질문게시판 > 블루투스에서 아두이노로 신호전달에 대하여
TODAY1,084 TOTAL2,933,370
BASIC4MCU | 질문게시판 | 블루투스에서 아두이노로 신호전달에 대하여
작성자 밍경 작성일2023-02-13 17:39 조회936회 댓글0건
#include <NewPing.h>  //for the Ultrasonic sensor function library.
//L298N motor control pins
#define RightEnable 5
#define Right1 A1
#define Right2 A0
#define LeftEnable 6
#define Left1 A2
#define Left2 A3
//Ultrasonic sensor control pins
#define trig_pin 8
#define echo_pin 9
//IR sensor control pins
#define LLeft 4
#define CLeft 2
#define CRight 3
#define RRight 10
int max_distance = 1000;
int cm = 0;
boolean skiptime = false;
NewPing sonar(trig_pin, echo_pin, max_distance);
SoftwareSerial Bluetooth(11, 12);
  Bluetooth.begin(9600);
  pinMode(RightEnable, OUTPUT);
  pinMode(Right1, OUTPUT);
  pinMode(Right2, OUTPUT);
  pinMode(LeftEnable, OUTPUT);
  pinMode(Left1, OUTPUT);
  pinMode(Left2, OUTPUT);
  pinMode(LLeft, INPUT);
  pinMode(CLeft, INPUT);
  pinMode(CRight, INPUT);
  pinMode(RRight, INPUT);
  digitalWrite(RightEnable, HIGH);
  digitalWrite(LeftEnable, HIGH);
  if (Bluetooth.available()) {
    int c = Bluetooth.read();
    Serial.write(Bluetooth.read());
    Serial.println(Bluetooth.read());
    Serial.println(c);
      if (c = 1) {
        int LC = digitalRead(CLeft);
        int RC = digitalRead(CRight);
        int RR = digitalRead(RRight);
        int LL = digitalRead(LLeft);
        Serial.println(readPing());
        if (readPing() < 0) {
          MotorStop();
        } else if (RR == 1) {
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.print("Straight_1");
          } else if (LL == 1) {
            MotorStop();
            Turn();
            MotorStop_Start_Point();
          } else {
            MotorStop();
            Turn();
        } else if (LC == 0 && RC == 1) {
          Left();
          Serial.println("Left1");
        } else if (LC == 1 && RC == 0) {
          Right();
          Serial.println("Right1");
        } else if (LC == 0 && RC == 0) {
          Straight();
          Serial.println("Straight1");
      else if (c = 2) {
          MotorStop();
          if (!skiptime) {
            Straight_();
            skiptime = true;
            Serial.println("Straight_2");
            MotorStop();
            Turn();
          } else {
            MotorStop();
            Turn();
          Left();
          Serial.println("Left2");
          Right();
          Serial.println("Right2");
          Straight();
          Serial.println("Straight2");
// if 처음
// loop
void MotorStop_Start_Point() {
  analogWrite(Right1, 0);
  analogWrite(Right2, 0);
  analogWrite(Left1, 0);
  analogWrite(Left2, 0);
  delay(10000);
void MotorStop() {
void Straight() {
  analogWrite(RightEnable, 90);
  analogWrite(LeftEnable, 95);
  analogWrite(Right1, 200);
  analogWrite(Left1, 200);
void Straight_() {
  analogWrite(LeftEnable, 90);
  delay(300);
void Right() {
  analogWrite(LeftEnable, 0);
void Left() {
  analogWrite(RightEnable, 0);
void TurnRight() {
  analogWrite(RightEnable, 100);
  analogWrite(LeftEnable, 100);
  delay(2350);
void Turn() {
  analogWrite(RightEnable, 120);
  analogWrite(Left2, 200);
  delay(2500);
void TurnLeft() {
  delay(2250);
int readPing() {
  delay(50);
  int cm = sonar.ping_cm();
  return cm;
  delay(50);
안녕하세요, 앱인벤터를 통해 블루투스로 아두이노에 신호를 전송하면 라인트레이서가 1이란 신호를 인식하고 c=1의 마지막 명령어인 "Straight1" 만 인식합니다.
