질문게시판 > ATMEGA128, 스위치로 LED와 부저 제어하
TODAY2,193 TOTAL3,320,505
BASIC4MCU | 질문게시판 | ATMEGA128, 스위치로 LED와 부저 제어하
작성자 염소염소 작성일2023-06-22 16:59 조회1,900회 댓글1건
#define ON 1
#define OFF 0
volatile int Buzzerstate = OFF;
unsigned char OCRValue[8] = {238, 212, 189, 178, 158, 141, 126, 118}; //DOREMI
unsigned char LEDON[8] = {0X01, 0X02, 0X04, 0x08, 0x10, 0x20, 0x40, 0x80};
// Switch interrupt
ISR(INT0_vect) {
  Buzzerstate = !Buzzerstate;  // Toggle Buzzerstate when switch is pressed
int main() {
  DDRA = 0Xff; // LED OUTPORT
  DDRB |= 0x10; // Buzzer outport
  DDRD = 0X00; // SWITCH INPUTPORT
  EIMSK = 0X01; // Enable external interrupt 0
  EICRA = 0X02; // Trigger INT0 on falling edge
  sei(); // Enable global interrupt
  int i=0; // Initialize i
  while(1) {
    if(Buzzerstate == ON) { // If switch is pressed
      for(i=0; i<8; i++) {  // For each note
        PORTA = LEDON[i];   // Turn on corresponding LED
        OCR0 = OCRValue[i]; // Set corresponding OCR value
        _delay_ms(500);     // Delay for note duration
      Buzzerstate = OFF;   // After playing all notes, turn off buzzer
    } else {
      PORTB &= ~(1<<4); // Turn off buzzer
안녕하세요! 스위치로 부저와 LED제어를 하고 있습니다. 원하는 동작은 스위치on 하면
도레미파솔라시도가 연주되고 종료되는 코드입니다. LED는 음계에 따라
동작되고 멈추는데 부저에서 소리가 안납니다
조회수 1,900
타이머0 CTC 토글 Mode 사용하려는 것이겠죠?
    TCCR0=0x9C; OCR0=  4; //16000000/64/2/(1+  4),40us
    TCCR0=0x9C; OCR0=  9; //16000000/64/2/(1+  9),80us
    TCCR0=0x9C; OCR0= 14; //16000000/64/2/(1+ 14),120us
    TCCR0=0x9C; OCR0= 19; //16000000/64/2/(1+ 19),160us
    TCCR0=0x9C; OCR0= 24; //16000000/64/2/(1+ 24),200us
    TCCR0=0x9C; OCR0= 49; //16000000/64/2/(1+ 49),400us
    TCCR0=0x9C; OCR0= 74; //16000000/64/2/(1+ 74),600us
    TCCR0=0x9C; OCR0= 99; //16000000/64/2/(1+ 99),800us
    TCCR0=0x9C; OCR0=124; //16000000/64/2/(1+124),1ms
    TCCR0=0x9C; OCR0=149; //16000000/64/2/(1+149),1.2ms
    TCCR0=0x9C; OCR0=174; //16000000/64/2/(1+174),1.4ms
    TCCR0=0x9C; OCR0=199; //16000000/64/2/(1+199),1.6ms
    TCCR0=0x9C; OCR0=224; //16000000/64/2/(1+224),1.8ms
    TCCR0=0x9C; OCR0=249; //16000000/64/2/(1+249),2ms
    TCCR0=0x9D; OCR0=  4; //16000000/128/2/(1+  4),80us
    TCCR0=0x9D; OCR0=  9; //16000000/128/2/(1+  9),160us
    TCCR0=0x9D; OCR0= 24; //16000000/128/2/(1+ 24),400us
    TCCR0=0x9D; OCR0= 49; //16000000/128/2/(1+ 49),800us
    TCCR0=0x9D; OCR0= 74; //16000000/128/2/(1+ 74),1.2ms
    TCCR0=0x9D; OCR0= 99; //16000000/128/2/(1+ 99),1.6ms
    TCCR0=0x9D; OCR0=124; //16000000/128/2/(1+124),2ms
    TCCR0=0x9D; OCR0=249; //16000000/128/2/(1+249),4ms
    TCCR0=0x9E; OCR0=  4; //16000000/256/2/(1+  4),160us
    TCCR0=0x9E; OCR0= 24; //16000000/256/2/(1+ 24),800us
    TCCR0=0x9E; OCR0= 49; //16000000/256/2/(1+ 49),1.6ms
    TCCR0=0x9E; OCR0=124; //16000000/256/2/(1+124),4ms
    TCCR0=0x9E; OCR0=249; //16000000/256/2/(1+249),8ms
TCCR0 설정이 빠져있는 것 같습니다.
