질문게시판 > ADC 이용한 NTC 써미스터 온도 센서로 LED 밝기 조절
TODAY9,830 TOTAL4,868,003
BASIC4MCU | 질문게시판 | ADC 이용한 NTC 써미스터 온도 센서로 LED 밝기 조절
작성자 밍구리 작성일2023-06-26 11:05 조회5,507회 댓글4건
#define F_CPU      16000000UL
#define REF_VOLTAGE 5.0
#define SERIESRESISTOR 100000
#define NOMAL_R 100000
#define NOMAL_TEMP 25
#define B 4100
#define ledPin  10
#define RPin  A2
#define NTCPin  A3
int bright;
int tValue;
float ADC_value=0 ;
float ADC_value2=0;
float Resistance; //Rt
float temp;
float adc;
//unsigned int sum=0;
int i;
int ADC_READ()
  ADCSRA =0b11010111 ; //
  while((ADCSRA & 0x10) == 1);
  int adc=0;
  float value=0;
  value = ADC_value*REF_VOLTAGE/1024; //10비트
  adc = value*10;
  Serial.print("Temperature");
  Serial.println(adc);
  tValue =constrain(adc, 25, 35);
  bright = map_test(tValue, 25, 35,0,255);
  analogWrite(ledPin,bright);
 ADCSRA = 0b11010101;
 //  ADCSRA = 0xD5;
   while((ADCSRA & 0x10) == 0);
   adc = (  (int)ADCL + ((int)ADCH<<8) ) ;
    adc = (adc*5)/1024 ;
 ADCSRA = ADCSRA & 0x3f;
 ADMUX = 0x60 | (port & 0x0f);
 ADCSRA = ADCSRA | 0xc0;
  return adc;
int read_tempt()
ADC_value = adc ; //A2에서 받아오는 값 Vo
Serial.print("ADC ");
Serial.println(ADC_value);
//Serial.print(" = ");
 ADC_value2 = 1023 ; //A3에서 받아오는 값 Vs=1023
Resistance =  ADC_value2 * SERIESRESISTOR; //Vs*Ro
Resistance = Resistance / ADC_value; //(Vs*Ro)/Vo
Resistance = Resistance - SERIESRESISTOR; ////(Vs*Ro)/Vo-Ro
Serial.print("Resistanc");
Serial.print(Resistance);
Serial.println(" Ohm");
float temp;
temp = Resistance / SERIESRESISTOR; // (Rt/Ro)
temp = log(temp); // ln(Rt/Ro)
temp /= B; // 1/B * ln(Rt/Ro)
temp += 1.0 / (NOMAL_TEMP + 273.15); // + (1/To)
temp = 1.0 / temp; // 역수
temp -= 273.15; //c로 전환
 return temp;
int map_test(int input, int min_in , int max_in, int out_in, int out_max)
float z=0;
z=256/(max_in-min_in)*(input-min_in);
return z;
int main() {
   pinMode(ledPin,OUTPUT);
   ADMUX = 0b00000000; //00 = 외부의 AREF 단자로 입력된 전압을 사용
   ADCSRA = 0b10000101; // 분주비 101=32 (16MHz/32=500000)
   ADCSRB = 0b00000000;
   sei();  //모든 인터럽트를 활성화
    ADC_READ();
    temp=read_tempt();
    tValue =constrain(temp, 25, 35); //25c일때의 ADCvalue값~50c일때의 ADCvalue값으로 제한
    bright = map_test(tValue, 25, 35,0,250);
    Serial.println(temp);
ADC를 이용헤서 NTC 써미스터 온도 센서로 온도를 측정하고 온도에 따라 LED 밝기 조절을 하고 싶은데 이렇게 돌렸더니 전혀 작동하질 않네요
어느 부분이 잘못된 걸까요?
댓글 4
조회수 5,507
AVR과 아두이노 구분을 하지 못하고 계신 것 같습니다.
