite(RightEnable, 0);
void TurnRight() {
  analogWrite(RightEnable, 100);
  analogWrite(LeftEnable, 100);
  delay(2350);
void Turn() {
  analogWrite(RightEnable, 120);
  analogWrite(Left2, 200);
  delay(2500);
void TurnLeft() {
  delay(2250);
int readPing() {
  delay(50);
  int cm = sonar.ping_cm();
  return cm;
  delay(50);
안녕하세요, 앱인벤터를 통해 블루투스로 아두이노에 신호를 전송하면 라인트레이서가 1이란 신호를 인식하고 c=1의 마지막 명령어인 "Straight1" 만 인식합니다.
그리고 c=2 라는 값을 인식해도 2에 해당하는 명령을 실행하지않고 똑같이 "Straight1" 값만 출력됩니다. 1번을 반복적으로 눌리면 눌릴때마다 신호값이 다시 인식되어
누르는 당시의 상황 ("Left", "Right" ) 값을 출력해내긴합니다. 1이란 신호값을 한번만 받고도 c=1의 모든 명령을 수행하게하는 방법이 있을까요?
그리고 시리얼모니터를 보면 1이나 2라는 신호를 주면 1-1 2-1 이런값으로 계속 입력이됩니다. 이것도 해결방법이 있을까요?
도움 주시면 감사하겠습니다.
조회수 166
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 17377
공지 사이트 이용 안내댓글[28] master 17-10-29 33600
질문 아두이노 코딩 질문댓글[2] 이미지새글첨부파일 pmh11 23-04-01 20
질문 라즈베리 파이 질문댓글[1] 새글 rasp 23-03-31 21
질문 아두이노 코드관련 질문댓글[1] 새글 왕초봉 23-03-31 22
질문 아두이노 led 부저 스위치 김똘 23-03-30 28
답변 답변글 답변 : 아두이노 led 부저 스위치댓글[4] master 23-03-30 39
질문 아두이노 근접센서 2개 연결 질문댓글[1] 김민종 23-03-29 29
질문 아두이노 코딩 에러 질문댓글[1] 이미지첨부파일 박무농 23-03-25 60
질문 아두이노를 이용한 타이머, 태양전지 제어댓글[2] 박무농 23-03-25 61
질문 sd카드 이미지 전송댓글[2] 던지기마스터 23-03-24 39
질문 초음파센서를 이용한 모터제어 질문있습니다.댓글[3] 이미지첨부파일 뉴비에오 23-03-24 81
질문 부품 관련 문의댓글[1] 타코 23-03-23 42
질문 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 그렇찌 23-03-22 56
답변 답변글 답변 : 모터 작동 시, 일부 모듈이 꺼지는 현상에 대해 질문드립니다. 이미지 master 23-03-23 37
질문 ESP로 원격 모터제어를 할 수 있나용?댓글[1] 비차 23-03-22 45
질문 HC06을 마스터로 설정하면 HC06끼리만 통신되나요?댓글[4] 비차 23-03-21 58
질문 아두이노 제어하기댓글[3] 매드닥터 23-03-19 75
질문 atmega128 압력센서 관련 질문입니다댓글[1] 공린이 23-03-19 96
질문 아두이노 스텝모터 각도제어 질문댓글[3] master 23-03-17 94
질문 아두이노와 파이썬(중점좌표) 시리얼 통신 질문드립니다.댓글[1] 이미지첨부파일 아두이노어렵잖아 23-03-16 62
질문 아두이노 3LED 버튼 관련 질문댓글[1] 이츤 23-03-16 70
질문 ATmega328p로 pca9685를 이용하여 서보모터(mg996r, mg90s)를 pwm로 제어 중 떨림댓글[1] 이미지첨부파일 토비 23-03-15 71
질문 hm-10 다중연결 질문있습니다.댓글[1] 첨부파일 뉴비에오 23-03-14 62
질문 while loop 실행 속도댓글[1] 412904 23-03-12 91
질문 AND 연산 질문드립니다.댓글[1] 412904 23-03-11 92
질문 아두이노 테트리스 게임댓글[1] 첨부파일 지욱애 23-03-02 189
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 151
질문 스텝모터 코딩 질문입니다..댓글[2] 무야더싱 23-02-25 167
질문 아두이노 나노33 IOT 의 BLE 연결 문제 이미지 가루밀 23-02-24 96
