질문게시판 > pixy2 cam 을 이용한 색상인식 모터 제어
TODAY350 TOTAL2,928,018
BASIC4MCU | 질문게시판 | pixy2 cam 을 이용한 색상인식 모터 제어
작성자 가나다라 작성일2023-06-05 22:10 조회440회 댓글1건
#include <SPI.h>
#include <Pixy2.h>
Pixy2 pixy;
int myPins[6] = {5, 6, 7, 8, 9, 10};
float deadZone = 0.15;
int baseSpeed = 130;
int cont = 0;
int signature, x, y, width, height;
float cx, cy, area;
  Serial.print("Starting...\n");
  pixy.init();
  for (int i = 0; i < 6; i++) {
    pinMode (myPins[i], OUTPUT);
  float turn = pixyCheck();
  if (turn > -deadZone && turn < deadZone)  {
    turn = 0;
  if (turn < 0) {
    moveRobot(-80, 170);
  else if (turn > 0) {
    moveRobot(170, -80);
  else {
    moveRobot(70, 70);
  delay(1);
float pixyCheck() {
  static int i = 0;
  int j;
  int8_t blocks;
  char buf[32];
  blocks = pixy.ccc.getBlocks();
  if (blocks)
    signature = pixy.blocks[0].signature;
    height = pixy.ccc.blocks[0].m_height;
    width = pixy.ccc.blocks[0].m_width;
    x = pixy.ccc.blocks[0].m_x;
    y = pixy.ccc.blocks[0].m_y;
    cx = (x + (width / 2));
    cy = (y + (height / 2));
    cx = mapfloat(cx, 0, 320, -1, 1);
    cy = mapfloat(cy, 0, 320, 1, -1);
    area = width * height;
    else {
      cont += 1;
      if (cont == 100) {
        cont = 0;
        cx = 0;
    return cx;
float mapfloat(long x, long in_min, long in_max, long out_min, long out_max)
  return (float)(x- in_min) * (out_max - out_min) / (float)(in_max - in_min) + out_min;
void moveRobot(int leftSpeed, int rightSpeed)
  if (leftSpeed >= 0) {
    digitalWrite(myPins[1], 0);
    digitalWrite(myPins[2], 1);
  else {
    digitalWrite(myPins[1], 1);
    digitalWrite(myPins[2], 0);
  if (rightSpeed >= 0) {
    digitalWrite(myPins[3], 0);
    digitalWrite(myPins[4], 1);
  else {
    digitalWrite(myPins[3], 1);
    digitalWrite(myPins[4], 0);
  analogWrite(myPins[0], abs(leftSpeed));
  analogWrite(myPins[5], abs(rightSpeed));
위의 코딩을 가져와서 수정을 하고 있는데 오류코드가 발생하여 질문 드립니다.
C:\Users\a0109\AppData\Local\Temp\.arduinoIDE-unsaved202355-20148-s7xjwa.yrbap\sketch_jun5a\sketch_jun5a.ino: In function 'float pixyCheck()': C:\Users\a0109\AppData\Local\Temp\.arduinoIDE-unsaved202355-20148-s7xjwa.yrbap\sketch_jun5a\sketch_jun5a.ino:48:22: error: 'Pixy2 {aka class TPixy2<Link2SPI>}' has no member named 'blocks' signature = pixy.blocks[0].signature; ^~~~~~ exit status 1 Compilation error: 'Pixy2 {aka class TPixy2<Link2SPI>}' has no member named 'blocks'
라는 오류코드가 나오며 pixy2를 이용하여 색상인식을 한 후 모터를 통해 따라 움직이는 코딩을 하고싶어서 질문을 드립니다.
조회수 440
라이브러리 설치하면 예제도 설치됩니다.
라이브러리의 예제를 컴파일 해서 오류가 없는 것을 확인 한 후에
라이브러리의 예제와 비교해서 원인을 찾아보세요
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 21078
공지 사이트 이용 안내댓글[29] master 17-10-29 34910
질문 타이머 인터럽트를 이용한 LCD제어 질문입니다. 새글 Tell 23-09-27 18
답변 답변글 답변 : 타이머 인터럽트를 이용한 LCD제어 질문입니다.댓글[1] 새글 master 23-09-28 13
질문 아두이노 무한루프 코드 질문...댓글[1] 새글 vnpaz 23-09-27 11
질문 질문있습니다ㅠㅠ 부탁드려요댓글[1] keldeo 23-09-27 16
질문 0 ~ 99 이중 for문으로 작성하는법!댓글[2] 상어 23-09-26 25
질문 리튬배터리로 화면 출력 질문드립니다 !댓글[1] 이미지 멘탈나간다 23-09-26 18
질문 lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ댓글[1] 아두이노개발자 23-09-26 38
질문 stm32에서 변수 값을 유지하는 방법댓글[1] 라칸 23-09-26 31
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다댓글[1] 노형빈 23-09-25 31
질문 16X16 도트 매트릭스 구동방법 질문입니다.댓글[1] 첨부파일 맹균 23-09-25 31
질문 stm32에서 RTC 시간 함수 쓰는데 의문점댓글[1] 라칸 23-09-25 40
질문 GPS 모듈 관련 질문입니다.댓글[3] 지구과학 23-09-22 34
질문 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[2] 둘둘이 23-09-22 65
답변 답변글 답변 : 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[1] master 23-09-25 43
질문 stm32 보드에서 시간설정과 불러오기를 하는데댓글[5] 라칸 23-09-22 46
질문 아두이노 인터럽트 질문입니다.댓글[2] Tell 23-09-21 50
답변 답변글 답변 : 아두이노 인터럽트 질문입니다.댓글[1] master 23-09-22 64
질문 아두이노와 거리 감지 센서의 전류 관련댓글[1] hmkim 23-09-21 76
질문 아두이노 코딩 질문있습니다. 도와주세요....댓글[1] 이미지첨부파일 vnpaz 23-09-20 81
질문 아두이노를 사용한 dc모터 위치제어댓글[2] 모터위치 23-09-20 75
질문 stm32 디버깅이나 rst버튼 없이 하는 방법좀댓글[1] 라칸 23-09-20 63
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 139
질문 알코올 측정기(MQ-3) 관련 질문 이미지 소오금 23-09-18 69
답변 답변글 답변 : 알코올 측정기(MQ-3) 관련 질문 master 23-09-19 119
질문 스텝모터 제어하는 소스파일 수정방법 질문드립니다. Bs드리프터 23-09-15 81
답변 답변글 답변 : 스텝모터 제어하는 소스파일 수정방법 질문드립니다.댓글[1] master 23-09-15 117
질문 atmega 128을 이용한 악기 튜너기댓글[1] 아두이노짱 23-09-15 322
질문 stm32 보드 ip주소 찾는법댓글[1] 라칸 23-09-13 75
