질문게시판 > 답변 : 블루투스에서 아두이노로 신호전달에 대하여
TODAY442 TOTAL2,679,149
BASIC4MCU | 질문게시판 | 답변 : 블루투스에서 아두이노로 신호전달에 대하여
작성자 master 작성일2023-02-14 14:15 조회309회 댓글0건
#include <NewPing.h>  //for the Ultrasonic sensor function library.
//L298N motor control pins
#define RightEnable 5
#define Right1 A1
#define Right2 A0
#define LeftEnable 6
#define Left1 A2
#define Left2 A3
//Ultrasonic sensor control pins
#define trig_pin 8
#define echo_pin 9
//IR sensor control pins
#define LLeft 4
#define CLeft 2
#define CRight 3
#define RRight 10
int max_distance=1000;
int cm=0;
boolean skiptime=false;
NewPing sonar(trig_pin,echo_pin,max_distance);
SoftwareSerial Bluetooth(11,12);
  Bluetooth.begin(9600);
  pinMode(RightEnable,OUTPUT); pinMode(Right1,OUTPUT); pinMode(Right2,OUTPUT);
  pinMode(LeftEnable,OUTPUT);  pinMode(Left1,OUTPUT);  pinMode(Left2,OUTPUT);
  pinMode(LLeft,INPUT); pinMode(CLeft,INPUT);
  pinMode(CRight,INPUT); pinMode(RRight,INPUT);
  digitalWrite(RightEnable,HIGH);
  digitalWrite(LeftEnable,HIGH);
  if(Bluetooth.available()){
    int c=Bluetooth.read();
    Serial.write(Bluetooth.read());
    Serial.println(Bluetooth.read());
    Serial.println(c);
    if(c=1){
      int LC=digitalRead(CLeft);  int RC=digitalRead(CRight);
      int RR=digitalRead(RRight); int LL=digitalRead(LLeft);
      Serial.println(readPing());
      if(readPing()< 0){ MotorStop(); }
      else if(RR==1){
        if( !skiptime){ Straight_(); skiptime=true; Serial.print("Straight_1"); }
        else if(LL==1){ MotorStop(); Turn(); MotorStop_Start_Point(); }
        else          { MotorStop(); Turn(); }
      else if(LC==0 && RC==1){ Left();     Serial.println("Left1"); }
      else if(LC==1 && RC==0){ Right();    Serial.println("Right1"); }
      else if(LC==0 && RC==0){ Straight(); Serial.println("Straight1"); }
    else if(c=2){
      else if(RR==1){
        if( !skiptime){ Straight_(); skiptime=true; Serial.println("Straight_2"); }
      else if(LC==0 && RC==1){ Left();     Serial.println("Left2"); }
      else if(LC==1 && RC==0){ Right();    Serial.println("Right2"); }
      else if(LC==0 && RC==0){ Straight(); Serial.println("Straight2"); }
// if 처음
// loop
void MotorStop_Start_Point(){
  analogWrite(Right1,0); analogWrite(Right2,0);
  analogWrite(Left1,0);  analogWrite(Left2,0);
  delay(10000);
void MotorStop(){
void Straight(){
  analogWrite(RightEnable,90); analogWrite(Right1,200); analogWrite(Right2,0);
  analogWrite(LeftEnable,95);  analogWrite(Left1,200);  analogWrite(Left2,0);
void Straight_(){
  analogWrite(LeftEnable,90);  analogWrite(Left1,200);  analogWrite(Left2,0);
  delay(300);
void Right(){
  analogWrite(LeftEnable,0);   analogWrite(Left1,200);  analogWrite(Left2,0);
void Left(){
  analogWrite(RightEnable,0); analogWrite(Right1,200); analogWrite(Right2,0);
void TurnRight(){
  analogWrite(RightEnable,100); analogWrite(Right1,200); analogWrite(Right2,0);
  analogWrite(LeftEnable,100);  analogWrite(Left1,0);    analogWrite(Left2,0);
  delay(2350);
void Turn(){
  analogWrite(RightEnable,120); analogWrite(Right1,200); analogWrite(Right2,0);
  analogWrite(LeftEnable,100);  analogWrite(Left1,0);    analogWrite(Left2,200);
  delay(2500);
void TurnLeft(){
  analogWrite(RightEnable,100); analogWrite(Right1,0);  analogWrite(Right2,0);
  analogWrite(LeftEnable,100);  analogWrite(Left1,200); analogWrite(Left2,0);
  delay(2250);
int readPing(){ delay(50); int cm=sonar.ping_cm(); return cm; delay(50); }
안녕하세요,앱인벤터를 통해 블루투스로 아두이노에 신호를 전송하면 라인트레이서가 1이란 신호를 인식하고
c=1의 마지막 명령어인 "Straight1" 만 인식합니다.
