질문게시판 > 아두이노 자판기 질문입니다
TODAY6,869 TOTAL6,755,686
BASIC4MCU | 질문게시판 | 아두이노 자판기 질문입니다
작성자 한세월두세월 작성일2023-12-06 22:22 조회1,199회 댓글1건
	#include <Servo.h>
#include <SPI.h>
#include <MFRC522.h>
#include <Wire.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);
Servo servo;
int a, b, c, d ;
  for(int i=5;i<=8;i++)pinMode(i,INPUT_PULLUP); // <-- 수정
  lcd.init();
  lcd.backlight();
  lcd.print("    Press Button");
  SPI.begin();
  mfrc522.PCD_Init();
  lcd.clear();
  a = digitalRead(5);
  b = digitalRead(6);
  c = digitalRead(7);
  d = digitalRead(8);
  Serial.print(a);
  Serial.print(b);
  Serial.print(c);
  Serial.print(d);
  //////////////////////////////////////a////////////////////////////////
  if( a== 0)
    lcd.clear();
    lcd.print("        5$        ");
    delay(2000);
    lcd.clear();
    lcd.print("  give your card");
    delay(3000);
    if( ! mfrc522.PICC_IsNewCardPresent())
      return;
    if(! mfrc522.PICC_ReadCardSerial())
      return;
    Serial.print("UID tag : ");
    String content ="";
    byte letter;
    for(byte i=0; i<mfrc522.uid.size; ++i)
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " ");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "));
      content.concat(String(mfrc522.uid.uidByte[i], HEX));
    Serial.println();
    Serial.print("Message : ");
    content.toUpperCase();
    if( content.substring(1) == "2B 3C C9 23")
      servo.attach(A0);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      lcd.print(" Take the cookies");
      delay(5000);
    //////////////////////////////////////b////////////////////////////////
  if( b== 0)
    lcd.clear();
    lcd.print("        6$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(2);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    //////////////////////////////////////c////////////////////////////////
  if( c== 0)
    lcd.clear();
    lcd.print("        6$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(3);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
    /////////////////////////////////////d////////////////////////////////
  if( d== 0)
    lcd.clear();
    lcd.print("        8$        ");
    delay(2000);
    lcd.clear();
    delay(3000);
      return;
      return;
    String content ="";
    byte letter;
    Serial.println();
      servo.attach(4);
      servo.write(80);
      delay(2000);
      servo.detach();
      delay(2000);
      lcd.clear();
      delay(5000);
원래 스위치를 누르고 give your card라는 문구가 lcd에 뜨면 rfid 카드를 가져다 대서 과자가 나오는 방식입니다
여기서 RFID에 카드를 가져다 대면 시리얼 모니터에 11111이라는 숫자가 계속 뜹니다. 혹시 정상적으로 작동할 수 있도록 할 수 있는 방법이 없을까요?  부탁드립니다..
조회수 1,199
한세월두세월님의 댓글
한세월두세월 작성일
rfid카드 식별번호도 기입했습니다..
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 24261
공지 사이트 이용 안내댓글[31] master 17-10-29 38805
질문 공통음극형 FND를 9V로 동작하게 하고 싶어요.댓글[3] 새글 멘토 25-01-21 8
질문 oled 모듈 연결 질문입니다!댓글[1] 펌린이 24-12-17 163
질문 Atmega 128 타이머 질문있습니다댓글[1] ednda 24-12-11 189
답변 답변글 답변 : Atmega 128 타이머 질문있습니다 master 24-12-11 140
질문 ATmega128 2개로 hc-05,hc-06블루트수 통신 동콩이 24-12-04 157
답변 답변글 답변 : ATmega128 2개로 hc-05,hc-06블루트수 통신댓글[4] master 24-12-04 1249
질문 lm75a 온도센서 관련 질문입니다.댓글[6] 이미지첨부파일 hanmw0707 24-12-01 3264
질문 리얼타임클락 질문이요 ㅠㅠ댓글[1] 이미지 팬케이크 24-11-22 255
질문 가속도센서 2개를 강아지 2마리에 각각 달아서 스마트폰으로 움직임을 보고 싶은데요댓글[1] gainomax 24-11-21 422
질문 라즈베리파이 4B 사용 중 막히는 부분 질문합니다댓글[1] 한마바키 24-11-12 6573
질문 스위치로 PI 모터 제어 바밤 24-11-11 207
답변 답변글 답변 : 스위치로 PI 모터 제어 master 24-11-12 196
질문 아트메가128 마이크로프로세서댓글[3] 옹심이 24-11-05 712
질문 초음파 센서로 장애물 인식댓글[1] 나난ㄴ 24-10-31 324
질문 이런 투명 LCD는 뭐라고 부르나요?댓글[2] 이미지 펌린이 24-10-29 491
질문 모터제어 중 RPM 계산 질문입니다.댓글[3] suuuuuuuh 24-10-24 645
질문 아트메가 128과 블루투스 모듈(HC-06) 연결 질문댓글[1] 메가아트 24-10-24 340
질문 ATmega128 질문 DFplayer mini댓글[1] Miin 24-10-18 6825
질문 스탭모터 3개 회로도 질문.. 삉삉이 24-10-11 340
답변 답변글 답변 : 스탭모터 3개 회로도 질문.. 이미지 master 24-10-12 374
질문 수분수위센서와 멀티플렉서댓글[3] 김고래쓰 24-10-10 938
질문 ATmegq128 PI 제어기 추가댓글[1] 바밤 24-10-08 364
답변 답변글 답변 : ATmegq128 PI 제어기 추가댓글[1] master 24-10-08 496
질문 아두이노 ide 네오픽셀 각 셀 각자 코드 현수 24-09-29 226
질문 아두이노 IDE 프로마이크로 네오픽셀 현수 24-09-29 256
답변 답변글 답변 : 아두이노 IDE 프로마이크로 네오픽셀 master 24-09-29 233
질문 아두이노 프로마이크로 ide 현수 24-09-28 256
답변 답변글 답변 : 아두이노 프로마이크로 ide master 24-09-28 366
