질문게시판 > 답변 : dc모터 제어 관련 질문 드려요 ㅠㅠ!!
TODAY523 TOTAL2,925,386
BASIC4MCU | 질문게시판 | 답변 : dc모터 제어 관련 질문 드려요 ㅠㅠ!!
작성자 master 작성일2023-06-07 11:40 조회409회 댓글0건
#include <Wire.h>
#include <LiquidCrystal_I2C.h>  // 아두이노 1
int IN1=3,IN2=4,ENA=5;
int trig_1=7,echo_1=6;    // 초음파1
int trig_2=9,echo_2=8;    // 초음파2
int trig_3=10,echo_3=11;  // 초음파3
int button_a=12,button_b=13;
unsigned long previousMillis=0; // 이전 시간
long interval=5000;
int preva_status=0,a_status=0;
int prevb_status=0,b_status=0;
long new_distance_1,new_distance_2,new_distance_3;
  pinMode(IN1,OUTPUT);    pinMode(IN2,OUTPUT); pinMode(ENA,OUTPUT);
  pinMode(trig_1,OUTPUT); pinMode(echo_1,INPUT);
  pinMode(trig_2,OUTPUT); pinMode(echo_2,INPUT);
  pinMode(trig_3,OUTPUT); pinMode(echo_3,INPUT);
  pinMode(button_a,INPUT); pinMode(button_b,INPUT);
  lcd.init(); lcd.backlight();
long distance_return(int trig,int echo){
  long duration,distance;
  digitalWrite(trig,0); delayMicroseconds(2);
  digitalWrite(trig,1); delayMicroseconds(10); digitalWrite(trig,0);
  duration=pulseIn(echo,1);
  distance=duration*170/1000 ;
  return distance;
void sensor_Print(long distance){
  Serial.print("거리: "); Serial.print(distance); Serial.println("mm");
void motor_stop(){ digitalWrite(IN1,0); digitalWrite(IN2,0); }
void motor_go()  { digitalWrite(IN1,1); digitalWrite(IN2,0); analogWrite(ENA,225); }
void motor_go_slow(){ // 벨트 천천히
  for(int pwm=225;pwm>0;pwm-=50){ if(pwm<0)pwm=0; analogWrite(ENA,pwm); delay(2000); }
    new_distance_1=distance_return(trig_1,echo_1);
    new_distance_2=distance_return(trig_2,echo_2);
    new_distance_3=distance_return(trig_3,echo_3);
    if(new_distance_1<50){
      lcd.setCursor(0,0); lcd.print("  a)Chocolate  ");
      lcd.setCursor(0,1); lcd.print("   b)Banana   ");
      previousMillis=millis();
      while(millis()-previousMillis<=8000){ // lcd선택+버튼 눌린 총 시간 약 7초
        a_status=digitalRead(12); b_status=digitalRead(13); delay(300); motor_stop();
        if(a_status>preva_status){
          Serial.print("A"); lcd.clear(); lcd.setCursor(0,0); lcd.print("  Good Choice!  "); lcd.setCursor(0,1); lcd.print("   Chocolate!   ");
        else if(b_status>prevb_status){
          Serial.print("B"); lcd.clear(); lcd.setCursor(0,0); lcd.print("  Good Choice!  "); lcd.setCursor(0,1); lcd.print("     Banana!    ");
        prevb_status=b_status; preva_status=a_status;
      lcd.clear(); motor_go(); delay(2000);
    else if(new_distance_2<50){
      lcd.setCursor(0,0); lcd.print("    Topping?    ");
      lcd.setCursor(0,1); lcd.print("   a)YES b)NO   ");
          Serial.print("a"); lcd.clear(); lcd.setCursor(0,0); lcd.print("   Good Choice!  "); lcd.setCursor(0,1); lcd.print("      YES!      ");
          Serial.print("b"); lcd.clear(); lcd.setCursor(0,0); lcd.print("   Good Choice!  "); lcd.setCursor(0,1); lcd.print("       NO       ");
    else if(new_distance_3<50){
      lcd.setCursor(0,0); lcd.print("    Milk ?    ");
      while(millis()-previousMillis<=20000){ // 우유시간 맞춰서 수정해야함 19초
          Serial.print("c"); lcd.clear(); lcd.setCursor(0,0); lcd.print("  Good Choice!  "); lcd.setCursor(0,1); lcd.print("     YES!    ");
          Serial.print("d"); lcd.clear(); lcd.setCursor(0,0); lcd.print("  Good Choice!  "); lcd.setCursor(0,1); lcd.print("    NO    ");
      lcd.clear(); motor_go_slow(); motor_stop(); delay(5000);
    motor_go();
#include <Servo.h> // 아두이노 2
Servo servo;
Servo servo2;
int IN1=7,IN2=6,speed1=9; // ENA pwm 조절 0~255
  servo.attach(13);
  servo2.attach(12);
  pinMode(speed1,OUTPUT); pinMode(IN1,OUTPUT); pinMode(IN2,OUTPUT);
  if(Serial.available()){
    char Data=Serial.read();
    if(Data=='A'){ servo.write( 90); delay(1000); }
    if(Data=='B'){ servo.write(180); delay(1000); }
    if(Data=='a'){ servo2.write(90); delay(1000); }
    if(Data=='b'){ servo2.write( 0); delay(1000); }
    if(Data=='c'){ digitalWrite(IN1,1); digitalWrite(IN2,0); analogWrite(speed1,255); delay(5000); }
    if(Data=='d'){ digitalWrite(IN3,1); digitalWrite(IN4,0); analogWrite(speed2,255); delay(5000); }
    servo.write(90);
    servo2.write(90);
    digitalWrite(IN1,0); digitalWrite(IN2,0); analogWrite(speed1,0);
와일문을 좋아하는 초보자님이 무섭습니다.
