질문게시판 > 답변 : 아두이노 자판기 질문입니다
TODAY432 TOTAL3,162,708
BASIC4MCU | 질문게시판 | 답변 : 아두이노 자판기 질문입니다
작성자 master 작성일2023-12-07 13:26 조회203회 댓글0건
#include <Servo.h>
Servo servo;
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN,RST_PIN);
#include <Wire.h>
int flag_a,flag_b,flag_c,flag_d,mode=0;
String content="";
byte letter;
  for(int i=5;i<=8;i++)pinMode(i,INPUT_PULLUP); // <-- 수정
  lcd.init(); lcd.backlight(); lcd.print("    Press Button");
  SPI.begin();
  mfrc522.PCD_Init();
  if(digitalRead(5)==0){
    if(flag_a==0){ flag_a=1; mode='a'; Serial.print(mode);
      lcd.clear(); lcd.print("        5$        "); delay(2000); lcd.clear(); lcd.print("  give your card");   delay(3000);
    if(flag_a){ flag_a=0; }
  if(digitalRead(6)==0){
    if(flag_b==0){ flag_b=1;  mode='b'; Serial.print(mode); lcd.clear(); lcd.print("  Press b Button");
      lcd.clear(); lcd.print("        6$        "); delay(2000); lcd.clear(); lcd.print("  give your card");   delay(3000);
    if(flag_b){ flag_b=0; }
  if(digitalRead(7)==0){
    if(flag_c==0){ flag_c=1;  mode='c'; Serial.print(mode); lcd.clear(); lcd.print("        5$        "); }
    if(flag_c){ flag_c=0; }
  if(digitalRead(8)==0){
    if(flag_d==0){ flag_d=1;  mode='d'; Serial.print(mode); lcd.clear(); lcd.print("  Press d Button"); }
    if(flag_d){ flag_d=0; }
  //////////////////////////////////////a////////////////////////////////
  if(mode!=0){
    if(! mfrc522.PICC_IsNewCardPresent())return;
    if(! mfrc522.PICC_ReadCardSerial())return;
    Serial.print("UID tag : ");
    content="";
    for(byte i=0; i<mfrc522.uid.size; ++i){
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "); Serial.print(mfrc522.uid.uidByte[i],HEX);
      content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : " "));
      content.concat(String(mfrc522.uid.uidByte[i],HEX));
    Serial.println(); Serial.print("Message : ");
    content.toUpperCase();
    if(content.substring(1)=="2B 3C C9 23"){
      switch(mode){
        case 'a': servo.attach(A0); break;
        case 'b': servo.attach(2);  break;
        case 'c': servo.attach(3);  break;
        case 'd': servo.attach(4);  break;
      servo.write(80); delay(2000); servo.detach(); delay(2000);
      lcd.clear(); lcd.print(" Take the cookies"); delay(5000);
      mode=0;
조회수 203
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23430
공지 사이트 이용 안내댓글[30] master 17-10-29 36693
질문 분주비와 업/업다운 카운트 관련 질문 드립니다.댓글[1] 412904 24-02-18 13
질문 stm32의 task댓글[1] 라칸 24-02-07 20
질문 stm32에서 ping 같은걸 해볼수 있나요?댓글[1] 라칸 24-01-23 67
질문 (초보)atmega128 led 제어 질문드립니다댓글[1] aaa123 24-01-22 94
질문 UART 통신을 하는데댓글[4] 라칸 24-01-10 272
질문 트랜지스터를 2개 쓰는이유댓글[2] 이미지첨부파일 소정이 24-01-10 174
질문 ,아두이노 서보모터 블루투스 연결댓글[4] 비누 23-12-22 972
질문 arduino 코드를 armega 128로 변환댓글[1] 이모저모 23-12-20 216
질문 MTP 주소 지정 방법댓글[1] adoui 23-12-19 207
질문 All-in-one air quality sensor Fosen 23-12-18 119
질문 Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문 ynbus 23-12-17 254
답변 답변글 답변 : Atmega128 PORTB에서 서보모터와 부저 사용 관련 질문댓글[1] master 23-12-17 502
질문 ATmega128에 MQ-3 센서를 사용하는 방법을 찾고 있습니다.댓글[1] 첨부파일 c언어초보 23-12-16 270
질문 3축 자이로센서로 진동값 계산하는 방법좀댓글[1] 라칸 23-12-15 222
질문 avr codevision에 led 교차하면서 소리나게 하는 법을 알고싶습니다.댓글[1] 주넘 23-12-14 266
질문 방금 글쓴 사람입니다!댓글[5] 이미지 범뚱 23-12-14 567
질문 이 코드에서 절대 7세그먼트 디스플레이에 불이 들어오지 않는데 왜 그럴까요?댓글[2] 범뚱 23-12-14 322
질문 아두이노 라인트레이서 질문 있습니다. 99999 23-12-14 191
답변 답변글 답변 : 아두이노 라인트레이서 질문 있습니다. master 23-12-14 179
질문 우노는 되는데 메가가 안됩니다(초음파)댓글[3] 초두이노 23-12-13 312
질문 atmega128 dht11 온도 센서 데이터출력댓글[4] 재효김 23-12-13 792
질문 ATMega128a 사용한 디지털 시계 질문입니다.댓글[3] 첨부파일 moon99 23-12-13 565
질문 서보모터 드라이버 관련 질문입니다.댓글[1] 뚱보개 23-12-13 219
질문 Atmega128 USART 질문입니다.댓글[1] dnjsjj 23-12-13 275
질문 codevision avr atmega128a 사용중입니다 범뚱 23-12-12 327
답변 답변글 답변 : codevision avr atmega128a 사용중입니다 master 23-12-13 236
질문 아두이노 주파수 변경하는법댓글[1] 파란하늘 23-12-12 288
질문 atmega 128 timer interrupt에 관한 질문 atmemem 23-12-12 269
