질문게시판 > ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요
TODAY681 TOTAL2,927,102
BASIC4MCU | 질문게시판 | ATMEGA128 혹시 여기서 왜 인터럽트 기능이 안되는지 알 수 있나요
작성자 IEEE 작성일2023-06-04 11:02 조회507회 댓글1건
​#include <avr/io.h> // ATmega128 register 정의
#include <avr/interrupt.h> // interrupt 관련
#define F_CPU 16000000UL
#define __DELAY_BACKWARD_COMPATIBLE__
unsigned char digit[10]={0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7c, 0x07,0x7f, 0x67};
unsigned char fnd_sel[4]={0x01, 0x02, 0x04, 0x08};
unsigned char fnd[4];
volatile int count1=0,count=0,count2=0, i =0,k=0, j=0,hour=0, MODE=0, order=0;
#define DO 0
#define RE 1
#define MI 2
#define FA 3
#define SO 4
#define RA 5
#define SI 6
#define DDO 7
#define si 8
#define RRE 9
unsigned char table[]={17,43,66,77,97,114,117,137,3,143};
int song[]={si, RE, SO, si, RE ,RE ,DO,DO,MI,MI ,MI,MI,RE,FA,RA,DDO,SI,RA,SO,SO,SO,SO, SO,SO,SI,SI,RRE,RRE,DDO,DDO,SI,RA,RA,RE,RE,FA,RA,DDO,DDO,SI,SI,RA,SO,SO,si,RE,SO,si,RE,RE,DO,DO,MI,MI,RE,FA,RA,DDO,SI,RA,SO,SO,SO,SO};
int count_1=0,count_2;
#define lux_1 900
unsigned short read_adc()
unsigned char adc_high, adc_low;
unsigned short adc_value;
ADCSRA|=(1<<ADSC);
adc_high = ADCH;
adc_low = ADCL;
adc_value = adc_high + adc_low;
return adc_value;
ISR(INT4_vect)
MODE++;
count2 = count;
if(MODE==6)
MODE=0;
ISR(INT5_vect)
if(MODE==0)
if(MODE==1)
hour++;
if(MODE==2)
hour++;
if(MODE==3)
count++;
if(MODE==4)
count++;
if(MODE==5)
MODE++;
void buzzer(int hz, int count_buzzer)
if (hz <= 0)
return;
double ms = 500.0 / hz;
int k;
for (k = 0; k < count_buzzer; k++)
PORTB |= 0b00010000; // 부저 ON
_delay_ms(ms);
PORTB &= 0b11101111; // 부저 OFF
_delay_ms(ms);
int main()
DDRB = 0b00010000;
ADMUX = 0b0000000;
ADCSRA = 0b11100111;
DDRA = 0xff;
int adc_digit = 0;
DDRC = 0xff; // FND Data
DDRG = 0x0f; // FND Select
DDRE = 0x00; // INT4, 5
EIMSK = 0b00110000;
EICRB = 0b00001111;
SREG |= 1<<7;
while(MODE!=5)
EIMSK = 0b000000000;
adc_digit = ADC;
if(adc_digit>=lux_1)
MODE = 5;
if(MODE==0)
count++;
else if(MODE==1)
if(count==60)
count=0;
hour++;
if(hour==24)
hour=0;
fnd[3] = (hour/10)%10; // 천 자리
fnd[2] = (hour/1)%10; // 백 자리
fnd[1] = (count/10)%10; // 십 자리
fnd[0] = count%10; // 일 자리
for (j=0; j<40; j++)
if ((MODE==1)||(MODE==2))
for(i=2;i<4;i++)
PORTC = digit[fnd[i]];
PORTG = fnd_sel[i];
_delay_ms(2);
_delay_us(100);
for(i=0;i<4;i++)
PORTG = fnd_sel[i];
_delay_us(100);
if ((MODE==3)||(MODE==4))
for(i=0;i<2;i++)
PORTG = fnd_sel[i];
_delay_ms(2);
_delay_us(100);
for(i=0;i<4;i++)
PORTG = fnd_sel[i];
_delay_us(100);
if (MODE == 5)
buzzer(587.3295,500);//레
buzzer(987.7666,500);//시
buzzer(1046.502,250);//도
buzzer(987.7666,250);//시
buzzer(880.0,250);//라
buzzer(783.9909,250);//솔
buzzer(659.2551,500);//미
buzzer(783.9909,500);//솔
buzzer(739.9888,250);//파#
buzzer(880.0,1000);//라
else if(MODE==6)
MODE = 0;
for(i=0;i<4;i++)
PORTG = fnd_sel[i];
_delay_us(100);
EIMSK = 0b00110000;
이 코딩에서 저희 MODE 5 상태가 되면 스위치를 눌러( 인터럽트 발생) mode 6으로 만들고 싶은데 그게 안 되네요 혹시 뭐가 문제일까요?