밍구리님의 댓글
밍구리 댓글의 댓글 작성일
아 그렇네요 예전에 쓴 코드를 가져오다가 섞였네요 그럼
DDRB = 0b00010000;
  TCCR1A=0b10101010;
  TCCR1B=0b00011010;
하고 고속 PWM 모드를 사용한다고 하면 OCR 값으로 듀티비를 지정하는 것 까지는 알겠는데 온도값에 따라 밝기를 설정해주려면 어떤 식으로 코드를 짜야할까요?
https://cafe.naver.com/circuitsmanual/71343
강좌글 참고하세요
온도값을 먼저 제대로 읽는 지 확인 한 후에
온도값에 따른 밝기를 출력하면 됩니다.
https://cafe.naver.com/circuitsmanual/151206
    OCR1A=speed; //PB5
OC1A는 PB4가 아니고 PB5입니다.
DDRB = 0b00010000; 이렇게 설정하면 안되고 DDRB = 0x20;  이렇게 설정해야겠죠
밍구리님의 댓글
밍구리 댓글의 댓글 작성일
아 이해했습니다! 핀 바꿔주고 온도 계산해서 if 문으로 온도별 %값 다르게 설정해줬더니 잘 작동하네요 감사합니다!
질문 아두이노 압력 센서로 LED 불빛 들어오게 할려고 하는데... 이미지첨부파일 윤시기 24-09-12 436
답변 답변글 답변 : 아두이노 압력 센서로 LED 불빛 들어오게 할려고 하는데... 이미지 master 24-09-12 308
질문 LED와 FND의 출력이 제가 생각한대로 나오지 않아요.댓글[4] 킹왕짱 24-07-24 1028
질문 atmega128 recipe for target 'main.o ' failed 오류댓글[3] hhhyyyeee 24-06-19 1280
질문 No source available for "<signal handler called>() at 0xffff…댓글[2] 라칸 24-03-20 1362
질문 Atmega128A 초음파 3개로 led3개를 각각 제어하고 싶은데 안됩니다 도와주세요..댓글[2] 밍토리 24-03-11 1724
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 1233
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 991
질문 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의 손문일 23-12-08 546
답변 답변글 답변 : 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의댓글[2] master 23-12-08 1158
질문 pwm을 이용한 led댓글[1] 이미지첨부파일 아자자자자자 23-12-02 1307
질문 조도 센서를 이용하여 pwm모드로 led밝기 조절 아자자자자자 23-12-02 1000
답변 답변글 답변 : 조도 센서를 이용하여 pwm모드로 led밝기 조절댓글[2] master 23-12-02 2070
질문 AD 내부 인터럽트를 이용해 조도센서를 통한 LED 제어 첨부파일 푸글릿 23-11-21 1040
답변 답변글 답변 : AD 내부 인터럽트를 이용해 조도센서를 통한 LED 제어댓글[1] master 23-11-21 1867
질문 질문 아두이노 - ph 센서 이용 LED 켜기댓글[2] 이미지첨부파일 잼민 23-11-20 2554
답변 답변글 답변 : 질문 아두이노 - ph 센서 이용 LED 켜기 이미지 master 23-11-20 1576
질문 초음파센서 두개사용하여 물체탐지 Led댓글[1] 알려주새ㅔㅔ요ㅠ 23-10-16 2028
질문 atmega128 lcd led 동시 제어 ewaesdf 23-10-09 1604
답변 답변글 답변 : atmega128 lcd led 동시 제어 master 23-10-09 1561
질문 안녕하세요 스위치로 led 제어 관련 질문이 있습니다댓글[1] 노형빈 23-09-25 1817
질문 ATMEGA128 LED 제어 질문댓글[2] 이미지첨부파일 mango 23-07-22 3223
질문 atmega128 led 제어 질문댓글[2] 이미지 mango 23-07-20 2993
현재글 ADC 이용한 NTC 써미스터 온도 센서로 LED 밝기 조절댓글[4] 밍구리 23-06-26 5508
질문 Trm121 가까이 가면 led 점등댓글[1] 첨부파일 그냥사는사람 23-06-25 1632
질문 ATMEGA128, 스위치로 LED와 부저 제어하댓글[1] 염소염소 23-06-22 2500
질문 Atmega128 온도센서로 led제어 질문드려요댓글[1] 이미지첨부파일 얍얍 23-06-05 2763
질문 아두이노 시리얼 번호를 이용해 led 제어 wnion 23-06-04 1623
답변 답변글 답변 : 아두이노 시리얼 번호를 이용해 led 제어 master 23-06-07 1429
질문 atmega128 led와 fan댓글[3] 이라 23-05-28 6408
