질문게시판 > 아두이노 자판기 질문입니다
TODAY387 TOTAL3,162,663
BASIC4MCU | 질문게시판 | 아두이노 자판기 질문입니다
작성자 한세월두세월 작성일2023-12-06 22:22 조회321회 댓글1건
	#include <Servo.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
Servo servo;
int a, b, c, d ;
  for(int i=5;i<=8;i++)pinMode(i,INPUT_PULLUP); // <-- 수정
  lcd.init();
  lcd.backlight();
  lcd.print("    Press Button");
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.clear();
  a = digitalRead(5);
  b = digitalRead(6);
  c = digitalRead(7);
  d = digitalRead(8);
  Serial.print(a);
  Serial.print(b);
  Serial.print(c);
  Serial.print(d);
  //////////////////////////////////////a////////////////////////////////
  if( a== 0)
    lcd.clear();
    lcd.print("        5$        ");
    delay(2000);
    lcd.clear();
    lcd.print("  give your card");
    delay(3000);
    if( ! mfrc522.PICC_IsNewCardPresent())
      return;
    if(! mfrc522.PICC_ReadCardSerial())
      return;
    Serial.print("UID tag : ");
    String content ="";
    byte letter;
    for(byte i=0; i<mfrc522.uid.size; ++i)
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " ");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "));
      content.concat(String(mfrc522.uid.uidByte[i], HEX));
    Serial.println();
    Serial.print("Message : ");
    content.toUpperCase();
    if( content.substring(1) == "2B 3C C9 23")
      servo.attach(A0);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      lcd.print(" Take the cookies");
      delay(5000);
    //////////////////////////////////////b////////////////////////////////
  if( b== 0)
    lcd.clear();
    lcd.print("        6$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(2);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    //////////////////////////////////////c////////////////////////////////
  if( c== 0)
    lcd.clear();
    lcd.print("        6$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(3);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    /////////////////////////////////////d////////////////////////////////
  if( d== 0)
    lcd.clear();
    lcd.print("        8$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(4);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
원래 스위치를 누르고 give your card라는 문구가 lcd에 뜨면 rfid 카드를 가져다 대서 과자가 나오는 방식입니다
여기서 RFID에 카드를 가져다 대면 시리얼 모니터에 11111이라는 숫자가 계속 뜹니다. 혹시 정상적으로 작동할 수 있도록 할 수 있는 방법이 없을까요?  부탁드립니다..
조회수 321
한세월두세월님의 댓글
한세월두세월 작성일
rfid카드 식별번호도 기입했습니다..
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36691
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 19
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 66
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 93
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 271
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 173
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 206
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 252
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 265
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 178
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 311
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 563
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 218
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 274
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 327
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 235
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 287
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 269
