질문게시판 > 답변 : atmega128a 외부인터럽트 두개와 7segment의 연결
TODAY5,507 TOTAL3,486,644
BASIC4MCU | 질문게시판 | 답변 : atmega128a 외부인터럽트 두개와 7segment의 연결
작성자 master 작성일2023-12-02 18:58 조회650회 댓글0건
#define F_CPU 16000000
#define B0   458
#define C1   523    // 도
#define C1_  554
#define D1   587    // 레
#define D1_  622
#define E1   659    // 미
#define F1   699    // 파
#define F1_  740
#define G1   784    // 솔
#define G1_  831
#define A1   880    // 라
#define A1_  932
#define B1   988    // 시
#define C2   C1*2   // 도
#define C2_  C1_*2
#define D2   D1*2   // 레
#define D2_  D1_*2
#define E2   E1*2   // 미
#define F2   F1*2   // 파
#define F2_  F1_*2
#define G2   G1*2   // 솔
#define G2_  G1_*2
#define A2   A1*2   // 라
#define A2_  A1_*2
#define B2   B1*2   // 시
#define DLY_0   32  // 온음표*2
#define DLY_1   16  // 온음표
#define DLY_2   8   // 2분 음표
#define DLY_4   4   // 4분 음표
#define DLY_8   2   // 8분 음표
#define DLY_16  1   // 16분 음표
volatile int santa[100]={E1,F1,G1,G1,A1,B1,C2,C2,E1,F1,G1,G1,G1,G1,G1,A1,G1,F1,F1,F1,E1,G1,C1,E1,D1,F1,F1,C1,B1};
volatile int santa_length[100]={DLY_8,DLY_8,DLY_4,DLY_2,DLY_8,DLY_8,DLY_4,DLY_2,DLY_8,DLY_8,DLY_8,DLY_8,DLY_8,DLY_8,DLY_4,DLY_8,DLY_8,DLY_8,DLY_8,DLY_4,DLY_2,DLY_2,DLY_2,DLY_2,DLY_2,DLY_2,DLY_1,DLY_2,DLY_1,};
char COLUMN[4]={0,0,0,0};
volatile unsigned char Segment_Data[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x27,0x7F,0x6F};
volatile char calender[0]={0};
volatile char flag0=0,flag1=0,flag2=0;
volatile int  freq=1000,i;
volatile int count;
volatile unsigned char TIMERvalue=0xFF;
volatile unsigned char keyin=0;  // Declare and initialize keyin
volatile unsigned char keyold=0; // Declare and initialize keyold
volatile unsigned char change=0; // Declare and initialize change
volatile int SHOW_1=1; // Declare and initialize SHOW_1
volatile int SHOW_2=1; // Declare and initialize SHOW_2
volatile int number;
void Shimpyo(int time){ for(int i=0;i<time;i++)_delay_ms(50); }
void Cutoff_Play(void){ _delay_ms(20); TIMERvalue=1; _delay_ms(20); }
void ShowDigit(int i,int digit){ PORTC=~(0x01<<digit); PORTA=Segment_Data[i]; }
void Show4Digit(void){
  COLUMN[0]=(SHOW_1)/10; COLUMN[1]=(SHOW_1)%10;
  COLUMN[2]=(SHOW_2)/10; COLUMN[3]=(SHOW_2)%10;
  for(int i=0;i<4;i++){ ShowDigit(COLUMN[i],i); _delay_ms(2); }
void sum(void){ PORTC=0x00; PORTA=0xff; PORTE=0xff; }
void santasong(void){
  for(int i=0;i<40;i++){ freq=santa[i]; TIMERvalue=1000000/(8*freq); Shimpyo(santa_length[i]); Cutoff_Play(); }
ISR(INT0_vect){ flag0=1; }
ISR(INT1_vect){ flag1=1; }
ISR(INT2_vect){ flag2=1; }
ISR(TIMER0_COMP_vect){ OCR0=TIMERvalue; }
int main(void){
  DDRA=0xff;  DDRC=0xff;  DDRG=0x03;
  TCCR0=0x04; TCNT0=0x05; TIMSK=0x01;
  EICRA=0xFF; EIMSK=0x07; SREG=0x80;
    if(flag0){ flag0=0;
      number=SHOW_1*100+SHOW_2;
      count=calender[number];
      if(SHOW_1==12 && SHOW_2==25){ santasong(); _delay_ms(100); }
      else                        { PORTG=0x03; }
    if(flag1){ flag1=0;
      Show4Digit();
      keyin=(PING &0x0c)>>2;
      if(keyin){ _delay_ms(200); keyin=(PING & 0x0C)>> 2; }
      if(keyold!=keyin)change=1;
      else             change=0;
      if(change==1 && keyin==1){ if(++SHOW_1>12)SHOW_1=1; }
      if(change==1 && keyin==2){ if(++SHOW_2>31)SHOW_2=1; }
      if(change==1 && keyin==3){ keyin=0; }
    if(flag2){ flag2=0;
      if(change==1 && keyin==2){ calender[number]++; PORTG=0x02; _delay_ms(200); PORTG=0x00; }
DDRD=0x07;
입력핀을 출력으로 설정하면 고장납니다.
