질문게시판 > 답변 : atmega128a 외부인터럽트 두개와 7segment의 연결
TODAY378 TOTAL3,162,654
BASIC4MCU | 질문게시판 | 답변 : atmega128a 외부인터럽트 두개와 7segment의 연결
작성자 master 작성일2023-12-02 18:58 조회380회 댓글0건
#define F_CPU 16000000
#define B0   458
#define C1   523    // 도
#define C1_  554
#define D1   587    // 레
#define D1_  622
#define E1   659    // 미
#define F1   699    // 파
#define F1_  740
#define G1   784    // 솔
#define G1_  831
#define A1   880    // 라
#define A1_  932
#define B1   988    // 시
#define C2   C1*2   // 도
#define C2_  C1_*2
#define D2   D1*2   // 레
#define D2_  D1_*2
#define E2   E1*2   // 미
#define F2   F1*2   // 파
#define F2_  F1_*2
#define G2   G1*2   // 솔
#define G2_  G1_*2
#define A2   A1*2   // 라
#define A2_  A1_*2
#define B2   B1*2   // 시
#define DLY_0   32  // 온음표*2
#define DLY_1   16  // 온음표
#define DLY_2   8   // 2분 음표
#define DLY_4   4   // 4분 음표
#define DLY_8   2   // 8분 음표
#define DLY_16  1   // 16분 음표
volatile int santa[100]={E1,F1,G1,G1,A1,B1,C2,C2,E1,F1,G1,G1,G1,G1,G1,A1,G1,F1,F1,F1,E1,G1,C1,E1,D1,F1,F1,C1,B1};
volatile int santa_length[100]={DLY_8,DLY_8,DLY_4,DLY_2,DLY_8,DLY_8,DLY_4,DLY_2,DLY_8,DLY_8,DLY_8,DLY_8,DLY_8,DLY_8,DLY_4,DLY_8,DLY_8,DLY_8,DLY_8,DLY_4,DLY_2,DLY_2,DLY_2,DLY_2,DLY_2,DLY_2,DLY_1,DLY_2,DLY_1,};
char COLUMN[4]={0,0,0,0};
volatile unsigned char Segment_Data[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x27,0x7F,0x6F};
volatile char calender[0]={0};
volatile char flag0=0,flag1=0,flag2=0;
volatile int  freq=1000,i;
volatile int count;
volatile unsigned char TIMERvalue=0xFF;
volatile unsigned char keyin=0;  // Declare and initialize keyin
volatile unsigned char keyold=0; // Declare and initialize keyold
volatile unsigned char change=0; // Declare and initialize change
volatile int SHOW_1=1; // Declare and initialize SHOW_1
volatile int SHOW_2=1; // Declare and initialize SHOW_2
volatile int number;
void Shimpyo(int time){ for(int i=0;i<time;i++)_delay_ms(50); }
void Cutoff_Play(void){ _delay_ms(20); TIMERvalue=1; _delay_ms(20); }
void ShowDigit(int i,int digit){ PORTC=~(0x01<<digit); PORTA=Segment_Data[i]; }
void Show4Digit(void){
  COLUMN[0]=(SHOW_1)/10; COLUMN[1]=(SHOW_1)%10;
  COLUMN[2]=(SHOW_2)/10; COLUMN[3]=(SHOW_2)%10;
  for(int i=0;i<4;i++){ ShowDigit(COLUMN[i],i); _delay_ms(2); }
void sum(void){ PORTC=0x00; PORTA=0xff; PORTE=0xff; }
void santasong(void){
  for(int i=0;i<40;i++){ freq=santa[i]; TIMERvalue=1000000/(8*freq); Shimpyo(santa_length[i]); Cutoff_Play(); }
ISR(INT0_vect){ flag0=1; }
ISR(INT1_vect){ flag1=1; }
ISR(INT2_vect){ flag2=1; }
ISR(TIMER0_COMP_vect){ OCR0=TIMERvalue; }
int main(void){
  DDRA=0xff;  DDRC=0xff;  DDRG=0x03;
  TCCR0=0x04; TCNT0=0x05; TIMSK=0x01;
  EICRA=0xFF; EIMSK=0x07; SREG=0x80;
    if(flag0){ flag0=0;
      number=SHOW_1*100+SHOW_2;
      count=calender[number];
      if(SHOW_1==12 && SHOW_2==25){ santasong(); _delay_ms(100); }
      else                        { PORTG=0x03; }
    if(flag1){ flag1=0;
      Show4Digit();
      keyin=(PING &0x0c)>>2;
      if(keyin){ _delay_ms(200); keyin=(PING & 0x0C)>> 2; }
      if(keyold!=keyin)change=1;
      else             change=0;
      if(change==1 && keyin==1){ if(++SHOW_1>12)SHOW_1=1; }
      if(change==1 && keyin==2){ if(++SHOW_2>31)SHOW_2=1; }
      if(change==1 && keyin==3){ keyin=0; }
    if(flag2){ flag2=0;
      if(change==1 && keyin==2){ calender[number]++; PORTG=0x02; _delay_ms(200); PORTG=0x00; }
DDRD=0x07;
입력핀을 출력으로 설정하면 고장납니다.
EIMSK=0x0f;
인터럽트를 4개 이네이블 시키고 함수를 3개만 만들면 오동작하게 됩니다.
ISR(INT1_vect){
인터럽트 함수 안에서 무한루프를 사용하면 안됩니다.
_delay_ms(200);
가급적 인터럽트 함수 안에서는 딜레이를 사용하지 않는 것이 좋습니다.
인터럽트안의 코드를 메인으로 옮겼으니 원하는 동작이 되도록 잘 완성시켜보세요
전체 기능을 파악하는 데에는 어려움이 있으므로 남이 도와드리기는 어렵습니다.
조회수 380
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36691
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 19
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 66
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 93
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 271
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 173
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 206
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 252
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 265
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 178
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 311
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 563
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 218
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 274
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 326
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 235
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 287
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 268
