질문게시판 > RFID를 이용한 자판기 질문입니다.
TODAY360 TOTAL3,162,636
BASIC4MCU | 질문게시판 | RFID를 이용한 자판기 질문입니다.
작성자 왕초보두이노 작성일2023-12-02 18:47 조회281회 댓글1건
#include <Servo.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
Servo servo;
int a, b, c, d ;
  for(int i=5;i<=8;i++)pinMode(i,INPUT_PULLUP); // <-- 수정
  lcd.init();
  lcd.backlight();
  lcd.print("    Press Button");
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.clear();
  a = digitalRead(5);
  b = digitalRead(6);
  c = digitalRead(7);
  d = digitalRead(8);
  Serial.print(a);
  Serial.print(b);
  Serial.print(c);
  Serial.print(d);
  //////////////////////////////////////a////////////////////////////////
  if( a== 0)
    lcd.clear();
    lcd.print("        5$         ");
    delay(2000);
    lcd.clear();
    lcd.print("  give your card");
    delay(3000);
    if( ! mfrc522.PICC_IsNewCardPresent())
      return;
    if(! mfrc522.PICC_ReadCardSerial())
      return;
    Serial.print("UID tag : ");
    String content ="";
    byte letter;
    for(byte i=0; i<mfrc522.uid.size; ++i)
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " ");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "));
      content.concat(String(mfrc522.uid.uidByte[i], HEX));
    Serial.println();
    Serial.print("Message : ");
    content.toUpperCase();
    if( content.substring(1) == "2B 3C C9 23")
      servo.attach(A0);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      lcd.print(" Take the cookies");
      delay(5000);
    //////////////////////////////////////b////////////////////////////////
  if( b== 0)
     lcd.clear();
    lcd.print("        6$         ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(2);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    //////////////////////////////////////c////////////////////////////////
  if( c== 0)
    lcd.clear();
    lcd.print("        6$         ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(3);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    /////////////////////////////////////d////////////////////////////////
  if( d== 0)
     lcd.clear();
    lcd.print("        8$         ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(4);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
컴파일도 정상정으로 되고, 업로딩도 됩니다. 스위치를 누르면 lcd에 문구까지 뜨는데, RFID가 인식을 못하는건지 RFID가 작동이 안됩니다.
버튼을 누르고 give me your card라는 텍스트가 lcd에 뜨면 RFID에 카드를 인식시켜 서브모터가 돌아가게 하는 작동방식인데 혹시 명령어에 문제가 있는지 궁금해서 가르쳐 주시면 감사하겠습니다.
조회수 281
RFID 예제를 돌려보면 문제가 있는지 알 수 있겠죠?
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36691
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 19
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 66
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 93
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 271
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 173
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 971
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 215
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 206
질문 All-in-one air quality sensor Fosen 23-12-18 118
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 252
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 501
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 269
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 221
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 265
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 566
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 321
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 190
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 178
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 311
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 791
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 563
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 218
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 273
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 326
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 235
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 287
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 268
