질문게시판 > 답변 : ATmega128에서 LCD와 블루투스
TODAY433 TOTAL3,162,709
BASIC4MCU | 질문게시판 | 답변 : ATmega128에서 LCD와 블루투스
작성자 master 작성일2023-12-05 21:17 조회568회 댓글1건
#define F_CPU 16000000UL
#define __DELAY_BACKWARD_COMPATIBLE__
#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
#define STATE_3 3
#define NULL    0x00
#define BIT4_LINE2_DOT58      0x28
#define DISPON_CUROFF_BLKOFF  0x0C
#define DISPOFF_CUROFF_BLKOFF 0x08
#define INC_NOSHIFT           0x06
#define DISPCLEAR             0x01
#define CUR1LINE              0x80
#define CUR2LINE              0xC0
#define CURHOME               0x02
#define E_BIT                 0x04
#define RW_BIT                0x03
#define RS_BIT                0x02
#define STOP_SPEED    0
#define LOW_SPEED     77
#define MID_SPEED     153
#define HIGH_SPEED    230
#define MOTOR_CW      0xb0
#define MOTOR_CCW     0x70
#define MOTOR_BRAKE   0xd0
#define MOTOR_STOP    0x30
#define MOTOR_STANDBY 0x00
char Fan_name[]="Good Fan";
char START_LCD[]="Put the number!";
char STOP_SPEED1[]="Turn Off!";
char LOW_SPEED1[]="Speed State 1";
char MID_SPEED1[]="Speed State 2";
char HIGH_SPEED1[]="Speed State 3";
char ERROR[]="Put 1 or 2 or 3";
int motor_speed[4]={STOP_SPEED, LOW_SPEED, MID_SPEED, HIGH_SPEED};
unsigned char c=STATE_0;
void putchar1(char c){ while(!(UCSR1A & (1<<UDRE1))); UDR1=c; }
void puts1(char *ptr){ while(*ptr !=NULL)putchar1(*ptr++); }
char available1(){
  if(UCSR1A & (1<<RXC1))return(1); else return(0);
char getchar1(){ while(!(UCSR1A & (1<<RXC1))); return(UDR1); }
void init_uart1(){
  DDRE &=~(1 <<PE0);
  DDRE |=(1 << PE1);
  UCSR1B=0x18;//(1 << RXEN0) | (1 << TXEN0); //0x18;///
  UCSR1C=0x06;//(1 << UCSZ11) | (1 << UCSZ10); //0x06;////;
  UBRR1H=0;
  UBRR1L=8;
void CLCD_data(char data){
  PORTD=0x04; _delay_us(1); PORTD=0x14; PORTC=data & 0xf0;
  PORTD=0x04; _delay_us(2); PORTD=0x14; PORTC=(data << 4) & 0xf0;
  PORTD=0x04; _delay_ms(1);
void CLCD_cmd(char cmd){
  PORTD=0x00; _delay_us(1); PORTD=0x10; PORTC=cmd & 0xf0;
  PORTD=0x00; _delay_us(2); PORTD=0x10; PORTC=(cmd << 4) & 0xf0;
  PORTD=0x00; _delay_ms(1);
void CLCD_puts(char *ptr){ while(*ptr !=NULL)CLCD_data(*ptr++); }
void init_CLCD(){
  DDRC=0xff; DDRD=0xff;
  _delay_ms(50);
  CLCD_cmd(BIT4_LINE2_DOT58);
  CLCD_cmd(DISPON_CUROFF_BLKOFF);
  CLCD_cmd(INC_NOSHIFT);
  CLCD_cmd(DISPCLEAR);
  _delay_ms(2);
int main(void){
  char c;
  DDRB=0xf0; PORTB=MOTOR_STANDBY;
  TCCR2=0x6b; OCR2=0;
  init_uart1();
  _delay_ms(500);
  init_CLCD();
    if(!available1()){
      CLCD_cmd(CUR1LINE);
      CLCD_puts(Fan_name);
      CLCD_cmd(CUR2LINE);
      CLCD_puts(START_LCD);
    c=getchar1();
    putchar1(c);
    switch(c){
      case '0' :
            CLCD_cmd(DISPCLEAR); CLCD_cmd(CUR1LINE); CLCD_puts(Fan_name);
            CLCD_cmd(CUR2LINE);  CLCD_puts(STOP_SPEED1);
            PORTB=MOTOR_STOP;  OCR2=motor_speed[0];
      case '1' :
            CLCD_cmd(CUR2LINE);  CLCD_puts(LOW_SPEED1);
            PORTB=MOTOR_CW;    OCR2=motor_speed[1];
      case '2' :
            CLCD_cmd(CUR2LINE);  CLCD_puts(MID_SPEED1);
            PORTB=MOTOR_CW;    OCR2=motor_speed[2];
      case '3' :
            CLCD_cmd(CUR1LINE);
            CLCD_cmd(CUR2LINE);
            CLCD_puts(HIGH_SPEED1);
            PORTB=MOTOR_CW;            OCR2=motor_speed[3];
      default :
            //CLCD_cmd(DISPCLEAR);
            //CLCD_cmd(CUR1LINE);
            //CLCD_puts(Fan_name);
            //CLCD_cmd(CUR2LINE);
            //CLCD_puts(ERROR);
UART1도 포트D인데 CLCD도 포트D를 사용하고 있습니다.
중복되지 않도록 비트마스크 방법을 사용하든지 다른 포트를 사용하세요
조회수 568
fanfan님의 댓글
fanfan 작성일
감사합니다. 다시 한번 살펴보고 해결해보겠습니다!
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36693
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 20
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 67
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 94
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 272
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 174
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 207
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 254
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 266
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 179
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 312
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 565
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 219
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 275
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 327
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 236
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 288
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 269