그리고 c=2 라는 값을 인식해도 2에 해당하는 명령을 실행하지않고 똑같이 "Straight1" 값만 출력됩니다.
1번을 반복적으로 눌리면 눌릴때마다 신호값이 다시 인식되어
누르는 당시의 상황("Left","Right" )값을 출력해내긴합니다. 1이란 신호값을 한번만 받고도 c=1의 모든 명령을 수행하게하는 방법이 있을까요?
그리고 시리얼모니터를 보면 1이나 2라는 신호를 주면 1-1 2-1 이런값으로 계속 입력이됩니다. 이것도 해결방법이 있을까요?
도움 주시면 감사하겠습니다.
    if(c=1){
    else if(c=2){
비교문은 아래처럼 사용해야 합니다.
    if(c==1){
    else if(c==2){
    if(c=1){
이렇게 사용하면 c를 1로 치환(대입)하기 때문에 어떤 문자를 수신해도 c=1이 되어버립니다.
또, c가 0이 아니므로 if문도 실행 됩니다.
조회수 309
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 19170
공지 사이트 이용 안내댓글[28] master 17-10-29 34060
질문 stm32f767 스텝모터 속도 질문있습니다 새글 123132 23-05-27 12
질문 아트메가 128 코딩 오류 질문입니다.댓글[1] 새글 태태킴 23-05-27 12
질문 스텝모터 제어하는 소스파일인데 질문있습니다. 새글 Bs드리프터 23-05-27 16
답변 답변글 답변 : 스텝모터 제어하는 소스파일인데 질문있습니다. 새글 master 23-05-27 20
질문 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[2] 새글 오후에 23-05-27 13
답변 답변글 답변 : 모터 컨트롤러와 웜기어 모터 연결 문의 드립니다댓글[1] 새글첨부파일 오후에 23-05-27 14
질문 아두이노 스텝모터 초음파 결합댓글[2] 새글 결합기원 23-05-26 24
답변 답변글 답변 : 아두이노 스텝모터 초음파 결합 새글 master 23-05-27 11
질문 piezo부저 연결 방법댓글[2] 이미지새글첨부파일 djwb 23-05-26 17
질문 Atmega128과 도트매트릭스을 이용해 16x16미로찾기 새글 JJEE 23-05-26 25
답변 답변글 답변 : Atmega128과 도트매트릭스을 이용해 16x16미로찾기 새글 master 23-05-26 17
질문 아두이노 mq3 센서 여러개댓글[5] 새글 keyest 23-05-26 31
질문 아두이노 이어폰모듈 elb080306댓글[1] 크라퀴 23-05-25 19
질문 어제 아두이노 핀 문제댓글[2] 미ㅏㄴㅇ 23-05-25 30
질문 스텝 모터, 모터 드라이버 관련 질문입니다댓글[2] 스튜와트 23-05-24 30
답변 답변글 답변 : 스텝 모터, 모터 드라이버 관련 질문입니다 이미지 master 23-05-24 21
질문 아두이노 디지털 핀 문제 미ㅏㄴㅇ 23-05-24 23
답변 답변글 답변 : 아두이노 디지털 핀 문제댓글[1] master 23-05-24 36
질문 아두이노 코드 합치기댓글[1] 아두초보이노 23-05-24 30
질문 마그네틱 도어센서 관련 질문드립니다. 엉아 23-05-23 22
답변 답변글 답변 : 마그네틱 도어센서 관련 질문드립니다.댓글[1] master 23-05-24 17
답변 답변글 답변 : 답변 : 마그네틱 도어센서 관련 질문드립니다. master 23-05-24 21
질문 토양습도센서 이용시LCD 오류댓글[5] 윤던 23-05-23 38
질문 ATMEGA 광센서 부저댓글[2] 코딩 23-05-23 40
질문 ATMEGA J-KIT 128 스위치 부저댓글[1] 이미지첨부파일 코딩 23-05-22 43
질문 장애물 회피 게임댓글[1] 첨부파일 헬창 23-05-20 56
질문 회로도 관련 질문댓글[1] 이미지첨부파일 dnjs 23-05-20 39
질문 Atmega FND 왼쪽 2칸엔 고정 오른쪽 2칸엔 1씩증가댓글[1] 초피 23-05-20 48