그리고 c=2 라는 값을 인식해도 2에 해당하는 명령을 실행하지않고 똑같이 "Straight1" 값만 출력됩니다. 1번을 반복적으로 눌리면 눌릴때마다 신호값이 다시 인식되어
누르는 당시의 상황 ("Left", "Right" ) 값을 출력해내긴합니다. 1이란 신호값을 한번만 받고도 c=1의 모든 명령을 수행하게하는 방법이 있을까요?
그리고 시리얼모니터를 보면 1이나 2라는 신호를 주면 1-1 2-1 이런값으로 계속 입력이됩니다. 이것도 해결방법이 있을까요?
도움 주시면 감사하겠습니다.
조회수 936
질문 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[2] 둘둘이 23-09-22 102
답변 답변글 답변 : 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[1] master 23-09-25 93
질문 Arduino nano 33 iot 모듈 블루투스 통신댓글[5] 이미지첨부파일 senior 23-08-16 700
질문 아두이노 블루투스모듈(HC-06) 모바일 값 전송 질문댓글[3] 이미지첨부파일 소오금 23-08-13 508
질문 아두이노 서보모터 블루투스 제어댓글[3] rnqudah 23-08-01 761
질문 dfplayer 블루투스 연결 앱인벤터댓글[1] 이미지첨부파일 아두이노우 23-06-11 447
질문 Ph 블루투스로 앱인벤터 출력 안녕하세요13 23-04-28 474
답변 답변글 답변 : Ph 블루투스로 앱인벤터 출력댓글[15] master 23-04-29 5782
질문 아두이노 초음파센서와 HC06(블루투스)를 이용, 릴레이동작댓글[3] 나도할수있어아두 23-04-27 1463
질문 아두이노 블루투스 서보 제어서 튐댓글[2] 첨부파일 타이지 23-04-24 1103
질문 아두이노 2대 블루투스댓글[2] 다유 23-04-13 1057
질문 Attiny85로 블루투스 수신받아서 모터 방향제어가 가능할까요?댓글[1] 비차 23-04-07 886
질문 아두이노우노 블루투스 2개 연결댓글[1] dsfadfs 23-02-28 1223
질문 아두이노 블루투스 관련 질문입니다. 생물공학도 23-02-21 831
답변 답변글 답변 : 아두이노 블루투스 관련 질문입니다. master 23-02-21 842
질문 블루투스에서 아두이노로 신호전달에 대하여(2)댓글[1] 이미지첨부파일 밍경 23-02-14 1250
현재글 블루투스에서 아두이노로 신호전달에 대하여 밍경 23-02-13 937
답변 답변글 답변 : 블루투스에서 아두이노로 신호전달에 대하여 master 23-02-14 795
질문 블루투스 모듈을 이용해 정해진 위치로 이동할 수가 있나요?댓글[2] BBAM 23-01-05 1612
질문 매트랩 블루투스 무선 통신댓글[2] 이미지첨부파일 아두이노대학 22-12-08 2008
질문 Atmega128, 블루투스 문제 donggle 22-12-02 1468
답변 답변글 답변 : Atmega128, 블루투스 문제 master 22-12-03 1169
질문 ATmega128과 앱인벤터를 이용해 블루투스 연결을 하고싶은데 코드를 어떻게 작성해야 할까요?댓글[1] 디디 22-12-01 1896
질문 아두이노 GPS(neo-6m)정보를 블루투스(HC06)을 통해 스마트폰으로 가져오는 방법 없을까요?댓글[1] 회색고로케 22-12-01 1558
질문 아두이노 화재센서 블루투스 연동 질문드립니다.댓글[1] 원할머니보고쌈 22-11-29 2309
질문 급함)) 스위치 또는 블루투스로 전체회로를 ON/OFF하고싶습니다. 이미지 Ptype4 22-11-28 1759
답변 답변글 답변 : 급함)) 스위치 또는 블루투스로 전체회로를 ON/OFF하고싶습니다.댓글[1] 이미지 master 22-11-30 1957
질문 블루투스로 값을 받았는대 led가 켜지지 않습니다.. ENEN 22-11-26 1988
답변 답변글 답변 : 블루투스로 값을 받았는대 led가 켜지지 않습니다..댓글[1] master 22-11-27 2215
질문 블루투스 통신이랑 도어락 코드를 합치고 싶습니다.댓글[1] 이재우 22-11-20 2765
