질문게시판 > ATmega128에서 LCD와 블루투스
TODAY392 TOTAL3,162,668
BASIC4MCU | 질문게시판 | ATmega128에서 LCD와 블루투스
작성자 fanfan 작성일2023-12-05 18:54 조회461회 댓글0건
//코드입니다.
#define F_CPU 16000000UL
#define __DELAY_BACKWARD_COMPATIBLE__
#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
#define STATE_3 3
#define NULL 0x00
unsigned char c = STATE_0;
#define BIT4_LINE2_DOT58 0x28
#define DISPON_CUROFF_BLKOFF 0x0C
#define DISPOFF_CUROFF_BLKOFF 0x08
#define INC_NOSHIFT 0x06
#define DISPCLEAR 0x01
#define CUR1LINE 0x80
#define CUR2LINE 0xC0
#define CURHOME 0x02
#define E_BIT 0x04
#define RW_BIT 0x03
#define RS_BIT 0x02
void CLCD_cmd(char);
void CLCD_data(char);
void CLCD_puts(char *);
void display_fnd(unsigned int value);
void init_CLCD();
void init_uart1();
char Fan_name[] = "Good Fan";
char START_LCD[] = "Put the number!";
char STOP_SPEED1[] = "Turn Off!";
char LOW_SPEED1[] = "Speed State 1";
char MID_SPEED1[] = "Speed State 2";
char HIGH_SPEED1[] = "Speed State 3";
char ERROR[] = "Put 1 or 2 or 3";
#define STOP_SPEED 0
#define LOW_SPEED 77
#define MID_SPEED 153
#define HIGH_SPEED 230
#define MOTOR_CW 0xb0
#define MOTOR_CCW 0x70
#define MOTOR_BRAKE 0xd0
#define MOTOR_STOP 0x30
#define MOTOR_STANDBY 0x00
int motor_speed[4] = {STOP_SPEED, LOW_SPEED, MID_SPEED, HIGH_SPEED};
void putchar1(char c)
while(!(UCSR1A & (1<<UDRE1)))
UDR1 = c;
void puts1(char *ptr)
while(*ptr != NULL)
putchar1(*ptr++);
char available1()
if(UCSR1A & (1<<RXC1))
return(1);
return(0);
char getchar1()
while(!(UCSR1A & (1<<RXC1)))
return(UDR1);
void init_uart1()
DDRE &= ~(1 <<PE0);
DDRE |= (1 << PE1);
UCSR1B = 0x18;//(1 << RXEN0) | (1 << TXEN0);//0x18;///
UCSR1C = 0x06;//(1 << UCSZ11) | (1 << UCSZ10);//0x06;////;
UBRR1H = 0;
UBRR1L = 8;
char c;
DDRB = 0xf0;
TCCR2 = 0x6b;
OCR2 = 0;
PORTB = MOTOR_STANDBY;
init_uart1();
_delay_ms(500);
init_CLCD();
if(!available1())
CLCD_cmd(CUR1LINE);
CLCD_puts(Fan_name);
CLCD_cmd(CUR2LINE);
CLCD_puts(START_LCD);
c = getchar1();
putchar1(c);
switch(c)
case '0' :
CLCD_cmd(DISPCLEAR);
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
CLCD_puts(STOP_SPEED1);
PORTB = MOTOR_STOP;
OCR2 = motor_speed[0];
case '1' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
CLCD_puts(LOW_SPEED1);
PORTB = MOTOR_CW;
OCR2 = motor_speed[1];
case '2' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
CLCD_puts(MID_SPEED1);
PORTB = MOTOR_CW;
OCR2 = motor_speed[2];
case '3' :
CLCD_cmd(CUR1LINE);
CLCD_cmd(CUR2LINE);
CLCD_puts(HIGH_SPEED1);
PORTB = MOTOR_CW;
OCR2 = motor_speed[3];
default :
//CLCD_cmd(DISPCLEAR);
//CLCD_cmd(CUR1LINE);
//CLCD_puts(Fan_name);
//CLCD_cmd(CUR2LINE);
//CLCD_puts(ERROR);
void init_CLCD()
DDRC = 0xff;
DDRD = 0xff;
_delay_ms(50);
PORTC = 0x00;
CLCD_cmd(BIT4_LINE2_DOT58);
CLCD_cmd(DISPON_CUROFF_BLKOFF);
CLCD_cmd(INC_NOSHIFT);
_delay_ms(2);
void CLCD_puts(char *ptr)
while(*ptr != NULL)
CLCD_data(*ptr++);
void CLCD_data(char data)
PORTD = 0x04;
_delay_us(1);
PORTD = 0x14;
PORTC = data & 0xf0;
PORTD = 0x04;
_delay_us(2);
PORTD = 0x14;
PORTC = (data << 4) & 0xf0;
PORTD = 0x04;
_delay_ms(1);
void CLCD_cmd(char cmd)
PORTD = 0x00;
_delay_us(1);
PORTD = 0x10;
PORTC = cmd & 0xf0;
PORTD = 0x00;
_delay_us(2);
PORTD = 0x10;
PORTC = (cmd << 4) & 0xf0;
PORTD = 0x00;
_delay_ms(1);
위와 같은 코드로 프로그램을 실행했을 때,   LCD 화면에 문자가 뜨질 않습니다. 왜 이런 문제가 발생하는 지 이해가 가질 않네요.
그런데, main에서  int_uart1(); 를 주석 처리를 하면 문자는 잘 뜹니다. 그런데  uart1 과  CLCD를 초기화 하고 프로그램을 실행하면 CLCD에 문자는 뜨지 않고, uart와 모터는 통신이 잘됩니다.
코드에 어떠한 문제가 있는지 알려주시면 감사하겠습니다..
조회수 461
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36691
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 19
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 66
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 93
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 271
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 173
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 206
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 252
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 265
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 178
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 311
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 563
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 218
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 274
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 327
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 235
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 287
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 269
