질문게시판 > 서브모터,I2C LCD, RFID, 버튼을 이용한 아두이노
TODAY6,897 TOTAL11,521,159
BASIC4MCU | 질문게시판 | 서브모터,I2C LCD, RFID, 버튼을 이용한 아두이노
작성자 돕고살려주세요 작성일2023-11-30 21:54 조회2,659회 댓글1건
#include<Servo.h>
#include<SPI.h>
#include<MFRC522.h>
#include<Wire.h>
#include<LiquidCrystal_I2C.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
Servo servo;
int a,b,c,d;
  SPI.begin();
  lcd.begin(2,16);
  pinMode(OUTPUT, 5);
  pinMode(OUTPUT, 6);
  pinMode(OUTPUT, 7);
  pinMode(OUTPUT, 8);
  mfrc522.PCD_Init();
  lcd.print("   Press Button");
  lcd.clear();
  lcd.print("  Press the button  ");
  a = digitalRead(5);
  b = digitalRead(6);
  c = digitalRead(7);
  d = digitalRead(8);
  Serial.print(a);
  Serial.print(b);
  Serial.print(c);
  Serial.print(d);
  if(a==0)
    lcd.clear();
    lcd.print("    give me your card");
    delay(9000);
    if( ! mfrc522.PICC_IsNewCardPresent())
      return;
    if(! mfrc522. PICC_ReadCardSerial())
      return;
    Serial.print("UID tag : ");
    String content = "";
    byte letter;
    for(byte i =0; i<mfrc522. uid.size; ++i)
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " ");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "));
      content.concat(String(mfrc522.uid.uidByte[i], HEX));
    Serial.println();
    Serial.print("Message : ");
    content.toUpperCase();
    if(content.substring(1) =="2B 3C C9 23")
      servo.attach(A0);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      lcd.print("  Take the cookies");
      delay(5000);
  if(b==0)
    lcd.clear();
    delay(9000);
      return;
      return;
    byte letter;
    Serial.println();
      servo.attach(2);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
  if(c==0)
    lcd.clear();
    delay(9000);
      return;
      return;
    byte letter;
    Serial.println();
      servo.attach(3);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
  if(d==0)
    lcd.clear();
    delay(9000);
      return;
      return;
    byte letter;
    Serial.println();
      servo.attach(4);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
제가 유튜브를 보고 RFID를 이용한 자판기를 만들어 볼려고 하는데, 유튜브에 있는대로 따라해봤지만 LCD에는 검은색 블록이 나열되어 출력이 되고, 버튼을 누른 뒤 RFID에 카드(RFID)를 접촉시키면, 360도 서브모터가 돌아가 과자가 떨어지게 행동이 됐어야 하는데, 어떠한 문제가 있는건지 RFID도 인식을 못하고, button을 눌러도 아무런 반응을 하지 않습니다. 핀도 모두 lcd는 아날로그 쪽에, RFID는 디지털 쪽에 점프선을 연결 했는데도 안됩니다. 혹시 어떠한 문제가 있는지, 해결방안도 설명해주시면 감사하겠습니다.
라이브러리도 다 깔았고 lcd의 주소도 확인하여 맞췄습니다. 제가 아두이노를 접한지 얼마 되지 않아서 도와주시면 감사하겠습니다.
혹시 제가 틀렸을수도 있으니, 제가 본 유튜브 링크 남겨보겠습니다.
작동방식
1. LCD에 "Press the button" 이라는 문구가 뜬다.
2. Give me your card라는 문구가 뜨면 RFID에 카드를 접촉시킨다.
3.그 버튼에 해당하는 서브모터가 돌아가면서 과자를 떨어뜨린다.
4.lcd에 Take the cookies라는 문구가 뜬다
5.lcd가 다시 초기화 한다.
조회수 2,659
LCD 예제/ RFID예제/ 서보모터 예제/ 스위치예제/로 충분히 학습한 후에 다시 시도 해보세요
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 1733
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 6804
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 2178
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 1002
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 1013
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 3493
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 8350
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 4900
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 1443
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 1637
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 1360
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 1175
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 1527
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 1027
답변 답변글 답변 : atmega 128 timer interrupt에 관한 질문 master 23-12-13 882
질문 Atmega128에서 시계코드에 스톱워치, 타이머를 추가하고 싶습니다. 주넘 23-12-11 1298
답변 답변글 답변 : Atmega128에서 시계코드에 스톱워치, 타이머를 추가하고 싶습니다. master 23-12-13 1071
질문 atmega128에서 16x16 LDM에 좌측부분이 안나옵니다.댓글[1] 이미지 주넘 23-12-11 1701
질문 ATmega128 to ATmega128로 USART 통신 질문 alsdn 23-12-08 1238
답변 답변글 답변 : ATmega128 to ATmega128로 USART 통신 질문 master 23-12-08 1290
질문 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의 손문일 23-12-08 962
답변 답변글 답변 : 네오픽셀 Rainbow코드 LED주소 지정하는 법 문의댓글[2] master 23-12-08 2524
질문 아두이노 L9110 DC모터 제어댓글[1] wdsdd 23-12-08 1660
질문 Atmega128 CLCD와 블루투스 통신 문제댓글[1] fanfan 23-12-07 2336
답변 답변글 답변 : Atmega128 CLCD와 블루투스 통신 문제댓글[3] master 23-12-07 6251
질문 스마트팜 관련 질문댓글[3] 이미지첨부파일 생물공학도 23-12-07 4138
질문 아두이노 자판기 질문입니다댓글[1] 한세월두세월 23-12-06 1684
답변 답변글 답변 : 아두이노 자판기 질문입니다 master 23-12-07 1072
질문 atmega128 질문있습니다댓글[1] 이미지첨부파일 아자자자자자 23-12-06 2174
질문 스텝모터 제어 및 온도센서 값 동시 추출 질문드립니다.댓글[1] metanoia 23-12-06 1972