EIMSK=0x0f;
인터럽트를 4개 이네이블 시키고 함수를 3개만 만들면 오동작하게 됩니다.
ISR(INT1_vect){
인터럽트 함수 안에서 무한루프를 사용하면 안됩니다.
_delay_ms(200);
가급적 인터럽트 함수 안에서는 딜레이를 사용하지 않는 것이 좋습니다.
인터럽트안의 코드를 메인으로 옮겼으니 원하는 동작이 되도록 잘 완성시켜보세요
전체 기능을 파악하는 데에는 어려움이 있으므로 남이 도와드리기는 어렵습니다.
조회수 650
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23803
공지 사이트 이용 안내댓글[31] master 17-10-29 37805
질문 아두이노 여러 센서 연결댓글[4] 이미지첨부파일 공수백자 24-07-09 108
질문 기어드 모터 외부인터럽트 사용하여 1초 동안 펄스 세는 법댓글[3] 바밤 24-07-04 102
질문 STM32F429ZIT6 rtc alarm 인터럽트 i2c lcd에 구현하는 방법댓글[5] aaahhhj 24-06-29 187
질문 Atmega128 LCD 출력이 나오지 않습니다, 코드 확인 부탁드립니다. 이미지첨부파일 코드에막혀 24-06-25 54
답변 답변글 답변 : Atmega128 LCD 출력이 나오지 않습니다, 코드 확인 부탁드립니다.댓글[1] master 24-06-25 57
질문 atmega128 recipe for target 'main.o ' failed 오류댓글[3] hhhyyyeee 24-06-19 125
질문 atmega128 코드 합치기 앗메 24-06-18 88
답변 답변글 답변 : atmega128 코드 합치기 master 24-06-19 44
질문 아두이노 파력발전댓글[1] sighn 24-06-16 73
질문 ATmega4809 nRF24L01 모듈을 이용한 무선 통신댓글[3] Ahri 24-06-12 139
질문 atmega128에 dht11 왜 측정을 못하죠?댓글[1] 탈북한시민 24-06-11 98
질문 atmega128이 실행이 되지 않습니다댓글[1] 이미지첨부파일 니굴 24-06-10 79
질문 아트메가 128 쓰는디 while 문이 안먹혀요댓글[1] 수히 24-06-09 78
질문 atmega128 UART통신으로 FND출력 Rion 24-06-09 107
답변 답변글 답변 : atmega128 UART통신으로 FND출력댓글[1] master 24-06-10 102
질문 atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ댓글[2] 이미지첨부파일 왕두일 24-06-06 239
답변 답변글 답변 : atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ master 24-06-07 130
질문 atmega128을 이용한 LCD 사용에 문제가 발생했습니다.댓글[3] 이미지 네넴 24-06-05 774
질문 Co 센서 값에 따른 ppm을 계산하려는데댓글[1] 라칸 24-06-05 143
질문 17HS4401, A4988 스텝모터 제어댓글[1] 이미지 jhbaik 24-06-03 174
질문 코드비전avr을 이용한 아두이노 우노 제어댓글[1] gkstntjd 24-05-29 190
질문 Energia 시리얼 모니터에 아무것도 출력되지않습니다.댓글[1] 김의공 24-05-22 200
질문 아두이노 스위치, 에어펌프 연결댓글[1] 이미지첨부파일 존존 24-05-20 368
질문 MSP430런치패드를 이용한 LCD 코딩 관련 질문댓글[1] 뀨쥰이 24-05-16 248
질문 생활 속 가스 센서 이미지첨부파일 Fosen 24-05-13 119
질문 atmega128A로 초음파센서 바밤 24-05-13 284
답변 답변글 답변 : atmega128A로 초음파센서 master 24-05-13 246
질문 eeprom 값 출력이 다르게 나옵니다댓글[5] 이미지첨부파일 idghte 24-05-05 540
