질문게시판 > lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ
TODAY849 TOTAL3,072,943
BASIC4MCU | 질문게시판 | lcd,바코드,서보모터, 아두이노 질문 드립니다. ㅠㅠ
작성자 아두이노개발자 작성일2023-09-26 11:24 조회735회 댓글1건
바코드 인식을 LCD로 하는 과정에서 문제가 있어 질문 드립니다.
#include <usbhid.h>
#include <usbhub.h>
#include <hiduniversal.h>
#include <hidboot.h>
#include <SPI.h>
class MyParser : public HIDReportParser {
  public:
    MyParser();
    void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
  protected:
    uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
    virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
    virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
  // If error or empty, return
  if (buf[2] == 1 || buf[2] == 0) return;
  for (uint8_t i = 7; i >= 2; i--) {
    // If empty, skip
    if (buf[i] == 0) continue;
    // If enter signal emitted, scan finished
    if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
      OnScanFinished();
    // If not, continue normally
    else {
      // If bit position not in 2, it's uppercase words
      OnKeyScanned(i > 2, buf, buf[i]);
    return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
  // Letters
  if (VALUE_WITHIN(key, 0x04, 0x1d)) {
    if (upper) return (key - 4 + 'A');
    else return (key - 4 + 'a');
  // Numbers
  else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
    return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
  return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
  uint8_t ascii = KeyToAscii(upper, mod, key);
  Serial.print((char)ascii);
void MyParser::OnScanFinished() {
USB          Usb;
USBHub       Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser     Parser;
  Serial.begin( 115200 );
  if (Usb.Init() == -1) {
    Serial.println("OSC did not start.");
  delay( 200 );
  Hid.SetReportParser(0, &Parser);
  Usb.Task();
#include <Servo.h>
#include <Wire.h>
Servo servo1;
Servo servo2;
int Trig1 = 10;
int Echo1 = 11;
int Trig2 = 8;
int Echo2 = 9;
int ultrasonic_1 = 2;
int ultrasonic_2 = 3;
int ultrasonic_num_1 = 0;
int ultrasonic_num_2 = 0;
unsigned long current_time;
unsigned long code1_time[5];
unsigned long code2_time[5];
int code1_count = 0;
int code2_count = 0;
int code1_count2 = 0;
int code2_count2 = 0;
int code1_num_1 = 0;
int code2_num_1 = 0;
int code1_num_2 = 0;
int code2_num_2 = 0;
char recieved_data;
int recieved_data_num;
  Serial.begin(115200);
  lcd.init();
  lcd.backlight();
  pinMode(Trig1, OUTPUT);
  pinMode(Echo1, INPUT);
  pinMode(Trig2, OUTPUT);
  pinMode(Echo2, INPUT);
  pinMode(ultrasonic_1, OUTPUT);
  pinMode(ultrasonic_2, OUTPUT);
  servo1.attach(6);
  servo2.attach(5);
  servo1.write(0);
  servo2.write(0);
  current_time = millis();
  if(Serial.available()) {
    recieved_data = Serial.read();
    Serial.println(recieved_data);
  lcd.setCursor(0,0);
  lcd.print("Black_  RED_    ");
  if(recieved_data == '1') {
    code1_time[code1_count] = current_time + 3400; //3초 후
    code1_num_1 = 1;
    code1_count++;
    code1_count2++;
  lcd.setCursor(0,1);
  lcd.print("IN:");
  lcd.setCursor(3,1);
  lcd.print(code1_count2);
  for(int i = 0; i < 5; i++) {
    if((code1_num_1 == 1) && (code1_time[i] < current_time) && (current_time < code1_time[i] + 250)) {
      code1_num_2 = 1;
  if(code1_num_2 == 1) {
    servo1.write(40);
    code1_num_2 = 0;
    else if(code1_num_2 == 0) {
      servo1.write(0);
