질문게시판 > 블루투스에서 아두이노로 신호전달에 대하여
TODAY390 TOTAL2,694,823
BASIC4MCU | 질문게시판 | 블루투스에서 아두이노로 신호전달에 대하여
작성자 밍경 작성일2023-02-13 17:39 조회401회 댓글0건
#include <NewPing.h>  //for the Ultrasonic sensor function library.
//L298N motor control pins
#define RightEnable 5
#define Right1 A1
#define Right2 A0
#define LeftEnable 6
#define Left1 A2
#define Left2 A3
//Ultrasonic sensor control pins
#define trig_pin 8
#define echo_pin 9
//IR sensor control pins
#define LLeft 4
#define CLeft 2
#define CRight 3
#define RRight 10
int max_distance = 1000;
int cm = 0;
boolean skiptime = false;
NewPing sonar(trig_pin, echo_pin, max_distance);
SoftwareSerial Bluetooth(11, 12);
  Bluetooth.begin(9600);
  pinMode(RightEnable, OUTPUT);
  pinMode(Right1, OUTPUT);
  pinMode(Right2, OUTPUT);
  pinMode(LeftEnable, OUTPUT);
  pinMode(Left1, OUTPUT);
  pinMode(Left2, OUTPUT);
  pinMode(LLeft, INPUT);
  pinMode(CLeft, INPUT);
  pinMode(CRight, INPUT);
  pinMode(RRight, INPUT);
  digitalWrite(RightEnable, HIGH);
  digitalWrite(LeftEnable, HIGH);
  if (Bluetooth.available()) {
    int c = Bluetooth.read();
    Serial.write(Bluetooth.read());
    Serial.println(Bluetooth.read());
    Serial.println(c);
      if (c = 1) {
        int LC = digitalRead(CLeft);
        int RC = digitalRead(CRight);
        int RR = digitalRead(RRight);
        int LL = digitalRead(LLeft);
        Serial.println(readPing());
        if (readPing() < 0) {
          MotorStop();
        } else if (RR == 1) {
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.print("Straight_1");
          } else if (LL == 1) {
            MotorStop();
            Turn();
            MotorStop_Start_Point();
          } else {
            MotorStop();
            Turn();
        } else if (LC == 0 && RC == 1) {
          Left();
          Serial.println("Left1");
        } else if (LC == 1 && RC == 0) {
          Right();
          Serial.println("Right1");
        } else if (LC == 0 && RC == 0) {
          Straight();
          Serial.println("Straight1");
      else if (c = 2) {
          MotorStop();
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.println("Straight_2");
            MotorStop();
            Turn();
          } else {
            MotorStop();
            Turn();
          Left();
          Serial.println("Left2");
          Right();
          Serial.println("Right2");
          Straight();
          Serial.println("Straight2");
// if 처음
// loop
void MotorStop_Start_Point() {
  analogWrite(Right1, 0);
  analogWrite(Right2, 0);
  analogWrite(Left1, 0);
  analogWrite(Left2, 0);
  delay(10000);
void MotorStop() {
void Straight() {
  analogWrite(RightEnable, 90);
  analogWrite(LeftEnable, 95);
  analogWrite(Right1, 200);
  analogWrite(Left1, 200);
void Straight_() {
  analogWrite(LeftEnable, 90);
  delay(300);
void Right() {
  analogWrite(LeftEnable, 0);
void Left() {
  analogWrite(RightEnable, 0);
void TurnRight() {
  analogWrite(RightEnable, 100);
  analogWrite(LeftEnable, 100);
  delay(2350);
void Turn() {
  analogWrite(RightEnable, 120);
  analogWrite(Left2, 200);
  delay(2500);
void TurnLeft() {
  delay(2250);
int readPing() {
  delay(50);
  int cm = sonar.ping_cm();
  return cm;
  delay(50);
안녕하세요, 앱인벤터를 통해 블루투스로 아두이노에 신호를 전송하면 라인트레이서가 1이란 신호를 인식하고 c=1의 마지막 명령어인 "Straight1" 만 인식합니다.
그리고 c=2 라는 값을 인식해도 2에 해당하는 명령을 실행하지않고 똑같이 "Straight1" 값만 출력됩니다. 1번을 반복적으로 눌리면 눌릴때마다 신호값이 다시 인식되어
누르는 당시의 상황 ("Left", "Right" ) 값을 출력해내긴합니다. 1이란 신호값을 한번만 받고도 c=1의 모든 명령을 수행하게하는 방법이 있을까요?
그리고 시리얼모니터를 보면 1이나 2라는 신호를 주면 1-1 2-1 이런값으로 계속 입력이됩니다. 이것도 해결방법이 있을까요?
도움 주시면 감사하겠습니다.
조회수 401
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19512
공지 사이트 이용 안내댓글[28] master 17-10-29 34149
질문 안녕하십니까? 아두이노를 배우고 있는 학생입니다. 도와주세요 이미지새글첨부파일 인하전자 01:18 11
질문 pixy2 cam 을 이용한 색상인식 모터 제어 새글 가나다라 23-06-05 9
질문 안녕하세요 제품 품목 이름에 대해서 궁금합니다. 이미지새글첨부파일 알려주시면감사합니다 23-06-05 15
질문 Atmega128 온도센서로 led제어 질문드려요 이미지새글첨부파일 얍얍 23-06-05 17
질문 아구이노 코드를 atmega 128 코드로 변환 하고 싶습니다 ㅠㅠ 새글 기로롱 23-06-05 17
질문 atmega128 uart 질문입니다. 새글 bme12 23-06-05 20
질문 라즈베리파이에 풀 프레임 이미지센서 활용에 대한 질문이 있습니다. 이미지새글첨부파일 KYLO 23-06-04 17
질문 아두이노 시리얼 번호를 이용해 led 제어 새글 wnion 23-06-04 19
질문 ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요 새글 IEEE 23-06-04 32
질문 stm32f767을 이용해서 자이로가속도 센서의 값 받아오기 rlchwjswk 23-06-03 20
질문 아두이노 모터제어 관련해서 질문드립니다!댓글[1] 이미지첨부파일 아두이노어렵잖아 23-06-03 40
질문 atmega128 디지털조도센서 코드오류댓글[1] 이미지 까미 23-06-02 38
질문 atmega128 디지털 조도 센서댓글[1] 까미 23-06-02 39
질문 lora 무선 모듈에 관한 질문입니다.댓글[1] 로이스10 23-06-01 22
질문 적외선 송수신기 DC모터2개 제어 질문입니다.댓글[5] Tell 23-06-01 37
질문 스텝모터 제어 코드 질문댓글[5] pmh11 23-05-31 45
질문 초음파 센서를 이용한 인원 카운팅댓글[1] 초음파야 23-05-31 36
질문 모터 Hall 스위치 연결 문의댓글[1] 오후 23-05-31 24
질문 아두이노 lcd 문자 스크롤디스플레이 wnion 23-05-31 32
질문 아두이노 타이머 인터럽트 미ㅏㄴㅇ 23-05-30 45
답변 답변글 답변 : 아두이노 타이머 인터럽트댓글[7] master 23-05-30 52
질문 THC-Soil Sensor with TTL 모듈 아두이노 센서값 받아오기댓글[1] ppiickle 23-05-30 31
질문 stm32 psd센서구동 질문댓글[2] 수포자 23-05-29 30
질문 앱인벤터 아두이노 보드 LCD 글씨 나타내기 질문댓글[7] 이미지 당찬병아리 23-05-29 49
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 52
질문 stm32f767 스텝모터 속도 질문있습니다 123132 23-05-27 36
