질문게시판 > esp32링크가 안 나옵니
TODAY25,662 TOTAL9,413,281
BASIC4MCU | 질문게시판 | esp32링크가 안 나옵니
작성자 선우04 작성일2023-11-24 04:56 조회1,535회 댓글1건
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
//            Ensure ESP32 Wrover Module or other board with PSRAM is selected
//            Partial images will be transmitted if image exceeds buffer size
//            You must select partition scheme from the board menu that has at least 3MB APP space.
//            Face Recognition is DISABLED for ESP32 and ESP32-S2, because it takes up from 15
//            seconds to process single frame. Face Detection is ENABLED if PSRAM is enabled as well
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char* ssid = "2023821017";
const char* password = "anes8478@@";
void startCameraServer();
void setupLedFlash(int pin);
  Serial.begin(115200);
  Serial.setDebugOutput(true);
  Serial.println();
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG; // for streaming
  //config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(config.pixel_format == PIXFORMAT_JPEG){
    if(psramFound()){
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
    } else {
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
  } else {
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
  s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash(LED_GPIO_NUM);
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  // Do nothing. Everything is done in another task by the web server
  delay(10000);
이렇게 코드를 작성했고 업로드는 전혀 문제가 안 생기는데 시리얼 모니터에서 rst 버튼을 누르면 url 링크가 나와야 하는데
오류 코드가 나옵니다 해결 하는 방법좀 알려주세요
..........ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
E (494) esp_core_dump_f�ff�� No core dump partition found!
E (494) esp_core_dump_flash: No core dump partition found!
조회수 1,535
https://forum.arduino.cc/t/esp32-cam-esp-core-dump-flash/1074812/16
이 글도 참고하시고
더 많은 글은 웹검색 참고하세요
https://www.google.com/search?q=E+(494)+esp_core_dump_f%EF%BF%BDff%EF%BF%BD%EF%BF%BD+No+core+dump+partition+found!&oq=E+(494)+esp_core_dump_f%EF%BF%BDff%EF%BF%BD%EF%BF%BD+No+core+dump+partition+found!&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBBzgxM2owajeoAgCwAgA&sourceid=chrome&ie=UTF-8
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 3241
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 7739
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 4593
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 1320
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 1518
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 1275
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 1112
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 1424
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 970
답변 답변글 답변 : atmega 128 timer interrupt에 관한 질문 master 23-12-13 819
질문 Atmega128에서 시계코드에 스톱워치, 타이머를 추가하고 싶습니다. 주넘 23-12-11 1230
답변 답변글 답변 : Atmega128에서 시계코드에 스톱워치, 타이머를 추가하고 싶습니다. master 23-12-13 1009
질문 atmega128에서 16x16 LDM에 좌측부분이 안나옵니다.댓글[1] 이미지 주넘 23-12-11 1610
질문 ATmega128 to ATmega128로 USART 통신 질문 alsdn 23-12-08 1140
답변 답변글 답변 : ATmega128 to ATmega128로 USART 통신 질문 master 23-12-08 1217
질문 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의 손문일 23-12-08 868
답변 답변글 답변 : 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의댓글[2] master 23-12-08 2304
질문 아두이노 L9110 DC모터 제어댓글[1] wdsdd 23-12-08 1540
질문 Atmega128 CLCD와 블루투스 통신 문제댓글[1] fanfan 23-12-07 2206
답변 답변글 답변 : Atmega128 CLCD와 블루투스 통신 문제댓글[3] master 23-12-07 5939
질문 스마트팜 관련 질문댓글[3] 이미지첨부파일 생물공학도 23-12-07 3842
질문 아두이노 자판기 질문입니다댓글[1] 한세월두세월 23-12-06 1592
답변 답변글 답변 : 아두이노 자판기 질문입니다 master 23-12-07 1003
질문 atmega128 질문있습니다댓글[1] 이미지첨부파일 아자자자자자 23-12-06 2042
질문 스텝모터 제어 및 온도센서 값 동시 추출 질문드립니다.댓글[1] metanoia 23-12-06 1830
질문 ATmega128에서 LCD와 블루투스 fanfan 23-12-05 1812
답변 답변글 답변 : ATmega128에서 LCD와 블루투스댓글[1] master 23-12-05 2931
질문 atmega128 압력센서 관해댓글[2] 메시기모찌 23-12-04 5848
질문 안녕하세요 심장박동센서를 이용해 일정 심박수 이상이되면 부저 작동에 대해서 질문드립니다.댓글[8] 충전공 23-12-04 53778
질문 atmega128 CLCD댓글[2] 릴를 23-12-03 6219