조회수 507
if(MODE==5){ MODE++; }
ISR(INT5_vect)에서 위 코드는 왜 넣었을까요?
SREG |= 1<<7;
while(1){ // while(MODE!=5){
메인함수의 무한루프에서 MODE를 왜 사용했을까요?
이 루프를 벗어나면 먹통 됩니다.
else if(MODE==6){ MODE = 0; }
MODE=6이면 0으로 clear 시키는 곳이 몇군데 있습니다.
MODE=6을 사용하려면 MODE=7에서 clear 시켜야겠죠
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 21070
공지 사이트 이용 안내댓글[29] master 17-10-29 34907
질문 타이머 인터럽트를 이용한 LCD제어 질문입니다. 새글 Tell 23-09-27 15
답변 답변글 답변 : 타이머 인터럽트를 이용한 LCD제어 질문입니다. 새글 master 09:19 7
질문 아두이노 무한루프 코드 질문...댓글[1] 새글 vnpaz 23-09-27 9
질문 질문있습니다ㅠㅠ 부탁드려요댓글[1] 새글 keldeo 23-09-27 13
질문 0 ~ 99 이중 for문으로 작성하는법!댓글[2] 새글 상어 23-09-26 20
질문 리튬배터리로 화면 출력 질문드립니다 !댓글[1] 이미지새글 멘탈나간다 23-09-26 17
질문 lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ댓글[1] 새글 아두이노개발자 23-09-26 34
질문 stm32에서 변수 값을 유지하는 방법댓글[1] 라칸 23-09-26 27
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다댓글[1] 노형빈 23-09-25 28
질문 16X16 도트 매트릭스 구동방법 질문입니다.댓글[1] 첨부파일 맹균 23-09-25 24
질문 stm32에서 RTC 시간 함수 쓰는데 의문점댓글[1] 라칸 23-09-25 35
질문 GPS 모듈 관련 질문입니다.댓글[3] 지구과학 23-09-22 33
질문 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[2] 둘둘이 23-09-22 64
답변 답변글 답변 : 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[1] master 23-09-25 34
질문 stm32 보드에서 시간설정과 불러오기를 하는데댓글[5] 라칸 23-09-22 46
질문 아두이노 인터럽트 질문입니다.댓글[2] Tell 23-09-21 48
답변 답변글 답변 : 아두이노 인터럽트 질문입니다.댓글[1] master 23-09-22 63
질문 아두이노와 거리 감지 센서의 전류 관련댓글[1] hmkim 23-09-21 74
질문 아두이노 코딩 질문있습니다. 도와주세요....댓글[1] 이미지첨부파일 vnpaz 23-09-20 80
질문 아두이노를 사용한 dc모터 위치제어댓글[2] 모터위치 23-09-20 72
질문 stm32 디버깅이나 rst버튼 없이 하는 방법좀댓글[1] 라칸 23-09-20 59
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 136
질문 알코올 측정기(MQ-3) 관련 질문 이미지 소오금 23-09-18 69
답변 답변글 답변 : 알코올 측정기(MQ-3) 관련 질문 master 23-09-19 118
질문 스텝모터 제어하는 소스파일 수정방법 질문드립니다. Bs드리프터 23-09-15 81
답변 답변글 답변 : 스텝모터 제어하는 소스파일 수정방법 질문드립니다.댓글[1] master 23-09-15 114
질문 atmega 128을 이용한 악기 튜너기댓글[1] 아두이노짱 23-09-15 322
질문 stm32 보드 ip주소 찾는법댓글[1] 라칸 23-09-13 75