  if(recieved_data == '2') {
    code2_time[code2_count] = current_time + 5500; //5초 후
    code2_num_1 = 1;
    code2_count++;
    code2_count2++;
  lcd.setCursor(8,1);
  lcd.print("IN:");
  lcd.setCursor(11,1);
  lcd.print(code2_count2);
    if((code2_num_1 == 1) && (code2_time[i] < current_time) && (current_time < code2_time[i] + 250)) {
      code2_num_2 = 1;
  if(code2_num_2 == 1) {
    servo2.write(40);
    code2_num_2 = 0;
    else if(code2_num_2 == 0) {
      servo2.write(0);
  digitalWrite(Trig1, LOW);
  digitalWrite(Echo1, LOW);
  delayMicroseconds(2);
  digitalWrite(Trig1, HIGH);
  delayMicroseconds(10);
  unsigned long duration1= pulseIn(Echo1, HIGH);
  float distance1 = ((float)(340 * duration1) / 10000) / 2;
  digitalWrite(Trig2, LOW);
  digitalWrite(Echo2, LOW);
  digitalWrite(Trig2, HIGH);
  unsigned long duration2= pulseIn(Echo2, HIGH);
  float distance2 = ((float)(340 * duration2) / 10000) / 2;
    if((code1_num_1 == 1) && (distance1 < 4) && (code1_time[i] - 1000 < current_time) && (current_time < code1_time[i] + 1000)) {
      ultrasonic_num_1 = 1;
  if(ultrasonic_num_1 == 1) {
    digitalWrite(ultrasonic_1, HIGH);
    } else {
      digitalWrite(ultrasonic_1, LOW);
    if((code2_num_1 == 1) && (distance2 < 4) && (code2_time[i] - 1000 < current_time) && (current_time < code2_time[i] + 1000)) {
      ultrasonic_num_2 = 1;
  if(ultrasonic_num_2 == 1) {
    digitalWrite(ultrasonic_2, HIGH);
    } else {
      digitalWrite(ultrasonic_2, LOW);
  recieved_data = 0;
  if(code1_count == 4) {
    code1_count = 0;
  if(code2_count == 4) {
    code2_count = 0;
  delay(200);
  lcd.clear();
조회수 735
동일한 회로를 가지고 있고
회로 연결도 동일하게 했을 경우에만
동일한 증상을 겪을 수 있습니다.
불가능하겠죠?
설명을 많이 하셔야 할 것 같습니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23059
공지 사이트 이용 안내댓글[30] master 17-10-29 36174
질문 ATmega128 to ATmega128로 USART 통신 질문 새글 alsdn 23-12-08 45
답변 답변글 답변 : ATmega128 to ATmega128로 USART 통신 질문 새글 master 23-12-08 50
질문 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의 손문일 23-12-08 32
답변 답변글 답변 : 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의댓글[2] master 23-12-08 48
질문 아두이노 L9110 DC모터 제어댓글[1] wdsdd 23-12-08 61
질문 Atmega128 CLCD와 블루투스 통신 문제댓글[1] fanfan 23-12-07 84
답변 답변글 답변 : Atmega128 CLCD와 블루투스 통신 문제댓글[3] master 23-12-07 80
질문 스마트팜 관련 질문댓글[1] 이미지첨부파일 생물공학도 23-12-07 43
질문 아두이노 자판기 질문입니다댓글[1] 한세월두세월 23-12-06 76
답변 답변글 답변 : 아두이노 자판기 질문입니다 master 23-12-07 38
질문 atmega128 질문있습니다댓글[1] 이미지첨부파일 아자자자자자 23-12-06 91
질문 스텝모터 제어 및 온도센서 값 동시 추출 질문드립니다.댓글[1] metanoia 23-12-06 37
질문 ATmega128에서 LCD와 블루투스 fanfan 23-12-05 130
답변 답변글 답변 : ATmega128에서 LCD와 블루투스댓글[1] master 23-12-05 164
질문 atmega128 압력센서 관해댓글[2] 메시기모찌 23-12-04 150
질문 안녕하세요 심장박동센서를 이용해 일정 심박수 이상이되면 부저 작동에 대해서 질문드립니다.댓글[8] 충전공 23-12-04 163
질문 atmega128 CLCD댓글[2] 릴를 23-12-03 258
질문 atmega128 블루투스 CLCD댓글[3] 릴를 23-12-03 230
질문 pwm을 이용한 led댓글[1] 이미지첨부파일 아자자자자자 23-12-02 99
질문 스텝모터, 컬러센서를 이용한 아두이노댓글[3] 초식동물 23-12-02 146
질문 조도 센서를 이용하여 pwm모드로 led밝기 조절 아자자자자자 23-12-02 85
답변 답변글 답변 : 조도 센서를 이용하여 pwm모드로 led밝기 조절댓글[2] master 23-12-02 59
질문 RFID를 이용한 자판기 질문입니다.댓글[1] 왕초보두이노 23-12-02 74
질문 ATMEGA 128 초음파 센서 거리에 따른 부저 작동 질문드립니다.댓글[7] 충전공 23-12-02 382
질문 atmega128a 외부인터럽트 두개와 7segment의 연결 우엉 23-12-02 117
답변 답변글 답변 : atmega128a 외부인터럽트 두개와 7segment의 연결 master 23-12-02 111
질문 atmega128 스위치 서보모터댓글[1] 메시기모찌 23-12-02 238
질문 atmega128 모터 질문입니다댓글[4] 이미지 릴를 23-12-01 215