조회수 409
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 21055
공지 사이트 이용 안내댓글[29] master 17-10-29 34900
질문 질문있습니다ㅠㅠ 부탁드려요댓글[1] 새글 keldeo 02:57 7
질문 0 ~ 99 이중 for문으로 작성하는법!댓글[2] 새글 상어 23-09-26 11
질문 리튬배터리로 화면 출력 질문드립니다 !댓글[1] 이미지새글 멘탈나간다 23-09-26 9
질문 lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ댓글[1] 새글 아두이노개발자 23-09-26 22
질문 stm32에서 변수 값을 유지하는 방법댓글[1] 새글 라칸 23-09-26 16
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다댓글[1] 새글 노형빈 23-09-25 17
질문 16X16 도트 매트릭스 구동방법 질문입니다.댓글[1] 새글첨부파일 맹균 23-09-25 16
질문 stm32에서 RTC 시간 함수 쓰는데 의문점댓글[1] 새글 라칸 23-09-25 22
질문 GPS 모듈 관련 질문입니다.댓글[3] 지구과학 23-09-22 29
질문 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[2] 둘둘이 23-09-22 57
답변 답변글 답변 : 아두이노 블루투스와 초음파센서를 이용한 장애물 정지댓글[1] 새글 master 23-09-25 19
질문 stm32 보드에서 시간설정과 불러오기를 하는데댓글[5] 라칸 23-09-22 42
질문 아두이노 인터럽트 질문입니다.댓글[2] Tell 23-09-21 45
답변 답변글 답변 : 아두이노 인터럽트 질문입니다.댓글[1] master 23-09-22 54
질문 아두이노와 거리 감지 센서의 전류 관련댓글[1] hmkim 23-09-21 65
질문 아두이노 코딩 질문있습니다. 도와주세요....댓글[1] 이미지첨부파일 vnpaz 23-09-20 70
질문 아두이노를 사용한 dc모터 위치제어댓글[2] 모터위치 23-09-20 62
질문 stm32 디버깅이나 rst버튼 없이 하는 방법좀댓글[1] 라칸 23-09-20 53
질문 LCD에 숫자 표기법을 바꾸고 싶습니댓글[2] Bs드리프터 23-09-19 126
질문 알코올 측정기(MQ-3) 관련 질문 이미지 소오금 23-09-18 62
답변 답변글 답변 : 알코올 측정기(MQ-3) 관련 질문 master 23-09-19 112
질문 스텝모터 제어하는 소스파일 수정방법 질문드립니다. Bs드리프터 23-09-15 75
답변 답변글 답변 : 스텝모터 제어하는 소스파일 수정방법 질문드립니다.댓글[1] master 23-09-15 110
질문 atmega 128을 이용한 악기 튜너기댓글[1] 아두이노짱 23-09-15 316
질문 stm32 보드 ip주소 찾는법댓글[1] 라칸 23-09-13 68
질문 마이컴 종류 질문댓글[2] stevie8 23-09-12 122
질문 주파수 실수배 체배 관련문의댓글[6] 스쳐두임신 23-09-11 151
질문 스마트 창문 제작 중에 질문 있습니다!댓글[1] 이미지첨부파일 N8008 23-09-09 120