메인 무한루프 전에 설정하세요
TCCR0=0x9D; 이 설정을 먼저 사용해보고 멜로디가 이상하면 TCCR0=0x9C 또는 TCCR0=0x9E 등으로 바꿔보세요
질문 No source available for "<signal handler called>() at 0xffff…댓글[2] 라칸 24-03-20 322
질문 Atmega128A 초음파 3개로 led3개를 각각 제어하고 싶은데 안됩니다 도와주세요..댓글[2] 밍토리 24-03-11 606
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 485
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 543
질문 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의 손문일 23-12-08 349
답변 답변글 답변 : 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의댓글[2] master 23-12-08 684
질문 pwm을 이용한 led댓글[1] 이미지첨부파일 아자자자자자 23-12-02 613
질문 조도 센서를 이용하여 pwm모드로 led밝기 조절 아자자자자자 23-12-02 566
답변 답변글 답변 : 조도 센서를 이용하여 pwm모드로 led밝기 조절댓글[2] master 23-12-02 847
질문 AD 내부 인터럽트를 이용해 조도센서를 통한 LED 제어 첨부파일 푸글릿 23-11-21 757
답변 답변글 답변 : AD 내부 인터럽트를 이용해 조도센서를 통한 LED 제어댓글[1] master 23-11-21 1474
질문 질문 아두이노 - ph 센서 이용 LED 켜기댓글[2] 이미지첨부파일 잼민 23-11-20 1321
답변 답변글 답변 : 질문 아두이노 - ph 센서 이용 LED 켜기 이미지 master 23-11-20 1211
질문 초음파센서 두개사용하여 물체탐지 Led댓글[1] 알려주새ㅔㅔ요ㅠ 23-10-16 1561
질문 atmega128 lcd led 동시 제어 ewaesdf 23-10-09 1209
답변 답변글 답변 : atmega128 lcd led 동시 제어 master 23-10-09 1238
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다댓글[1] 노형빈 23-09-25 1263
질문 ATMEGA128 LED 제어 질문댓글[2] 이미지첨부파일 mango 23-07-22 2013
질문 atmega128 led 제어 질문댓글[2] 이미지 mango 23-07-20 1858
질문 ADC 이용한 NTC 써미스터 온도 센서로 LED 밝기 조절댓글[4] 밍구리 23-06-26 2879
질문 Trm121 가까이 가면 led 점등댓글[1] 첨부파일 그냥사는사람 23-06-25 1155
현재글 ATMEGA128, 스위치로 LED와 부저 제어하댓글[1] 염소염소 23-06-22 1901
질문 Atmega128 온도센서로 led제어 질문드려요댓글[1] 이미지첨부파일 얍얍 23-06-05 2114
질문 아두이노 시리얼 번호를 이용해 led 제어 wnion 23-06-04 1318
답변 답변글 답변 : 아두이노 시리얼 번호를 이용해 led 제어 master 23-06-07 1108
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 3096
질문 아두이노 버튼으로 led제어 질문댓글[3] wnion 23-05-13 3179
질문 atmega128 led 점등댓글[1] 부경 23-04-06 3138
질문 아두이노 근접센서 led제어댓글[1] 김민종 23-04-05 2434
질문 아두이노 led 부저 스위치 김똘 23-03-30 1852
